Pinephone pro stuck while booting
Exclamation
So i have a pinephone pro and i have tried every thing provided here https://forum.pine64.org/showthread.php?tid=18216 and gotten assistanve on discord which still did not help. Ive charged for approximately 10 hours on Maskrom, tried using a sd card, flashed directly to EMMC, attempted to reinstall Towboot, Used a gui tool and dd, and still it will not work. Whenever i turn it on with a working os installed it will flash red then yellow then stay stuck, the screen wont even show anything. If i try without an os on the phone it reboots as the it knows there no os installed. Sometimes too when i turn it on it will stay red and just vibrate as soon as it is turned on. It will not even boot to an SD card if i use either the RE button or the volume down button. I can however boot into mass storage mode by holding volume up and connect it to the computer, im not sure how much this can help but if anyone can help pls do.
(08-16-2025, 11:35 AM)Supervisor Wrote: So i have a pinephone pro and i have tried every thing provided here https://forum.pine64.org/showthread.php?tid=18216 and gotten assistanve on discord which still did not help. Ive charged for approximately 10 hours on Maskrom, tried using a sd card, flashed directly to EMMC, attempted to reinstall Towboot, Used a gui tool and dd, and still it will not work. Whenever i turn it on with a working os installed it will flash red then yellow then stay stuck, the screen wont even show anything. If i try without an os on the phone it reboots as the it knows there no os installed. Sometimes too when i turn it on it will stay red and just vibrate as soon as it is turned on. It will not even boot to an SD card if i use either the RE button or the volume down button. I can however boot into mass storage mode by holding volume up and connect it to the computer, im not sure how much this can help but if anyone can help pls do.
just in case advises.
if mobian: try different image week ago or two weeks ago. mobian have some bad images.
when using dd, writing target needs to be whole disk, not a partition. images for pinephone includes partitioning table.
# target shpould be a whole disk. # be careful about "of=" # use "lsblk" to list devices # "sync" is just in case # sudo or root access is required sudo dd status=progress bs=8M if=file-image.img of=/dev/sdx ; sync
ive tried this too, ive tried old images of mobiab, postmarket os, arch arm, and ubuntu touch
Nothing worked
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,401 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 835 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,667 01-24-2026, 01:01 PM
Last Post: heocb
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,849 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 6,840 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,877 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 15,194 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,890 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,555 09-06-2024, 02:39 AM
Last Post: zvavybir
  Pinephone pro shuts down immediately after login covar 4 6,845 07-03-2024, 10:59 AM
Last Post: covar
