RTKLIB PinePhone Pro GPS
Hello all,
I want to use my PinePhone Pro as a rover in a RTKLIB setup. Todo so, I have some questions:
1. Is it correct, that the Pinephone Pro GPS sensor can provide GPS raw data?
2. If yes, what is the format? In RTKLIB I can select rtcm2, rtcm3, oem4, oem3, ubx, ss2, hemis, skytraq, gw10, javad, sp3
3. On mobian the device should be ttyUSB1, correct? I have configured it with baudrate 115200. There are 2 additional options in RTKLIB inpstr-path config: 8:n:1:off Does anyone know, what does that mean and if it is correct for the PinePhone Pro?
By the way: What GPS chip is used in the phone?
(05-01-2025, 01:16 PM)jlaba Wrote: Hello all,
It does NMEA serial standard, not sure which of these options above do the same.
Look in the manual https://rtklib.com/prog/manual_2.3.0.pdf and search NMEA and the question should probably be answered.
Ideally I would like to be able to toggle the Pine Phone to become a bluetooth or USB GPS device(as well as a BT game controlller, and a bluetooth network hotspot as was done for the Linux Nokia N900)
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,191 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 768 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,563 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 4,032 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,650 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 6,686 07-02-2025, 02:03 PM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 14,863 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 6,771 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,486 09-06-2024, 02:39 AM
Last Post: zvavybir
  Pinephone pro shuts down immediately after login covar 4 6,658 07-03-2024, 10:59 AM
Last Post: covar
