Broken earpiece on a PPP? Fixing guide!
Pine64 shipped me a PPP with a broken earpiece (resistance: No Load). I originally deemed it a software issue, until I tried the hardware testing image.
Required items: sidecutters, small pliers, a boxcutter (thin handle helps), thin tape (e.g tesa), A Xaomi Mi 4 earpiece (Thanks Funeral!)
Visual guide: https://chonkyrabbit.eu/files/Media/ppp-earpiece-fix/
For further help, feel free to reply. I hope I did not forget anything.
You might as well try your luck finding the original earpiece on the web. Measurements: 6x13x2mm
I hope this helps!
Edit: MrRabbit found one: https://www.ebay.com/itm/322654218666
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 6,429 11-18-2023, 07:25 AM
Last Post: crocspot
  Pinephone Pro Earpiece is not working, need help silverwing 2 4,181 03-25-2023, 11:46 AM
Last Post: UltraBlack_
