reset wifi hardware/driver when it dies through console on pp?
Hi
question:
My wifi sometimes just dies, and i was wondering is there a way to reset the hardware/driver or something? like the modem reset command?
thanks!
(02-11-2023, 04:17 AM)tuxcall Wrote: Hi
question:
thanks!
Don't know if this will help, but try "sudo systemctl restart NetworkManager.service".
question:
thanks!
Yes, see below:
sudo rmmod 8723cs && sudo modprobe 8723cs
thanks! i'll try both those answers when my wifi drops/acts weird again
Thanks for sharing! This is what I am looking for
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,116 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Wifi doesn't work after update nickolas 2 3,038 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 3,331 01-12-2023, 03:06 PM
Last Post: user641
  Wifi issue since last update and held back updates goku499 11 11,170 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Hardware VIdeo Acceleration on Mobian biketool 3 4,481 06-21-2022, 01:01 PM
  Problem with wifi kubussz 0 1,502 04-02-2022, 12:57 PM
Last Post: kubussz
  Anyone using a hardware token? p121458 13 17,126 01-17-2022, 03:24 AM
  wifi adapter not found.. why? b7l3wui26r 3 3,692 11-29-2021, 10:28 AM
Last Post: beta-user
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 43,519 11-02-2021, 03:42 AM
Last Post: AntonReiser
  Jerky wifi and bluetooth motox6 0 1,870 06-22-2021, 12:50 AM
Last Post: motox6
