Armbian and LibreELEC and AltLinux for Quartz64
#81
(12-04-2022, 05:43 AM)balbes150 Wrote:
(12-04-2022, 05:09 AM)bosi564 Wrote: I'll quickly add a bit more information, because I'm not sure what will be helpful.  I'll have time later to do some tests (after 8-10 hours from this post).
My quartz64 has 8 gigabytes of RAM. I think I read somewhere in the wiki that early tests were done on devices with 4 gigabytes and there was no guarantee that video will work on devices with 8GB, but after a quick search I couldn't verify this info.
Quote:By the way, have other images been recorded on your SD card before? Perhaps the reason is the "remnants" of old systems that leave a backup copy of GPT or other data. Try to completely clean the SD card (using the DD utility) before writing the EDK2 image.
No, it was a brand new microSD from the store dedicated to video recording. But I'll wipe it clean later just to be sure.
The usb stick was used for some other linux/bsd installations, but I'll wipe it clean too.
There may be a problem with the launch, unlike models with 8GB of RAM. I have only a version with 4GB of RAM available, I can't debug a new system on 8 RAM versions. It may be necessary to change the settings, but without real equipment, it is not effective. And how does "normal" Armbian (latest versions with kernel 6.1) work on your model?
Please PM me your address, email address, and phone number (for shipping purpose), I will ship out 8GB version board to you.
I found in the source code and in the release tags that there were two versions with 4GB and 8GB for Quartz64 in the beginning. Try the options from the website for the 8GB version.
If this works, I'll try adding another option for the 8GB version.
https://github.com/jaredmcneill/quartz64_uefi/releases
Quote:.I found in the source code and in the release tags that there were two versions with 4GB and 8GB for Quartz64 in the beginning. Try the options from the website for the 8GB version.
I tried both the latest release from the link and the one which is a bit older, but for the 8GB ram variant and both didn't work out. Before that I've zeroed the microSD one time for the unified image (which tests for ram) and forgot to zeroed it before writing the older image for 8gb, but I think the Tianocore EDK image works fine. For example your image does recognize (from the tianocore menu) that the board has 8 gigabytes of ram and that the CPU is running at a speed close to 2ghz.
Also I tried armbian 23 from the community releases:
1. Armbian_23.02.0-trunk_Quartz64a_kinetic_edge_6.0.11.img
2. Armbian_23.02.0-trunk_Quartz64a_kinetic_edge_6.0.11_xfce_desktop.img
But the same problem occurred - the system didn't boot successfully.
I did try to randomly remove from the kernel's command line a "ro", which preceded a "rw" and some fsck.* options which resulted in that the monitor didn't go to sleep, although it didn't boot either.
Quote:Ver 20221204-EDK-EFI with support for direct launch from SD card, USB recording is not needed.
I had written a question earlier, but forgot to publish it. Where can I download this version? I couldn't find it at recent links.
Re-erasing the SD card from EDK2 is not required.
You have tried the wrong versions of Armbian. Check the versions from yandex disk (directory without extension in the name of EDK). To check, write the Armbian image to the SD card and check the launch WITHOUT EDK2.
Ver 20221206-EDK-EFI
see all the latest and test versions at this link (broken down by date)
https://disk.yandex.ru/d/xMVoaZXFFcWuog
I downloaded "Armbian_22.11.0-trunk_Quartz64a_jammy_edge_6.1.0.img.xz" and wrote it on the microSD card.
The monitor showed the Tianocore menu, then the GRUB menu and the default option was selected, again the monitor went to sleep. I had the NUM LOCK led toggled on before that, but when the monitor went to sleep, the led also shut down and couldn't be toggled anymore.
The led near the power jack is on and emitting green light. There's a led near the USB ports and near the reset button which flashes in red. I guess this is the heartbeat led mentioned in the wiki.
The board was running for about 10 minutes while I was writing this post. I'll leave it for a few more hours, but I'm not hopeful.
I'll try to find my UART adapter and try to connect to the board.
New info! I've got kernel panic Smile
After connecting to the serial console with baud speed 115200 (for your image), I've seen the beautiful information for booting options and the GRUB menu. Then I've edited the baud rate to 115200 on the kernel command line to see whatever was going on. (for some reason connecting initially with 1500000 as the wiki and your post from the armbian forum suggested didn't work).
I'm inserting the lines after I've edited the entry in the grub menu:
Quote:Booting a command list
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.1.0-rc8-media (root@vbox) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP PREEMPT Tue Dec  6 12:36:11 MSK 2022
[    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board
[    0.000000] efi: EFI v2.70 by EDK2
[    0.000000] efi: ACPI 2.0=0xecae0018 SMBIOS=0xefee0000 SMBIOS 3.0=0xefec0000 MEMATTR=0xefa35a98 RNG=0xecaef698 MEMRESERVE=0xecb43d18
[    0.000000] efi: seeding entropy pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x1fefed480-0x1fefeffff]
[    0.000000] Zone ranges:
[    0.000000]  DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]  DMA32    empty
[    0.000000]  Normal  [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]  node  0: [mem 0x0000000000000000-0x0000000000aeffff]
[    0.000000]  node  0: [mem 0x0000000000af0000-0x00000000083fffff]
[    0.000000]  node  0: [mem 0x0000000008400000-0x00000000093fffff]
[    0.000000]  node  0: [mem 0x0000000009400000-0x00000000ec9cefff]
[    0.000000]  node  0: [mem 0x00000000ec9cf000-0x00000000ecadffff]
[    0.000000]  node  0: [mem 0x00000000ecae0000-0x00000000ecaeffff]
[    0.000000]  node  0: [mem 0x00000000ecaf0000-0x00000000ecb3ffff]
[    0.000000]  node  0: [mem 0x00000000ecb40000-0x00000000efe1ffff]
[    0.000000]  node  0: [mem 0x00000000efe20000-0x00000000efeaffff]
[    0.000000]  node  0: [mem 0x00000000efeb0000-0x00000000efebffff]
[    0.000000]  node  0: [mem 0x00000000efec0000-0x00000000effdffff]
[    0.000000]  node  0: [mem 0x00000000effe0000-0x00000000efffffff]
[    0.000000]  node  0: [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] cma: Reserved 384 MiB at 0x00000000cec00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] ------------[ cut here ]------------
[    0.000000] WARNING: CPU: 0 PID: 0 at include/linux/cpumask.h:47 set_nr_cpu_ids.part.8+0x4/0x10
[    0.000000] Modules linked in:
[    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 6.1.0-rc8-media #trunk
[    0.000000] Hardware name: Pine64 RK3566 Quartz64-A Board (DT)
[    0.000000] pstate: 800000c9 (Nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    0.000000] pc : set_nr_cpu_ids.part.8+0x4/0x10
[    0.000000] lr : setup_nr_cpu_ids+0x28/0x34
[    0.000000] sp : ffffdcfaf2613e10
[    0.000000] x29: ffffdcfaf2613e10 x28: ffff3d553eff0100 x27: ffffdcfaf2275108
[    0.000000] x26: 0000000000000000 x25: ffffdcfaf2275108 x24: ffffdcfaf20deed8
[    0.000000] x23: ffffdcfaf20de000 x22: ffffdcfaf2619980 x21: ffffdcfaf2276100
[    0.000000] x20: 0000000000000000 x19: ffffdcfaf28f0000 x18: 0000000000000001
[    0.000000] x17: 6666666666666631 x16: 3030303030303078 x15: 692e74656e207365
[    0.000000] x14: 793d726961706572 x13: 6f6220303d73656d x12: 616e66692e74656e
[    0.000000] x11: 006e6169626d7261 x10: 2e6873616c707374 x9 : 6f6f623d656c6966
[    0.000000] x8 : 746f6f622e687361 x7 : 6c7073746f6f6220 x6 : 303d73656d616e66
[    0.000000] x5 : ffffdcfaf2619a60 x4 : 000000000000000f x3 : 000000000000003c
[    0.000000] x2 : 0000000000000000 x1 : 0000000000000100 x0 : 0000000000000003
[    0.000000] Call trace:
[    0.000000]  set_nr_cpu_ids.part.8+0x4/0x10
[    0.000000]  start_kernel+0x47c/0x9ec
[    0.000000]  __primary_switched+0xbc/0xc4
[    0.000000] ---[ end trace 0000000000000000 ]---
[    0.000000] percpu: Embedded 30 pages/cpu s83496 r8192 d31192 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1999872
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-rc8-media root=UUID=4caa7899-9e84-47f5-bcd9-669d5d19d8a6 ro console=ttyS02,115200 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian
[    0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-rc8-media", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000cac00000-0x00000000cec00000] (64MB)
[    0.000000] Memory: 7418712K/8126464K available (17152K kernel code, 2918K rwdata, 6572K rodata, 4544K init, 740K bss, 314536K reserved, 393216K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=256, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:    RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 26 jiffies.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes to big.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000925] Console: colour dummy device 80x25
[    0.001503] printk: console [tty0] enabled
[    0.001601] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001623] pid_max: default: 32768 minimum: 301
[    0.001749] LSM: Security Framework initializing
[    0.001792] Yama: becoming mindful.
[    0.001903] AppArmor: AppArmor initialized
[    0.002026] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002062] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.003082] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.003834] cblist_init_generic: Setting adjustable number of callback queues.
[    0.003860] cblist_init_generic: Setting shift to 8 and lim to 1.
[    0.003948] cblist_init_generic: Setting shift to 8 and lim to 1.
[    0.004131] rcu: Hierarchical SRCU implementation.
[    0.004143] rcu:    Max phase no-delay instances is 1000.
[    0.008277] Remapping and enabling EFI services.
[    0.008743] smp: Bringing up secondary CPUs ...
[    0.017053] Detected VIPT I-cache on CPU1
[    0.017129] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.017142] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.017186] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.025580] Detected VIPT I-cache on CPU2
[    0.025649] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.025661] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.025696] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.034032] Detected VIPT I-cache on CPU3
[    0.034105] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.034118] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.034150] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.034249] smp: Brought up 1 node, 4 CPUs
[    0.034341] SMP: Total of 4 processors activated.
[    0.034352] CPU features: detected: 32-bit EL0 Support
[    0.034360] CPU features: detected: 32-bit EL1 Support
[    0.034370] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.034381] CPU features: detected: Common not Private translations
[    0.034391] CPU features: detected: CRC32 instructions
[    0.034400] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.034409] CPU features: detected: LSE atomic instructions
[    0.034419] CPU features: detected: Privileged Access Never
[    0.034427] CPU features: detected: RAS Extension Support
[    0.034438] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.034506] CPU: All CPU(s) started at EL2
[    0.034517] alternatives: applying system-wide alternatives
[    0.039716] devtmpfs: initialized
[    0.054628] Registered cp15_barrier emulation handler
[    0.054665] Registered setend emulation handler
[    0.054842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.054882] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.061361] pinctrl core: initialized pinctrl subsystem
[    0.062056] SMBIOS 3.3.0 present.
[    0.062083] DMI: Pine64 PINE64 Quartz64 Model A/PINE64 Quartz64 Model A, BIOS EDK2-DEV 12/03/2022
[    0.062675] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.064141] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.064950] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.065536] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.065605] audit: initializing netlink subsys (disabled)
[    0.065826] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.066517] thermal_sys: Registered thermal governor 'fair_share'
[    0.066523] thermal_sys: Registered thermal governor 'bang_bang'
[    0.066536] thermal_sys: Registered thermal governor 'step_wise'
[    0.066546] thermal_sys: Registered thermal governor 'user_space'
[    0.066557] thermal_sys: Registered thermal governor 'power_allocator'
[    0.066645] cpuidle: using governor ladder
[    0.066713] cpuidle: using governor menu
[    0.067039] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.067157] ASID allocator initialised with 32768 entries
[    0.068349] Serial: AMBA PL011 UART driver
[    0.078548] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop
[    0.101776] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.102410] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.102938] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.103396] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.103850] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.106157] platform hdmi-con: Fixing up cyclic dependency with fe0a0000.hdmi
[    0.112750] KASLR enabled
[    0.123452] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.123484] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.123496] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.123506] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[    0.123516] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.123526] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.123536] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.123545] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.124446] cryptd: max_cpu_qlen set to 1000
[    0.190247] raid6: neonx8  gen()  2983 MB/s
[    0.258350] raid6: neonx4  gen()  3076 MB/s
[    0.326486] raid6: neonx2  gen()  2712 MB/s
[    0.394531] raid6: neonx1  gen()  2318 MB/s
[    0.462603] raid6: int64x8  gen()  2206 MB/s
[    0.530676] raid6: int64x4  gen()  2374 MB/s
[    0.598750] raid6: int64x2  gen()  2129 MB/s
[    0.666828] raid6: int64x1  gen()  1618 MB/s
[    0.666840] raid6: using algorithm neonx4 gen() 3076 MB/s
[    0.734897] raid6: .... xor() 2303 MB/s, rmw enabled
[    0.734908] raid6: using neon recovery algorithm
[    0.735855] ACPI: Interpreter disabled.
[    0.738337] iommu: Default domain type: Translated
[    0.738364] iommu: DMA domain TLB invalidation policy: strict mode
[    0.738876] SCSI subsystem initialized
[    0.739293] usbcore: registered new interface driver usbfs
[    0.739339] usbcore: registered new interface driver hub
[    0.739389] usbcore: registered new device driver usb
[    0.739910] pps_core: LinuxPPS API ver. 1 registered
[    0.739922] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.739959] PTP clock support registered
[    0.740314] EDAC MC: Ver: 3.0.0
[    0.740993] arm-scmi firmwareConfusedcmi: Enabled polling mode TX channel - prot_id:16
[    0.741119] arm-scmi firmwareConfusedcmi: SCMI Notifications - Core Enabled.
[    0.741173] arm-scmi firmwareConfusedcmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:3)
[    0.741192] arm-scmi firmwareConfusedcmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.741656] Registered efivars operations
[    0.742168] FPGA manager framework
[    0.742756] NetLabel: Initializing
[    0.742768] NetLabel:  domain hash size = 128
[    0.742779] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.742833] NetLabel:  unlabeled traffic allowed by default
[    0.742990] vgaarb: loaded
[    0.743472] clocksource: Switched to clocksource arch_sys_counter
[    0.743867] VFS: Disk quotas dquot_6.6.0
[    0.743937] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.744529] AppArmor: AppArmor Filesystem Enabled
[    0.744602] pnp: PnP ACPI: disabled
[    0.752222] NET: Registered PF_INET protocol family
[    0.752594] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.756491] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.756693] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.756819] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.757451] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.759228] TCP: Hash tables configured (established 65536 bind 65536)
[    0.759548] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.759704] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.760010] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.760051] NET: Registered PF_XDP protocol family
[    0.760069] PCI: CLS 0 bytes, default 64
[    0.760322] Trying to unpack rootfs image as initramfs...
[    0.768592] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.769306] kvm [1]: IPA Size Limit: 40 bits
[    0.769374] kvm [1]: GICv3: no GICV resource entry
[    0.769386] kvm [1]: disabling GICv2 emulation
[    0.769411] kvm [1]: GIC system register CPU interface enabled
[    0.769599] kvm [1]: vgic interrupt IRQ9
[    0.769753] kvm [1]: VHE mode initialized successfully
[    0.771739] Initialise system trusted keyrings
[    0.771802] Key type blacklist registered
[    0.772066] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[    0.777153] zbud: loaded
[    0.778866] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.779712] fuse: init (API version 7.37)
[    0.782383] integrity: Platform Keyring initialized
[    0.807262] xor: measuring software checksum speed
[    0.809905]    8regs          :  3831 MB/sec
[    0.812856]    32regs          :  3393 MB/sec
[    0.816010]    arm64_neon      :  3173 MB/sec
[    0.816034] xor: using function: 8regs (3831 MB/sec)
[    0.816054] Key type asymmetric registered
[    0.816064] Asymmetric key parser 'x509' registered
[    1.594269] Freeing initrd memory: 28856K
[    1.608089] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    1.608218] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.608351] io scheduler mq-deadline registered
[    1.608368] io scheduler kyber registered
[    1.608599] io scheduler bfq registered
[    1.620787] EINJ: ACPI disabled.
[    1.626208] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.626242] dma-pl330 fe530000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.628050] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.628078] dma-pl330 fe550000.dma-controller:      DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.632055] arm-scmi firmwareConfusedcmi: Failed. SCMI protocol 22 not active.
[    1.635293] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    1.638020] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 29, base_baud = 1500000) is a 16550A
[    1.639147] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 30, base_baud = 1500000) is a 16550A
[    1.639282] serial serial0: tty port ttyS1 registered
[    1.640232] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 31, base_baud = 1500000) is a 16550A
[    3.439592] printk: console [ttyS2] enabled
[    3.445425] Serial: AMBA driver
[    3.452091] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.465940] brd: module loaded
[    3.475247] loop: module loaded
[    3.485260] thunder_xcv, ver 1.0
[    3.488950] thunder_bgx, ver 1.0
[    3.492601] nicpf, ver 1.0
[    3.496311] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.504405] hns3: Copyright © 2017 Huawei Corporation.
[    3.510419] hclge is initializing
[    3.515278] VFIO - User Level meta-driver version: 0.3
[    3.524163] usbcore: registered new interface driver usb-storage
[    3.525402] ehci-platform fd880000.usb: EHCI Host Controller
[    3.525420] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    3.525432] ehci-platform fd800000.usb: EHCI Host Controller
[    3.525440] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 1
[    3.525448] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 2
[    3.525590] ohci-platform fd8c0000.usb: irq 38, io mem 0xfd8c0000
[    3.525619] ehci-platform fd800000.usb: irq 35, io mem 0xfd800000
[    3.525634] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    3.525648] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[    3.525734] ohci-platform fd840000.usb: irq 37, io mem 0xfd840000
[    3.532689] mousedev: PS/2 mouse device common for all mice
[    3.537274] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4
[    3.539484] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    3.539785] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.539793] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.539798] usb usb2: Product: EHCI Host Controller
[    3.539803] usb usb2: Manufacturer: Linux 6.1.0-rc8-media ehci_hcd
[    3.539807] usb usb2: SerialNumber: fd800000.usb
[    3.540256] hub 2-0:1.0: USB hub found
[    3.540301] hub 2-0:1.0: 1 port detected
[    3.545898] rtc-efi rtc-efi.0: registered as rtc0
[    3.551223] ehci-platform fd880000.usb: irq 36, io mem 0xfd880000
[    3.559943] rtc-efi rtc-efi.0: setting system clock to 2022-12-03T13:01:35 UTC (1670072495)
[    3.583527] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    3.587643] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    3.587652] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.587658] usb usb3: Product: Generic Platform OHCI controller
[    3.587662] usb usb3: Manufacturer: Linux 6.1.0-rc8-media ohci_hcd
[    3.587666] usb usb3: SerialNumber: fd840000.usb
[    3.588093] hub 3-0:1.0: USB hub found
[    3.588121] hub 3-0:1.0: 1 port detected
[    3.588500] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    3.588508] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.588513] usb usb1: Product: Generic Platform OHCI controller
[    3.588517] usb usb1: Manufacturer: Linux 6.1.0-rc8-media ohci_hcd
[    3.588521] usb usb1: SerialNumber: fd8c0000.usb
[    3.588902] hub 1-0:1.0: USB hub found
[    3.588930] hub 1-0:1.0: 1 port detected
[    3.590338] i2c_dev: i2c /dev entries driver
[    3.598764] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.607422] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    3.611645] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.611651] usb usb4: Product: EHCI Host Controller
[    3.611655] usb usb4: Manufacturer: Linux 6.1.0-rc8-media ehci_hcd
[    3.617871] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[    3.620434] usb usb4: SerialNumber: fd880000.usb
[    3.620885] hub 4-0:1.0: USB hub found
[    3.628359] rk808 0-0020: chip id: 0x8170
[    3.636662] hub 4-0:1.0: 1 port detected
[    3.719718] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[    3.864897] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.871875] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.878802] rk808-regulator rk808-regulator: max buck steps per change: 8
[    3.915177] vccio_acodec: Bringing 1800000uV into 3300000-3300000uV
[    3.943237] vcc2v8_dvp: Bringing 1800000uV into 2800000-2800000uV
[    3.955729] boost: Bringing 4700000uV into 5000000-5000000uV
[    3.974854] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    5.023512] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x93, state: 2
[    5.030157] rk808-rtc rk808-rtc: Failed to bulk read rtc_data: -110
[    5.037489] rk808-rtc rk808-rtc: registered as rtc1
[    6.079498] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[    7.103505] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[    8.127489] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[    9.151489] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[  10.175491] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[  11.199491] rk3x-i2c fdd40000.i2c: timeout, ipd: 0x80, state: 2
[  11.206131] cpu cpu0: _set_opp_voltage: failed to set voltage (1050000 1050000 1150000 mV): -110
[  11.215975] cpu cpu0: Failed to set regulator voltages: -110
[  11.222315] cpufreq: __target_index: Failed to change cpu frequency: -110
[  11.229951] ------------[ cut here ]------------
[  11.235114] kernel BUG at drivers/cpufreq/cpufreq.c:1480!
[  11.241151] Internal error: Oops - BUG: 00000000f2000800 [#1] PREEMPT SMP
[  11.248744] Modules linked in:
[  11.252160] CPU: 3 PID: 1 Comm: swapper/0 Tainted: G        W          6.1.0-rc8-media #trunk
[  11.261697] Hardware name: Pine64 PINE64 Quartz64 Model A/PINE64 Quartz64 Model A, BIOS EDK2-DEV 12/03/2022
[  11.272592] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[  11.280379] pc : cpufreq_online+0x830/0x9d0
[  11.285064] lr : cpufreq_online+0x82c/0x9d0
[  11.289742] sp : ffff80000803b9b0
[  11.293444] x29: ffff80000803b9b0 x28: 0000000000000000 x27: 0000000000000001
[  11.301429] x26: ffff3d5447759a18 x25: ffffdcfaf2998000 x24: ffff3d5447759820
[  11.309414] x23: ffffdcfaf261dd40 x22: ffffdcfaf22ea7c0 x21: 0000000000000000
[  11.317398] x20: 00000000001e6540 x19: ffff3d5447759800 x18: 0000000000000010
[  11.325383] x17: 3030353031203030 x16: 3030353031282065 x15: 0000000000000166
[  11.333368] x14: ffff80000803b6f0 x13: 00000000ffffffea x12: ffffdcfaf271f590
[  11.341352] x11: 0000000000000003 x10: 0000000000000001 x9 : ffff80000803c000
[  11.349336] x8 : ffff800008038000 x7 : ffff3d5447759a50 x6 : 0000000000000000
[  11.357320] x5 : ffff80000803b8c0 x4 : 0000000000000000 x3 : 0000000000000001
[  11.365304] x2 : 26f046606e331500 x1 : 0000000000000000 x0 : 00000000ffffff92
[  11.373288] Call trace:
[  11.376018]  cpufreq_online+0x830/0x9d0
[  11.380307]  cpufreq_add_dev+0xcc/0xe8
[  11.384491]  subsys_interface_register+0xa0/0x108
[  11.389755]  cpufreq_register_driver+0x178/0x300
[  11.394918]  dt_cpufreq_probe+0x224/0x490
[  11.399401]  platform_probe+0x68/0xd8
[  11.403496]  really_probe+0xc0/0x3a0
[  11.407495]  __driver_probe_device+0x7c/0x188
[  11.412367]  driver_probe_device+0x3c/0x108
[  11.417045]  __driver_attach+0xf8/0x1d8
[  11.421325]  bus_for_each_dev+0x74/0xc8
[  11.425613]  driver_attach+0x24/0x30
[  11.429611]  bus_add_driver+0x1dc/0x250
[  11.433899]  driver_register+0x64/0x120
[  11.438179]  __platform_driver_register+0x28/0x38
[  11.443438]  dt_cpufreq_platdrv_init+0x1c/0x28
[  11.448408]  do_one_initcall+0x4c/0x290
[  11.452698]  kernel_init_freeable+0x244/0x2b4
[  11.457571]  kernel_init+0x24/0x130
[  11.461471]  ret_from_fork+0x10/0x20
[  11.465473] Code: 51000681 aa1303e0 97fff7b4 34000ba0 (d4210000)
[  11.472288] ---[ end trace 0000000000000000 ]---
[  11.477449] note: swapper/0[1] exited with preempt_count 1
[  11.483609] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[  11.492173] SMP: stopping secondary CPUs
[  11.496561] Kernel Offset: 0x5cfae8a50000 from 0xffff800008000000
[  11.503374] PHYS_OFFSET: 0xffffc2acc0000000
[  11.508048] CPU features: 0x30000,001400a4,6600721b
[  11.513501] Memory Limit: none
[  11.516913] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
@bosi564 I wrote to you about checking the launch of a "clean" Armbian without EDK2. That is, you need to download and burn an image from the directory to the SD card WITHOUT specifying "EDK-EFI" in the directory name. Check the launch of the EDGE and CURRENT versions. And show the UART log when launching the EDGE and CURRENT versions.
(12-05-2022, 12:22 AM)tllim Wrote: Please PM me your address, email address, and phone number (for shipping purpose), I will ship out 8GB version board to you.
wrote  Smile
Perhaps someone can stub me into the right direction...
I build an Armbian from @balbes150 repo.
But I only get 2Gb of ram instead of 8Gb.
I think I misconfigured something, but where?
(12-07-2022, 07:35 AM)MC68060 Wrote: Perhaps someone can stub me into the right direction...
Which model are you creating an image for ?
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 17,226 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,131 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,569 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 54,855 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 85,465 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 5,224 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,163 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,240 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,500 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 3,825 07-21-2022, 01:08 PM
Last Post: Randomuser
