Fedora Workstation (36) on Pinebook Pro
(08-31-2022, 04:43 PM)u974615 Wrote:
(08-30-2022, 09:50 PM)pjsf Wrote: did you use dnf to install the rpm or software-center or something else?
so if you do lsmod do you see brcrmfmac loaded? I was actually misrembering , the only firmware I needed to find was BCM4345CS.hcd for the bluetooth support.
I used "$ sudo rpm --install brcm-pinebookpro-0.0-1.noarch.rpm"
I even copied (cp -r option) all the firmware files from the working Manjaro Plasma installed on the eMMC to the Fedora 36 Workstation image.
lsmod doesn't list brcmfmac nor any brcm module.
I was going to remove all the existing firmware files and re-copy the firmware files again.
so what happens if you do modprobe brcmfmac?
(08-31-2022, 07:14 PM)pjsf Wrote: so what happens if you do modprobe brcmfmac?
Actually, it is working now.  I cleared out all the firmware files and copied over the Manjaro Plasma ones.  And upon booting it up Wifi started working.
That's good! How's performance on emmc?
(08-31-2022, 08:07 PM)pjsf Wrote: That's good! How's performance on emmc?
Not too bad.  I haven't used the laptop much.  I feel like the slowness really is in the booting and not the eMMC speed.
Also, I suspect that the 4GB of RAM is probably causing more of the sluggishness that I experience when in GNOME3 shell.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 7,513 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 8,400 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 4,222 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,142 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 6,944 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 13,676 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 9,642 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 6,020 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 6,890 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 128,528 12-08-2023, 11:25 PM
