Android (android_dd_20160112) first impressions
#21
The last build, android with root. Yes, you are right, the play store has problem. I just installed Ubuntu now, it's working with lag. But it's appear that it's the bad performance of my MicroSD card which caused the lag. The CPU and RAM are OK, and iotop report that the SD is very bad... Any advice to buy new one ?
Cheers,
Red
#22
(05-30-2016, 03:41 PM)RedwinX Wrote: The last build, android with root. Yes, you are right, the play store has problem. I just installed Ubuntu now, it's working with lag. But it's appear that it's the bad performance of my MicroSD card which caused the lag. The CPU and RAM are OK, and iotop report that the SD is very bad... Any advice to buy new one ?
Cheers,
Red
I use Sandisk extreme U3's which work excellent for me.
I think the community recommends Samsung EVO+ as the best option.
#23
Cheers,
Red
Thanks Smile. Is it possible to run the system via usb (external ssd for exemple). It seems to be that it's possible for the rpi, the sd card used just for bootloader.
EDIT : I just found the solution, just copy the root partition tu the usb drive, and change the fstab Smile
#24
Cheers,
Red
I think that this has been answered already and it's not possible...
If you by any chance, find a way please do update us Wink
#25
I have received my Samsung MicroSD Pro+ 32Go, and it's working very fine (between 85-95Mo/s RW) Big Grin
#26
(06-05-2016, 06:01 AM)RedwinX Wrote: I have received my Samsung MicroSD Pro+ 32Go, and it's working very fine (between 85-95Mo/s RW) Big Grin
Good to know. Enjoy! Smile
  Need help compiling android for pine a64 + YeeticusMaximus22 1 969 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 559,132 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 45,349 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,836 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,337 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,648 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,358 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,913 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 376,888 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,650 02-26-2019, 11:58 AM
Last Post: Twistedx
