Mobian : Firefox, toolbar has moved to the bottom.
On my PinePhone Pro running Mobian the Firefox UI has automagically changed itself. The toolbars, Menu, URL field and buttons are all now at the bottom. I can't find the setting in Firefox to change it back. It is driving me nuts.
This is only on the PinePhone Pro Firefox on my PinePhone Firefox seems unchanged. Apart from applying available updates I have made no other changes to the OS and Firefox on this device. The PPP has been undated and rebooted this morning. Still no change.
Has there been a change in the files in userChrome, CSS etc that moves the UI elements around? If I know what has been changed then I have a chance of changing it back. Otherwise I can go and get the files created by Aris on Github to customise the Firefox UI and at least get the toolbar back at the top.
(03-06-2022, 01:27 AM)grump_fiddle_reinstall Wrote: On my PinePhone Pro running Mobian the Firefox UI has automagically changed itself. The toolbars, Menu, URL field and buttons are all now at the bottom. I can't find the setting in Firefox to change it back. It is driving me nuts.
Yes, the firefox-mobile-config package configures the toolbar via a configuration file. Inspecting the package should tell you pretty quickly, the changes are also explained here: https://wiki.mobian-project.org/doku.php?id=firefox-esr
  Experimental Mobian kernel patch for extended battery life teekay 15 16,775 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 21,730 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,687 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 8,986 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,143 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,144 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,066 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,818 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 1,963 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,097 10-14-2023, 11:57 AM
Last Post: mburns
