Armbian for Rock64
#41
(01-21-2022, 12:27 PM)gedas07 Wrote:
(01-20-2022, 08:12 PM)Rocklobster Wrote:
(01-18-2022, 12:57 PM)gedas07 Wrote: hello I have installed rock64 armbian debian bullseye, on the emmc card and I have an ssd disk by usb3, the disk is mounted in /etc/fstab, but every day approx it gives me an error
  blk_update_request: critical target error, dev sda, sector 250069504 op 0x0SadREAD) flags 0x0 phys_seg 1 prio class 0
[18241.624593] Buffer I/O error on dev sda, logical block 31258688, async page read
I have tried several discs and it happens to all of them
Is there something to be able to install so that I don't get that error
Thanks a lot
Do you have another computer you could use to check the integrity of  your SSD drives. Possibly a faulty batch. Alternatively could you install the Armbian Buster distribution and try that. Bullseye is known to be quite buggy at the moment.
Thanks for your answer
But the ssd, it worked perfectly, a day before with ubuntu 18, but with bullseye it gives those I/O failures
I have put another different ssd and after a few days it gives the same error
Try Armbian Buster so. If you can rule out OS issues you'll narrow it down to hardware issues.
Just a thought. How are you powering the SSD. You may not have enough capacity on your power supply if you are powering it from the board. Any dip in power usually leads to undercurrent voltage and will throw errors typically on storage devices
Thanks a lot
Hello, if the ssd has an external source, to be powered, so it is not the problem, what I said with ubuntu 18 was a year and it works perfect.
Switch to debian to stay up to date,
What image of buster do you recommend to try?
thanks
Thanks a lot
thanks
Try Armbian Focal if you need a desktop. Try Armbian Buster if server is all you need. You can download both from here https://wiki.pine64.org/index.php/ROCK64...MC_Boot.5D
Thanks a lot.
Hello, is Armbian currently the best/more stable linux server image for Rock64?
(02-08-2022, 08:23 PM)va88 Wrote: Hello, is Armbian currently the best/more stable linux server image for Rock64?
Probably the most widely used and in my case very stable.
finally install armbian buster, and install my rock64, the lxde desktop, when I'm in desktop mode I have black lines that flash horizontally on the screen every x seconds.
Is there something to install and that does not come out?
(02-28-2022, 11:44 AM)gedas07 Wrote: finally install armbian buster, and install my rock64, the lxde desktop, when I'm in desktop mode I have black lines that flash horizontally on the screen every x seconds.
Sorry to hear that. Have you installed latest?
There is a release just today happening. I don't know if anything specific has been addressed there (but you could check the release announcement).
Either wait a day or so and download new image, or you can build now yourself if you don't want to wait.
Let us know how it goes. Maybe make a post on Armbian forum if problems persist, likely much better chance of being seen there.
Cheers,
TRS-80
Protocols, not Platforms
Where I can find the image ? and Is it possible to install it without losing anything already installed?
(03-01-2022, 03:59 PM)gedas07 Wrote: Where I can find the image ?
OK, in general:
https://www.armbian.com/download/
But you will notice it's not listed.  You can still manually go to https://www.armbian.com/rock64/ however, but here we must note a few very important things:
  • It's CSC (no support).  This is a red flag.
  • There is a link to a forum thread about stability.
  • There is another note about eMMC troubles.
At this point I am wondering which image Rocklobster is using?  Did you build?  Because I see a lot of red flags here.
Are you sure Rocklobster you are referring to Rock64 (and not ROCKPro64)?  I just want to be sure.
(03-01-2022, 03:59 PM)gedas07 Wrote: Is it possible to install it without losing anything already installed?
Generally speaking, this is not supported.  However there are some people on the forums telling how to do this.  You would be on your own however.
But there seem to be much bigger problems here, proceed with caution!
I knew this sounded vaguely familiar.  I see gedas07 that you found your way to make this post.  I would advise to keep looking around the forums there and see if anyone found a solution.  Otherwise we are into development and bug fixing here.
Cheers,
TRS-80
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,179 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 468 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,703 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,723 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,724 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,838 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,016 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 79,107 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 104,938 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,358 03-14-2024, 03:09 AM
