PinePhone Pro and inaccessible WiFi channels
I run my WiFi on channel 13 (2472MHz 20MHz width) and channel 142 (5700MHz, 40MHz width) because of high congestion. It's legal where I live and I never have any problem because of that.
PPP EE works fine with both bands out of the box with stock firmware, however most third party distributions like the latest mobian refuse to work with these channels, SSIDs are just not visible on the phone.
Changing channels to something more common works this around, but noticeably reduces performance for other devices because of congestion.
iw reg get lists these frequences as usable:
phy#0
country 99: DFS-UNSET
 (2402 - 2482 @ 40), (6, 20), (N/A)
 (2474 - 2494 @ 20), (6, 20), (N/A)
 (5140 - 5360 @ 160), (6, 20), (N/A)
 (5460 - 5860 @ 160), (6, 20), (N/A)
There is no regulation data in system so regulation setting is bogus, but installing CRDA and setting a proper regulation domain doesn't result in anything.
I've tried to remove stock "brcmfmac43455-sdio.bin", "brcmfmac43455-sdio.clm_blob" and "brcmfmac43455-sdio.pine64,pinephone-pro.txt" from /lib/firmware/brcm and use firmwares from different images for PPP and PBP instead, the best I could get to is using "brcmfmac43455-sdio.bin", "brcmfmac43455-sdio.clm_blob" and "brcmfmac43455-sdio.txt" from /lib/firmware/updates/brcm (note the updates subdirectory) of the stock system.
This way I can use my 5GHz network, but 2.4GHz is still not accessible.
Have anyone else run into this issue? Any ideas on how to fix?
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,244 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 3,622 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,996 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,847 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,871 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,993 02-26-2025, 02:15 AM
Last Post: TOF
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 9,322 12-22-2024, 04:21 PM
Last Post: dchang0
  Manjaro plasma mobile Wifi Uturn 2 3,639 12-05-2024, 12:46 AM
Last Post: Uturn
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,292 10-28-2024, 10:46 AM
Last Post: Jite
  tow-boot, just bought pinephone pro stratofall 4 5,043 07-30-2024, 03:43 PM
Last Post: stratofall
