Phone bricked after update. Won't boot
Hello all,  after running the pinephonepro-post install script, I was able to update the phone with the latest repositories.  After the upgrade, i restarted my phone to make sure everything was good to go, and the phone never turned back on.  It has been completely dead since, and I have tried several of the tricks on the forum to see if I could get it to boot up.  It had about 50% power when it went down.  It was completely done with the update as well.  Not sure why a simple reboot would brick the phone.  Anyways, Any help would be appreciated. Thanks in advance
Try to charge the phone, maybe try a sd card with an OS flashed to it..?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Have you tried to boot on a SD card holding the RE button to bypass the eMMC? As explained here: https://wiki.pine64.org/wiki/PinePhone_P...g_the_eMMC
(02-02-2022, 05:59 PM)mando Wrote: Hello all,  after running the pinephonepro-post install script, I was able to update the phone with the latest repositories.  After the upgrade, i restarted my phone to make sure everything was good to go, and the phone never turned back on.  It has been completely dead since, and I have tried several of the tricks on the forum to see if I could get it to boot up.  It had about 50% power when it went down.  It was completely done with the update as well.  Not sure why a simple reboot would brick the phone.  Anyways, Any help would be appreciated. Thanks in advance
In particular which tricks have you tried? It'll help narrow things down.
AH  !
I have the same symptoms  ===> however my Explorer phone IS booting.
The boot indicator LED is not activating...  I posted this on the Bookworm thread.
Start with a normal 2 second power button press,  then just wait,  maybe up to 2+ minutes,
IT is Hard to just wait when you are looking at a black screen.  ===> Eventually the lock screen shows up.
IF the phone is on --- but froze from a suspend fault ---  a 12 second press on power button ---  then wait about 60 seconds for the lock screen.
A Few bugs, but over-all,   the new Explorer with Bookworm on sd card is running fairly well,
I used it to surf the forum and write a few posts a day or so back, --  I even used the cell data.
IT DOES SUCK ===>   THAT BOOT INDICATOR LIGHT IS NOT WORKING   Exclamation
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Hi  @mando
Did you ever resolve this problem ?
Which operating system are you using ?
( could it be your boot indicator light is not functioning ? )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Can't detect the phone's battery shanewilliam 2 1,946 05-17-2026, 04:49 AM
Last Post: drh
  pine phone konaphone 2 2,308 10-23-2025, 07:53 AM
Last Post: mikehenson
  Goolge banning Sideloaded APKs in 2026, Year of the really Linux Phone? biketool 1 5,894 08-27-2025, 11:59 AM
Last Post: zetabeta
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 4,604 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 3,532 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  No rk2aw boot menu jebez 7 5,371 07-09-2025, 07:12 AM
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 17,525 03-13-2025, 08:40 PM
Last Post: pcb
  Bluetooth for phone calls Stray 2 3,712 02-25-2025, 12:22 PM
Last Post: Stray
  PinePhone doesn't boot anymore lapin 3 3,935 09-13-2024, 10:09 AM
Last Post: lapin
  How to boot from SD card in PPP joespodie 2 4,988 08-02-2024, 02:49 PM
