Can't detect the phone's battery
I just flashed postmarketOS onto my PinePhone Pro, and everything seems to be functioning well, except the OS can't detect the battery. There's no battery indicator in the top-right corner of the screen, and the settings menu shows 0% under Energy. I installed the PowerSupply app, but all the fields are displaying "N/A." I've checked to ensure the battery is properly seated and that the phone turns on when unplugged. I can't find any information about this issue. Has anyone else experienced this or know what might be causing it?
(01-19-2026, 03:33 AM)shanewilliam Wrote: Hello,
i encountered this issue as well. seems to be software issue. archlinux and mobian are fine.
does audio system work for you?
i had issue with audio in three distributions in pp pro.
I also have this issue. Although annoying, the battery now lasts much longer than ever before (14+ hours). I will take the improved battery life over the battery indicator on the home screen always at 0. My PPP works in every other way. No issues with audio or connectivity. The PPP with PMOS is my daily driver phone, at least for now. I have had the PPP for quite a few years now and it just works for communication (calls and texts), Internet browsing, podcast listening, and Mahjongg.
  pine phone konaphone 2 2,321 10-23-2025, 07:53 AM
Last Post: mikehenson
  Goolge banning Sideloaded APKs in 2026, Year of the really Linux Phone? biketool 1 5,916 08-27-2025, 11:59 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 17,577 03-13-2025, 08:40 PM
Last Post: pcb
  Bluetooth for phone calls Stray 2 3,722 02-25-2025, 12:22 PM
Last Post: Stray
  suggestions for power/battery consumption data logger for community to compare? dchang0 6 6,076 01-02-2025, 09:46 PM
Question Phone call with the pinephone pro dfs 5 11,373 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 5,055 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 24,224 10-27-2023, 12:46 AM
Last Post: gregb49
  PinePhone Pro battery life at the beginning of 2023? dante404 14 23,097 06-03-2023, 07:45 AM
Last Post: crocspot
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 5,334 04-30-2023, 05:03 AM
Last Post: diederik
