Armbian on Quartz64
(11-22-2021, 01:25 AM)balbes150 Wrote: If you (or Pine64 or someone else) provide me with the necessary hardware (samples), I am ready to add CSC level support. If you want to get the "supported device" level, Pine64 needs to contact the Armbian developer community and discuss all the nuances of this work. Smile
PS This applies not only to the Quartz64, but also to other models.
You produced an image for the Station M2. Is your source code available for the M2 ?
Quote: Is your source code available for the M2 ?
yes
yes
Is this the correct one https://github.com/150balbes/build/blob/...ion-m2.wip ?
thanks
Are there people willing to take part in testing the initial test versions of Armbian (CSC) and LibreELEC for quartz64 ?
(01-13-2022, 05:25 AM)balbes150 Wrote: Are there people willing to take part in testing the initial test versions of Armbian (CSC) and LibreELEC for quartz64 ?
I'd be happy to test Armbian for the quartz64. https://users.armbian.com/balbes150/rk35...6.0.img.xz seems to work perfectly for me apart from not picking up the nvme drive.
(01-21-2022, 03:12 PM)mulimoen Wrote: I'd be happy to test Armbian for the quartz64. https://users.armbian.com/balbes150/rk35...6.0.img.xz seems to work perfectly for me apart from not picking up the nvme drive.
Tnx.
Unfortunately, I don't have Quartz64 to test, so all the work is done blindly.
Can you show the UART log of the startup process ?
Have you changed something in the startup settings?
Can you show the output of the commands "fdisk -l" "aplay -l" ?
Here is the boot log:
DDR Version V1.10 20210810 ln ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 72ps, dqs1: -96ps, dqs2: -72ps, dqs3: -168ps, tdqss: cs1 dqs0: 72ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x26 cs 0: the read training result: DQS0:0x37, DQS1:0x31, DQS2:0x39, DQS3:0x30, min  :0x12 0x14 0x17 0x12  0x1  0x8  0x9  0x8 , 0x8  0x8  0x4  0x1  0xf  0xb 0x11  0xa ,       0x14 0x13  0xe  0xc  0x8  0x2  0x4  0x6 ,0x10  0xb  0xc  0x3 0x13 0x12  0xe 0x13 , mid  :0x2d 0x2d 0x31 0x2c 0x1c 0x22 0x23 0x21 ,0x23 0x23 0x1d 0x1a 0x28 0x27 0x29 0x25 ,       0x30 0x2f 0x29 0x28 0x22 0x1c 0x1f 0x20 ,0x29 0x25 0x24 0x1e 0x2c 0x2a 0x28 0x2c , max  :0x48 0x47 0x4b 0x47 0x37 0x3d 0x3e 0x3b ,0x3e 0x3e 0x36 0x34 0x41 0x43 0x42 0x41 ,       0x4d 0x4b 0x44 0x45 0x3d 0x37 0x3a 0x3b ,0x43 0x3f 0x3d 0x39 0x45 0x43 0x43 0x45 , range:0x36 0x33 0x34 0x35 0x36 0x35 0x35 0x33 ,0x36 0x36 0x32 0x33 0x32 0x38 0x31 0x37 ,       0x39 0x38 0x36 0x39 0x35 0x35 0x36 0x35 ,0x33 0x34 0x31 0x36 0x32 0x31 0x35 0x32 , the write training result: DQS0:0x34, DQS1:0x13, DQS2:0x18, DQS3:0x5, min  :0x7f 0x84 0x87 0x85 0x71 0x76 0x78 0x7a 0x7a ,0x52 0x57 0x50 0x50 0x57 0x5a 0x5a 0x59 0x52 ,       0x63 0x64 0x5f 0x5e 0x56 0x52 0x53 0x5a 0x5d ,0x4b 0x4a 0x48 0x44 0x4e 0x4e 0x4c 0x52 0x49 , mid  :0x9a 0x9d 0xa0 0x9c 0x89 0x8d 0x91 0x91 0x90 ,0x6e 0x6d 0x66 0x69 0x70 0x71 0x71 0x72 0x6c ,       0x7f 0x7e 0x76 0x77 0x6f 0x6a 0x6c 0x72 0x76 ,0x66 0x62 0x5f 0x5b 0x67 0x69 0x62 0x6a 0x60 , max  :0xb5 0xb7 0xb9 0xb4 0xa1 0xa5 0xab 0xa9 0xa7 ,0x8a 0x84 0x7d 0x82 0x8a 0x89 0x89 0x8b 0x87 ,       0x9b 0x98 0x8d 0x90 0x89 0x82 0x86 0x8b 0x8f ,0x81 0x7a 0x77 0x73 0x80 0x85 0x79 0x83 0x77 , range:0x36 0x33 0x32 0x2f 0x30 0x2f 0x33 0x2f 0x2d ,0x38 0x2d 0x2d 0x32 0x33 0x2f 0x2f 0x32 0x35 ,       0x38 0x34 0x2e 0x32 0x33 0x30 0x33 0x31 0x32 ,0x36 0x30 0x2f 0x2f 0x32 0x37 0x2d 0x31 0x2e , cs 1: the read training result: DQS0:0x34, DQS1:0x34, DQS2:0x37, DQS3:0x30, min  :0x10 0x12 0x14  0xf  0x2  0x4  0xa  0x4 , 0xb  0x9  0x6  0x2 0x11  0xe 0x12  0xc ,       0x14 0x12  0xe  0xb  0x8  0x1  0x3  0x6 , 0xe  0x8  0xa  0x1 0x11  0xf  0xd 0x11 , mid  :0x2a 0x2b 0x2e 0x2a 0x1c 0x1f 0x23 0x1f ,0x26 0x25 0x20 0x1d 0x2b 0x2a 0x2c 0x28 ,       0x2f 0x2d 0x28 0x27 0x22 0x1c 0x1e 0x20 ,0x28 0x23 0x22 0x1d 0x2b 0x2a 0x27 0x2b , max  :0x45 0x45 0x48 0x46 0x36 0x3b 0x3c 0x3a ,0x41 0x41 0x3a 0x38 0x45 0x46 0x46 0x45 ,       0x4b 0x49 0x43 0x43 0x3d 0x37 0x39 0x3b ,0x42 0x3e 0x3b 0x39 0x45 0x45 0x42 0x45 , range:0x35 0x33 0x34 0x37 0x34 0x37 0x32 0x36 ,0x36 0x38 0x34 0x36 0x34 0x38 0x34 0x39 ,       0x37 0x37 0x35 0x38 0x35 0x36 0x36 0x35 ,0x34 0x36 0x31 0x38 0x34 0x36 0x35 0x34 , the write training result: DQS0:0x34, DQS1:0x13, DQS2:0x18, DQS3:0x5, min  :0x7a 0x82 0x82 0x7c 0x6e 0x71 0x74 0x76 0x76 ,0x55 0x56 0x52 0x52 0x59 0x5a 0x5c 0x5c 0x56 ,       0x65 0x67 0x60 0x60 0x57 0x54 0x56 0x5c 0x5d ,0x55 0x54 0x50 0x4d 0x56 0x58 0x56 0x5b 0x52 , mid  :0x96 0x9a 0x9c 0x97 0x83 0x89 0x8e 0x8e 0x8c ,0x71 0x70 0x6a 0x6a 0x73 0x73 0x74 0x74 0x6f ,       0x81 0x81 0x78 0x79 0x70 0x6b 0x6e 0x74 0x76 ,0x6f 0x6c 0x69 0x64 0x6f 0x72 0x6f 0x74 0x6c , max  :0xb2 0xb3 0xb6 0xb2 0x99 0xa2 0xa8 0xa6 0xa3 ,0x8d 0x8a 0x83 0x83 0x8d 0x8d 0x8d 0x8d 0x89 ,       0x9e 0x9b 0x91 0x93 0x89 0x83 0x87 0x8d 0x8f ,0x8a 0x84 0x82 0x7b 0x89 0x8d 0x88 0x8e 0x86 , range:0x38 0x31 0x34 0x36 0x2b 0x31 0x34 0x30 0x2d ,0x38 0x34 0x31 0x31 0x34 0x33 0x31 0x31 0x33 ,       0x39 0x34 0x31 0x33 0x32 0x2f 0x31 0x31 0x32 ,0x35 0x30 0x32 0x2e 0x33 0x35 0x32 0x33 0x34 , CA Training result: cs:0 min  :0x59 0x62 0x4d 0x49 0x4d 0x49 0x54 ,0x54 0x52 0x4b 0x4b 0x4b 0x45 0x54 , cs:0 mid  :0x97 0x9d 0x89 0x85 0x89 0x85 0x82 ,0x90 0x8e 0x88 0x87 0x86 0x82 0x80 , cs:0 max  :0xd5 0xd8 0xc6 0xc2 0xc5 0xc1 0xb1 ,0xcd 0xcb 0xc6 0xc4 0xc2 0xbf 0xac , cs:0 range:0x7c 0x76 0x79 0x79 0x78 0x78 0x5d ,0x79 0x79 0x7b 0x79 0x77 0x7a 0x58 , cs:1 min  :0x56 0x64 0x49 0x4e 0x4b 0x4e 0x53 ,0x51 0x57 0x4b 0x50 0x4a 0x47 0x51 , cs:1 mid  :0x97 0x9d 0x8a 0x87 0x8a 0x85 0x83 ,0x92 0x91 0x8a 0x87 0x88 0x82 0x81 , cs:1 max  :0xd9 0xd7 0xcb 0xc1 0xca 0xbd 0xb3 ,0xd4 0xcb 0xc9 0xbf 0xc6 0xbd 0xb1 , cs:1 range:0x83 0x73 0x82 0x73 0x7f 0x6f 0x60 ,0x83 0x74 0x7e 0x6f 0x7c 0x76 0x60 , out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Jan 08 2022 - 14:45:06) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(5938a9cdfc...) + OK ## Checking uboot 0x00a00000 ... sha256(641fb675b2...) + OK ## Checking fdt 0x00b204f8 ... sha256(74e6edd8a8...) + OK ## Checking atf-2 0x00068000 ... sha256(0965dc8022...) + OK ## Checking atf-3 0xfdcd0000 ... sha256(be991af043...) + OK ## Checking atf-4 0xfdcc9000 ... sha256(695349eb36...) + OK ## Checking atf-5 0x00066000 ... sha256(315a4195a9...) + OK ## Checking optee 0x08400000 ... sha256(b8cddafab0...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 256.502 ms INFO:    Preloader serial: 2 NOTICE:  BL31: v2.3():v2.3-167-g81e0b993a-dirty:xsf NOTICE:  BL31: Built : 11:20:08, Sep  6 2021 INFO:    GICv3 without legacy support detected. INFO:    ARM GICv3 driver initialized in EL3 INFO:    pmu v1 is valid INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    BL31: Initializing runtime services INFO:    BL31: Initializing BL32 I/TC: I/TC: Start rockchip platform init I/TC: Rockchip release version: 1.0 I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May  7 01:52:27 UTC 2021 aarch64 I/TC: Initialized INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0xa00000 INFO:    SPSR = 0x3c9 U-Boot 2017.09-armbian (Jan 08 2022 - 14:45:06 +0300) Model: Firefly RK3566 Board PreSerial: 2, raw, 0xfe660000 DRAM:  7.7 GiB Sysmem: init Relocation Offset: ed358000 Relocation fdt: eb9f81d0 - eb9fecd8 CR: M/C/I Using default environment no mmc device at slot 1 dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition No resource partition No resource partition Failed to load DTB, ret=-19 Failed to get kernel dtb, ret=-19 io-domain: OK Model: Firefly RK3566 Board rockchip_set_serialno: could not nc kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)   apll 816000 KHz   dpll 780000 KHz   gpll 1188000 KHz   cpll 1000000 KHz   npll 24000 KHz   vpll 24000 KHz   hpll 24000 KHz   ppll 100000 KHz   armclk 816000 KHz   aclk_bus 150000 KHz   pclk_bus 50000 KHz   aclk_top_high 300000 KHz   aclk_top_low 200000 KHz   hclk_top 150000 KHz   pclk_top 50000 KHz   aclk_perimid 300000 KHz   hclk_perimid 150000 KHz   pclk_pmu 50000 KHz Net:   No ethernet found. Hit key to stop autoboot('Cnge FIT: No boot partition FIT: No FIT image Could not find misc partition ANDROID: reboot reason: "(none)" optee api revision: 2.0 TEEC: Waring: Could not  images, AVB skip android_image_load_by_partname: Can't find part: boot Android image load failed Android boot failed, error -1. starting USB... Bus dwc3@fcc00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found        scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 340 bytes read in 14 ms (23.4 KiB/s) 1: Armbian Retrieving file: /boot/uInitrd 14039021 bytes read in 1204 ms (11.1 MiB/s) Retrieving file: /boot/Image 34912768 bytes read in 2943 ms (11.3 MiB/s) append: root=UUID=c22eb3a0-f780-48c9-adb5-37954715ba19 console=ttyS02,1500000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian Retrieving file: /boot/dtb/rockchip/rk3566-quartz64-a.dtb 105527 bytes read in 84 ms (1.2 MiB/s) Fdt Ramdisk skip relocation sacy Image at 0a200000 ...    Image Name:   uInitrd    Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)    Data Size:    14038957 Bytes = 13.4 MiB    Load Address: 00000000    Entry Point:  00000000    Verifying Checksum ... OK ## Flattened Device Tree blob at 0x0a100000    Booting using the fdt blob at 0x0a100000    Using Device Tree in place at 000000000a100000, end 000000000a11cc36 can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Total: 8109.608 ms Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux version 5.16.0-rc8-media (root@vbox) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP PREEMPT Sat Jan 8 10:58:33 MSK 2022 [    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board [    0.000000] efi: UEFI not found. [    0.000000] NUMA: No NUMA configuration found [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] NUMA: NODE_DATA [mem 0x1feff8a40-0x1feffafff] [    0.000000] Zone ranges: [    0.000000]   DMA      [mem 0x0000000000200000-0x00000000ffffffff] [    0.000000]   DMA32    empty [    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Movable zone start for each node [    0.000000] Early memory node ranges [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff] [    0.000000]   node   0: [mem 0x0000000009400000-0x00000000efffffff] [    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges [    0.000000] cma: Reserved 384 MiB at 0x00000000d8000000 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.1 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: Trusted OS migration not required [    0.000000] psci: SMC Calling Convention v1.2 [    0.000000] percpu: Embedded 30 pages/cpu s82200 r8192 d32488 u122880 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] CPU features: detected: Virtualization Host Extensions [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [    0.000000] alternatives: patching kernel code [    0.000000] Fallback order for Node 0: 0 [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1995336 [    0.000000] Policy zone: Normal [    0.000000] Kernel command line: root=UUID=c22eb3a0-f780-48c9-adb5-37954715ba19 console=ttyS02,1500000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [    0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB) [    0.000000] Memory: 7443592K/8108032K available (17984K kernel code, 3310K rwdata, 7828K rodata, 4864K init, 771K bss, 271224K reserved, 393216K cma-reserved) [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x180 with crng_init=0 [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] trace event string verifier disabled [    0.000000] rcu: Preemptible hierarchical RCU implementation. [    0.000000] rcu: RCU event tracing is enabled. [    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [    0.000000] Trampoline variant of Tasks RCU enabled. [    0.000000] Rude variant of Tasks RCU enabled. [    0.000000] Tracing variant of Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 320 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] GICv3: MBI range [296:319] [    0.000000] GICv3: Using MBI frame 0x00000000fd410000 [    0.000000] Root IRQ handler: gic_handle_irq [    0.000000] GICv3: 16 PPIs implemented [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    0.000000] ITS: No ITS available, not enabling LPIs [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.002005] Console: colour dummy device 80x25 [    0.002771] printk: console [tty0] enabled [    0.002927] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [    0.002972] pid_max: default: 32768 minimum: 301 [    0.003154] LSM: Security Framework initializing [    0.003212] Yama: becoming mindful. [    0.003364] AppArmor: AppArmor initialized [    0.003554] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.003628] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.006916] rcu: Hierarchical SRCU implementation. [    0.013637] EFI services will not be available. [    0.014322] smp: Bringing up secondary CPUs ... [    0.015464] Detected VIPT I-cache on CPU1 [    0.015518] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    0.015591] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    0.016919] Detected VIPT I-cache on CPU2 [    0.016969] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    0.017028] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    0.018267] Detected VIPT I-cache on CPU3 [    0.018314] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [    0.018371] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [    0.018563] smp: Brought up 1 node, 4 CPUs [    0.018707] SMP: Total of 4 processors activated. [    0.018727] CPU features: detected: 32-bit EL0 Support [    0.018743] CPU features: detected: 32-bit EL1 Support [    0.018762] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [    0.018786] CPU features: detected: Common not Private translations [    0.018803] CPU features: detected: CRC32 instructions [    0.018821] CPU features: detected: RCpc load-acquire (LDAPR) [    0.018837] CPU features: detected: LSE atomic instructions [    0.018854] CPU features: detected: Privileged Access Never [    0.018870] CPU features: detected: RAS Extension Support [    0.018889] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [    0.062092] CPU: All CPU(s) started at EL2 [    0.066546] devtmpfs: initialized [    0.092415] Registered cp15_barrier emulation handler [    0.092475] Registered setend emulation handler [    0.092507] KASLR disabled due to lack of seed [    0.092878] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [    0.092950] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [    0.104914] pinctrl core: initialized pinctrl subsystem [    0.106013] DMI not present or invalid. [    0.106798] NET: Registered PF_NETLINK/PF_ROUTE protocol family [    0.110832] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [    0.112034] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [    0.114358] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [    0.114543] audit: initializing netlink subsys (disabled) [    0.114925] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=0 res=1 [    0.117638] thermal_sys: Registered thermal governor 'fair_share' [    0.117656] thermal_sys: Registered thermal governor 'bang_bang' [    0.117688] thermal_sys: Registered thermal governor 'step_wise' [    0.117707] thermal_sys: Registered thermal governor 'user_space' [    0.117726] thermal_sys: Registered thermal governor 'power_allocator' [    0.118640] cpuidle: using governor ladder [    0.118723] cpuidle: using governor menu [    0.119307] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.119546] ASID allocator initialised with 65536 entries [    0.121681] Serial: AMBA PL011 UART driver [    0.140637] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop [    0.184196] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [    0.185263] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [    0.186401] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [    0.187467] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [    0.188498] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [    0.191278] platform hdmi-con: Fixing up cyclic dependency with fe0a0000.hdmi [    0.220007] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [    0.220059] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [    0.220082] HugeTLB registered 2.00 MiB page s1 0 pages [    0.220103] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [    0.221229] cryptd: max_cpu_qlen set to 1000 [    0.289438] raid6: neonx8   gen()  1372 MB/s [    0.357615] raid6: neonx8   xor()  1081 MB/s [    0.425801] raid6: neonx4   gen()  1398 MB/s [    0.493956] raid6: neonx4   xor()  1073 MB/s [    0.562169] raid6: neonx2   gen()  1280 MB/s [    0.630343] raid6: neonx2   xor()   985 MB/s [    0.698585] raid6: neonx1   gen()  1055 MB/s [    0.766716] raid6: neonx1   xor()   833 MB/s [    0.835034] raid6: int64x8  gen()  1015 MB/s [    0.903122] raid6: int64x8  xor()   528 MB/s [    0.971324] raid6: int64x4  gen()  1078 MB/s [    1.039502] raid6: int64x4  xor()   569 MB/s [    1.107739] raid6: int64x2  gen()   962 MB/s [    1.175868] raid6: int64x2  xor()   514 MB/s [    1.244107] raid6: int64x1  gen()   694 MB/s [    1.312269] raid6: int64x1  xor()   381 MB/s [    1.312293] raid6: using algorithm neonx4 gen() 1398 MB/s [    1.312313] raid6: .... xor() 1073 MB/s, rmw enabled [    1.312330] raid6: using neon recovery algorithm [    1.313603] ACPI: Interpreter disabled. [    1.318235] iommu: Default domain type: Translated [    1.318275] iommu: DMA domain TLB invalidation policy: strict mode [    1.319507] vgaarb: loaded [    1.320274] SCSI subsystem initialized [    1.321075] usbcore: registered new interface driver usbfs [    1.321177] usbcore: registered new interface driver hub [    1.321253] usbcore: registered new device driver usb [    1.322108] pps_core: LinuxPPS API ver. 1 registered [    1.322135] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    1.322183] PTP clock support registered [    1.322548] EDAC MC: Ver: 3.0.0 [    1.324162] FPGA manager framework [    1.324411] Advanced Linux Sound Architecture Driver Initialized. [    1.325479] NetLabel: Initializing [    1.325504] NetLabel:  domain hash size = 128 [    1.325521] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO [    1.325671] NetLabel:  unlabeled traffic allowed by default [    1.326902] clocksource: Switched to clocksource arch_sys_counter [    1.406505] VFS: Disk quotas dquot_6.6.0 [    1.406652] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    1.407896] AppArmor: AppArmor Filesystem Enabled [    1.408032] pnp: PnP ACPI: disabled [    1.422689] NET: Registered PF_INET protocol family [    1.423289] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [    1.427774] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [    1.428159] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [    1.429033] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [    1.429980] TCP: Hash tables configured (established 65536 bind 65536) [    1.430230] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [    1.430449] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [    1.430873] NET: Registered PF_UNIX/PF_LOCAL protocol family [    1.430974] NET: Registered PF_XDP protocol family [    1.431009] PCI: CLS 0 bytes, default 64 [    1.431452] Trying to unpack rootfs image as initramfs... [    1.440200] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [    1.441007] kvm [1]: IPA Size Limit: 40 bits [    1.441058] kvm [1]: GICv3: no GICV resource entry [    1.441080] kvm [1]: disabling GICv2 emulation [    1.441117] kvm [1]: GIC system register CPU interface enabled [    1.441356] kvm [1]: vgic interrupt IRQ9 [    1.441670] kvm [1]: VHE mode initialized successfully [    1.444968] Initialise system trusted keyrings [    1.445063] Key type blacklist registered [    1.445493] workingset: timestamp_bits=42 max_order=21 bucket_order=0 [    1.455201] zbud: lo ersion 4.0 (2009/01/31) Phillip Lougher [    1.462716] integrity: Platform Keyring initialized [    1.514163] xor: measuring software checksum speed [    1.520548]    8regs           :  1569 MB/sec [    1.525569]    32regs          :  1985 MB/sec [    1.532303]    arm64_neon      :  1480 MB/sec [    1.532337] xor: using function: 32regs (1985 MB/sec) [    1.532367] Key type asymmetric registered [    1.532385] Asymmetric key parser 'x509' registered [    1.532713] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [    1.533092] io scheduler mq-deadline registered [    1.533122] io scheduler kyber registered [    1.533481] io scheduler bfq registered [    1.555172] EINJ: ACPI disabled. [    1.564556] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [    1.564612] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    1.568249] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [    1.568306] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    1.581619] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [    1.585868] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 23, base_baud = 1500000) is a 16550A [    1.587919] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 41, base_baud = 1500000) is a 16550A [    1.588217] serial serial0: tty port ttyS1 registered [    1.589859] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 42, base_baud = 1500000) is a 16550A [    1.702910] printk: console [ttyS2] enabled [    1.705144] Serial: AMBA driver [    1.709465] rockchip-vop2 fe040000.vop: Adding to iommu group 0 [    1.717113] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    1.732968] brd: module loaded [    1.745352] loop: module loaded [    1.747979] Loading iSCSI transport class v2.0-870. [    1.749605] iscsi: registered transport (tcp) [    1.750031] megasas: 07.719.03.00-rc1 [    1.759043] libphy: Fixed MDIO Bus: probed [    1.762474] thunder_xcv, ver 1.0 [    1.762955] thunder_bgx, ver 1.0 [    1.763337] nicpf, ver 1.0 [    1.764910] hclge is initializing [    1.765251] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [    1.765907] hns3: Copyright (c) 2017 Huawei Corporation. [    1.766523] igb: Intel(R) Gigabit Ethernet Network Driver [    1.767052] igb: Copyright (c) 2007-2014 Intel Corporation. [    1.767661] igbvf: Intel(R) Gigabit Virtual Function Network Driver [    1.768230] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [    1.769230] sky2: driver version 1.30 [    1.771737] VFIO - User Level meta-driver version: 0.3 [    1.775618] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    1.776258] ehci-pci: EHCI PCI platform driver [    1.776744] ehci-platform: EHCI generic platform driver [    1.779853] ehci-platform fd800000.usb: EHCI Host Controller [    1.780423] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [    1.781343] ehci-platform fd800000.usb: irq 18, io mem 0xfd800000 [    1.795023] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [    1.796079] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [    1.796843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.797498] usb usb1: Product: EHCI Host Controller [    1.797943] usb usb1: Manufacturer: Linux 5.16.0-rc8-media ehci_hcd [    1.798509] usb usb1: SerialNumber: fd800000.usb [    1.799836] hub 1-0:1.0: USB hub found [    1.800255] hub 1-0:1.0: 1 port detected [    1.803727] ehci-platform fd880000.usb: EHCI Host Controller [    1.804325] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [    1.805273] ehci-platform fd880000.usb: irq 20, io mem 0xfd880000 [    1.819008] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [    1.820013] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [    1.820778] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.821433] usb usb2: Product: EHCI Host Controller [    1.821879] usb usb2: Manufacturer: Linux 5.16.0-rc8-media ehci_hcd [    1.822444] usb usb2: SerialNumber: fd880000.usb [    1.823778] hub 2-0:1.0: USB hub found [    1.824214] hub 2-0:1.0: 1 port detected [    1.825553] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    1.826155] ohci-pci: OHCI PCI platform driver [    1.826679] ohci-platform: OHCI generic platform driver [    1.827808] ohci-platform fd840000.usb: Generic Platform OHCI controller [    1.828451] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [    1.829379] ohci-platform fd840000.usb: irq 19, io mem 0xfd840000 [    1.891304] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [    1.892081] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.892739] usb usb3: Product: Generic Platform OHCI controller [    1.893276] usb usb3: Manufacturer: Linux 5.16.0-rc8-media ohci_hcd [    1.893841] usb usb3: SerialNumber: fd840000.usb [    1.895147] hub 3-0:1.0: USB hub found [    1.895587] hub 3-0:1.0: 1 portelatform fd8c0000.usb: Generic Platform OHCI controller [    1.897636] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [    1.898557] ohci-platform fd8c0000.usb: irq 21, io mem 0xfd8c0000 [    1.963295] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [    1.964074] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.964732] usb usb4: Product: Generic Platform OHCI controller [    1.965268] usb usb4: Manufacturer: Linux 5.16.0-rc8-media ohci_hcd [    1.965833] usb usb4: SerialNumber: fd8c0000.usb [    1.967161] hub 4-0:1.0: USB hub found [    1.967584] hub 4-0:1.0: 1 port detected [    1.970292] usbcore: registered new interface driver usb-storage [    1.974228] mousedev: PS/2 mouse device common for all mice [    1.977208] i2c_dev: i2c /dev entries driver [    1.980416] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [    1.990220] Freeing initrd memory: 13704K [    1.991801] rk808 0-0020: chip id: 0x8170 [    2.027237] random: fast init done [    2.038005] rk808-regulator rk808-regulator: there is no dvs0 gpio [    2.038609] rk808-regulator rk808-regulator: there is no dvs1 gpio [    2.039235] rk808-regulator rk808-regulator: max buck steps per change: 8 [    2.055108] vcc_ddr: Bringing 500000uV into 1100000-1100000uV [    2.085630] vccio_acodec: Bringing 1800000uV into 3300000-3300000uV [    2.114349] vcc2v8_dvp: Bringing 1800000uV into 2800000-2800000uV [    2.121994] boost: Bringing 4700000uV into 5000000-5000000uV [    2.137553] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0 [    2.151239] rk808-rtc rk808-rtc: registered as rtc0 [    2.154438] rk808-rtc rk808-rtc: setting system clock to 2022-01-22T09:03:13 UTC (1642842193) [    2.169419] sdhci: Secure Digital Host Controller Interface driver [    2.170004] sdhci: Copyright(c) Pierre Ossman [    2.171379] Synopsys Designware Multimedia Card Interface Driver [    2.173955] sdhci-pltfm: SDHCI platform and OF driver helper [    2.177793] ledtrig-cpu: registered to indicate activity on CPUs [    2.179646] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd [    2.180753] hid: raw HID events driver (C) Jiri Kosina [    2.181705] usbcore: registered new interface driver usbhid [    2.182217] usbhid: USB HID core driver [    2.194564] NET: Registered PF_INET6 protocol family [    2.247793] Segment Routing with IPv6 [    2.248221] In-situ OAM (IOAM) with IPv6 [    2.248707] NET: Registered PF_PACKET protocol family [    2.249411] 8021q: 802.1Q VLAN Support v1.8 [    2.249880] Key type dns_resolver registered [    2.251915] registered taskstats version 1 [    2.252315] Loading compiled-in X.509 certificates [    2.257387] Loaded X.509 cert 'Build time autogenerated kernel key: 3490074eafa2d3b2c7b4d4c40b3f4b2753ecfa14' [    2.262950] zswap: loaded using pool zstd/z3fold [    2.264920] Key type ._fscrypt registered [    2.265300] Key type .fscrypt registered [    2.265659] Key type fscrypt-provisioning registered [    2.269521] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [    2.270700] Key type encrypted registered [    2.271143] AppArmor: AppArmor sha1 policy hashing enabled [    2.271711] ima: No TPM chip found, activating TPM-bypass! [    2.272242] ima: Allocated hash algorithm: sha1 [    2.272699] ima: No architecture policies found [    2.273207] evm: Initialising EVM extended attributes: [    2.273675] evm: security.selinux [    2.273982] evm: security.SMACK64 [    2.274287] evm: security.SMACK64EXEC [    2.274619] evm: security.SMACK64TRANSMUTE [    2.275049] evm: security.SMACK64MMAP [    2.275389] evm: security.apparmor [    2.275701] evm: security.ima [    2.275974] evm: security.capability [    2.276300] evm: HMAC attrs: 0x1 [    2.367523] vop2_create_crtc: No remote for vp1 [    2.368000] vop2_create_crtc: No remote for vp2 [    2.368616] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops) [    2.371253] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [    2.373056] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [    2.376068] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops) [    2.377162] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [    2.378520] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [    2.381749] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [    2.383376] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [    2.384033] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30). [    2.384552] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10). [    2.385079] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [    2.385738] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [    2.391309] rk_gmac-dwmac fe010000.ethernet: init for RGMII [    2.392182] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [    2.392844] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [    2.393317] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [    2.393992] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [    2.394665] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [    2.395338] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [    2.396019] rk_gmac-dwmac fe010000.ethernet: TSO supported [    2.396523] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [    2.397247] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=8) [    2.397887] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [    2.398431] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width [    2.534929] libphy: stmmac: probed [    2.554729] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [    2.555462] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [    2.556084] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [    2.556115] printk: console [netcon0] enabled [    2.556687] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo [    2.556994] netconsole: network logging started [    2.558767] psci_checker: PSCI checker started using 4 CPUs [    2.559057] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [    2.559328] psci_checker: Starting hotplug tests [    2.560161] psci_checker: Trying to turn off and on again all CPUs [    2.561465] psci: CPU0 killed (polled 0 ms) [    2.565379] psci: CPU1 killed (polled 0 ms) [    2.569509] psci: CPU2 killed (polled 0 ms) [    2.571554] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    2.574687] Detected VIPT I-cache on CPU0 [    2.575118] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    2.575821] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]-cache on CPU1 [    2.579328] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    2.580046] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    2.583807] Detected VIPT I-cache on CPU2 [    2.584235] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    2.584948] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    2.587859] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3) [    2.589091] psci: CPU0 killed (polled 0 ms) [    2.592598] psci: CPU1 killed (polled 0 ms) [    2.595889] psci: CPU2 killed (polled 0 ms) [    2.599281] Detected VIPT I-cache on CPU0 [    2.599711] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    2.600412] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [    2.603926] Detected VIPT I-cache on CPU1 [    2.604354] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    2.605071] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    2.608528] Detected VIPT I-cache on CPU2 [    2.608962] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    2.609681] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    2.612613] psci_checker: Hotplug tests passed OK [    2.613058] psci_checker: Starting suspend tests (10 cycles per state) [    2.613707] psci_checker: cpuidle not available on CPU 0, ignoring [    2.614271] psci_checker: cpuidle not available on CPU 1, ignoring [    2.614851] psci_checker: cpuidle not available on CPU 2, ignoring [    2.615491] psci_checker: cpuidle not available on CPU 3, ignoring [    2.616081] psci_checker: Could not start suspend tests on any CPU [    2.616665] psci_checker: PSCI checker completed [    2.617111] of_cfs_init [    2.617388] of_cfs_init: OK [    2.620790] ALSA device list: [    2.621112]   No soundcards found. [    2.624015] Freeing v  2.625157] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [    2.626178] mmc0: new high speed SDHC card at address 0001 [    2.628204] mmcblk0: mmc0:0001 SD32G 29.1 GiB [    2.635094] Run /init as init process [    2.640413]  mmcblk0: p1 [    3.395104] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [    3.710976] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [    4.571366] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: data=writeback. Quota mode: none. [    5.532143] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified) [    5.536895] systemd[1]: Detected architecture arm64. [    5.563938] systemd[1]: Set hostname to <lenestol>. [    5.763633] dw-apb-uart fe660000.serial: forbid DMA for kernel console [    6.593597] systemd[1]: Queued start job for default target Graphical Interface. [    6.596377] random: systemd: uninitialized urandom read (16 bytes read) [    6.622004] systemd[1]: Created slice system-getty.slice. [    6.623394] random: systemd: uninitialized urandom read (16 bytes read) [    6.627809] systemd[1]: Created slice system-modprobe.slice. [    6.628817] random: systemd: uninitialized urandom read (16 bytes read) [    6.633472] systemd[1]: Created slice system-serial\x2dgetty.slice. [    6.637669] systemd[1]: Created slice User and Session Slice. [    6.638716] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [    6.640657] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [    6.643317] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [    6.644880] systemd[1]: Reached target Local Encrypted Volumes. [    6.646109] systemd[1]: Reached target Paths. [    6.647098] systemd[1]: Reached target Slices. [    6.647946] systemd[1]: Reached target Swap. [    6.648774] systemd[1]: Reached target System Time Set. [    6.676088] systemd[1]: Listening on RPCbind Server Activation Socket. [    6.678399] systemd[1]: Listening on Syslog Socket. [    6.680473] systemd[1]: Listening on fsck to fsckd communication Socket. [    6.681973] systemd[1]: Listening on initctl Compatibility Named Pipe. [    6.684281] systemd[1]: Listening on Journal Audit Socket. [    6.686138] systemd[1]: Listening on Journal Socket (/dev/log). [    6.688502] systemd[1]: Listening on Journal Socket. [    6.698585] systemd[1]: Listening on udev Control Socket. [    6.700674] systemd[1]: Listening on udev Kernel Socket. [    6.709728] systemd[1]: Mounting Huge Pages File System... [    6.719956] systemd[1]: Mounting POSIX Message Queue File System... [    6.729306] systemd[1]: Mounting RPC Pipe File System... [    6.739578] systemd[1]: Mounting Kernel Debug File System... [    6.749717] systemd[1]: Mounting Kernel Trace File System... [    6.751775] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [    6.763580] systemd[1]: Starting Restore / save the current clock... [    6.773803] systemd[1]: Starting Set the console keyboard layout... [    6.784307] systemd[1]: Starting Create list of static device nodes for the current kernel... [    6.797534] systemd[1]: Starting Load Kernel Module configfs... [    6.807263] systemd[1]: Starting Load Kernel Module drm... [    6.822737] systemd[1]: Starting Load Kernel Module fuse... [    6.839584] systemd[1]: Started Nameserver information manager. [    6.841862] systemd[1]: Reached target Network (Pre). [    6.848164] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [    6.849341] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [    6.864694] systemd[1]: Starting Load Kernel Modules... [    6.875533] systemd[1]: Starting Remount Root and Kernel File Systems... [    6.889793] systemd[1]: Starting Coldplug All udev Devices... [    6.912261] systemd[1]: Mounted Huge Pages File System. [    6.914139] systemd[1]: Mounted POSIX Message Queue File System. [    6.920296] systemd[1]: Mounted Kernel Debug File System. [    6.922383] systemd[1]: Mounted Kernel Trace File System. [    6.928399] systemd[1]: Finished Restore / save the current clock. [    6.936899] fuse: init (API version 7.35) [    6.938261] systemd[1]: Finished Create list of static device nodes for the current kernel. [    6.942338] systemd[1]: modprobe@configfs.service: Succeeded. [    6.945175] RPC: Registered named UNIX socket transport module. [    6.945750] RPC: Registered udp transport module. [    6.946095] systemd[1]: Finished Load Kernel Module configfs. [    6.946181] RPC: Registered tcp transport module. [    6.946188] RPC: Registered tcp NFSv4.1 backchannel transport module. [    6.956445] systemd[1]: modprobe@drm.service: Succeeded. [    6.960149] systemd[1]: Finished Load Kernel Module drm. [    6.983862] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [    6.995565] systemd[1]: Mounted RPC Pipe File System. [    6.999778] systemd[1]: modprobe@fuse.service: Succeeded. [    7.002573] systemd[1]: Finished Load Kernel Module fuse. [    7.010764] systemd[1]: Finished Load Kernel Modules. [    7.015588] systemd[1]: Finished Remount Root and Kernel File Systems. [    7.026249] systemd[1]: Mounting FUSE Control File System... [    7.035659] systemd[1]: Mounting Kernel Configuration File System... [    7.041823] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [    7.043209] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [    7.052727] systemd[1]: Starting Load/Save Random Seed... [    7.062051] systemd[1]: Starting Apply Kernel Variables... [    7.078717] systemd[1]: Starting Create System Users... [    7.087922] systemd[1]: Mounted FUSE Control File System. [    7.089791] systemd[1]: Mounted Kernel Configuration File System. Armbian 22.02.0-trunk Bullseye ttyS2 lenestol login:
Here is the output of aplay -l
**** List of PLAYBACK Hardware Devices **** card 0: HDMI [HDMI], device 0: fe400000.i2s-i2s-hifi i2s-hifi-0 [fe400000.i2s-i2s-hifi i2s-hifi-0]   Subdevices: 1/1   Subdevice #0: subdevice #0 card 1: RK817 [Analog RK817], device 0: fe410000.i2s-rk817-hifi rk817-hifi-0 [fe410000.i2s-rk817-hifi rk817-hifi-0]   Subdevices: 1/1   Subdevice #0: subdevice #0 card 2: SPDIF [SPDIF], device 0: fe460000.spdif-dit-hifi dit-hifi-0 [fe460000.spdif-dit-hifi dit-hifi-0]   Subdevices: 1/1   Subdevice #0: subdevice #0
And the output of fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 29.12 GiB, 31267487744 bytes, 61069312 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: CE161589-0136-441A-B356-7B3EA133A022 Device         Start      End  Sectors  Size Type /dev/mmcblk0p1 32768 60456959 60424192 28.8G Linux filesystem Disk /dev/zram0: 3.75 GiB, 4021952512 bytes, 981922 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes
The only change I've made is to extlinux.conf to use the quartz device tree.
Quote:Here is the boot log:
Tnx
(01-22-2022, 03:23 AM)mulimoen Wrote: Here is the boot log:
Can you check the launch of a new version that uses the new version of the main u-boot-2022 and show the output of the UART console? It is advisable to check the version with XFCE and check the operation of audio devices (try to run a test video file).
https://disk.yandex.ru/d/xMVoaZXFFcWuog
(01-23-2022, 06:30 AM)balbes150 Wrote: Can you check the launch of a new version that uses the new version of the main u-boot-2022 and show the output of the UART console?
Here you go:
DDR Version V1.10 20210810 ln ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: 72ps, dqs1: -96ps, dqs2: -72ps, dqs3: -168ps, tdqss: cs1 dqs0: 72ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x26 cs 0: the read training result: DQS0:0x37, DQS1:0x31, DQS2:0x38, DQS3:0x30, min  :0x12 0x14 0x18 0x12  0x1  0x8  0x9  0x8 , 0x9  0x8  0x4  0x1  0xf  0xc 0x11  0xa ,       0x14 0x12  0xe  0xb  0x8  0x0  0x4  0x5 ,0x11  0xb  0xc  0x3 0x13 0x11  0xf 0x13 , mid  :0x2d 0x2d 0x31 0x2c 0x1c 0x22 0x23 0x21 ,0x23 0x23 0x1d 0x1b 0x28 0x27 0x29 0x25 ,       0x30 0x2e 0x28 0x27 0x22 0x1b 0x1e 0x20 ,0x2a 0x25 0x24 0x1e 0x2c 0x2a 0x28 0x2c , max  :0x48 0x47 0x4b 0x47 0x37 0x3d 0x3e 0x3b ,0x3e 0x3e 0x36 0x35 0x41 0x43 0x42 0x41 ,       0x4d 0x4b 0x43 0x44 0x3d 0x37 0x39 0x3b ,0x43 0x3f 0x3d 0x39 0x46 0x43 0x42 0x46 , range:0x36 0x33 0x33 0x35 0x36 0x35 0x35 0x33 ,0x35 0x36 0x32 0x34 0x32 0x37 0x31 0x37 ,       0x39 0x39 0x35 0x39 0x35 0x37 0x35 0x36 ,0x32 0x34 0x31 0x36 0x33 0x32 0x33 0x33 , the write training result: DQS0:0x34, DQS1:0x13, DQS2:0x18, DQS3:0x5, min  :0x7f 0x84 0x87 0x85 0x71 0x76 0x79 0x7a 0x7a ,0x52 0x57 0x50 0x50 0x58 0x5a 0x5a 0x59 0x52 ,       0x64 0x64 0x5f 0x5f 0x56 0x52 0x53 0x5a 0x5d ,0x4b 0x4a 0x48 0x44 0x4e 0x4e 0x4c 0x52 0x4a , mid  :0x9a 0x9d 0xa0 0x9c 0x89 0x8d 0x91 0x92 0x90 ,0x6e 0x6d 0x68 0x69 0x71 0x71 0x71 0x71 0x6c ,       0x7f 0x7d 0x76 0x78 0x6f 0x6a 0x6c 0x72 0x76 ,0x66 0x62 0x5f 0x5b 0x67 0x69 0x63 0x6a 0x60 , max  :0xb5 0xb7 0xb9 0xb3 0xa1 0xa5 0xaa 0xaa 0xa7 ,0x8a 0x84 0x80 0x82 0x8a 0x89 0x89 0x8a 0x87 ,       0x9b 0x97 0x8d 0x91 0x89 0x82 0x86 0x8b 0x8f ,0x81 0x7a 0x77 0x73 0x81 0x85 0x7b 0x83 0x77 , range:0x36 0x33 0x32 0x2e 0x30 0x2f 0x31 0x30 0x2d ,0x38 0x2d 0x30 0x32 0x32 0x2f 0x2f 0x31 0x35 ,       0x37 0x33 0x2e 0x32 0x33 0x30 0x33 0x31 0x32 ,0x36 0x30 0x2f 0x2f 0x33 0x37 0x2f 0x31 0x2d , cs 1: the read training result: DQS0:0x34, DQS1:0x33, DQS2:0x37, DQS3:0x30, min  :0x10 0x11 0x14  0xf  0x2  0x4  0xa  0x3 , 0xa  0x8  0x5  0x1  0xe  0xc 0x11  0xb ,       0x14 0x12  0xe  0xc  0x8  0x0  0x3  0x6 , 0xe  0x8  0xa  0x1 0x11  0xf  0xe 0x11 , mid  :0x2a 0x2b 0x2e 0x2a 0x1c 0x1f 0x22 0x1e ,0x24 0x24 0x1f 0x1b 0x28 0x28 0x2b 0x27 ,       0x30 0x2d 0x28 0x27 0x22 0x1b 0x1e 0x20 ,0x28 0x23 0x22 0x1d 0x2b 0x29 0x28 0x2b , max  :0x45 0x45 0x48 0x45 0x36 0x3b 0x3b 0x3a ,0x3f 0x40 0x39 0x36 0x43 0x44 0x45 0x43 ,       0x4c 0x49 0x43 0x43 0x3d 0x37 0x39 0x3b ,0x42 0x3e 0x3b 0x39 0x45 0x44 0x42 0x45 , range:0x35 0x34 0x34 0x36 0x34 0x37 0x31 0x37 ,0x35 0x38 0x34 0x35 0x35 0x38 0x34 0x38 ,       0x38 0x37 0x35 0x37 0x35 0x37 0x36 0x35 ,0x34 0x36 0x31 0x38 0x34 0x35 0x34 0x34 , the write training result: DQS0:0x34, DQS1:0x13, DQS2:0x18, DQS3:0x5, min  :0x7b 0x82 0x82 0x7d 0x6e 0x71 0x74 0x76 0x75 ,0x56 0x56 0x52 0x52 0x59 0x5b 0x5c 0x5c 0x56 ,       0x65 0x67 0x60 0x60 0x57 0x54 0x56 0x5c 0x5d ,0x56 0x54 0x50 0x4d 0x57 0x58 0x56 0x5b 0x52 , mid  :0x96 0x9a 0x9c 0x97 0x83 0x89 0x8d 0x8e 0x8c ,0x71 0x70 0x6a 0x6a 0x73 0x74 0x74 0x74 0x6f ,       0x81 0x81 0x78 0x7a 0x70 0x6b 0x6e 0x74 0x76 ,0x70 0x6c 0x69 0x64 0x70 0x72 0x6f 0x75 0x6b , max  :0xb2 0xb3 0xb6 0xb2 0x98 0xa2 0xa7 0xa7 0xa3 ,0x8d 0x8a 0x82 0x83 0x8d 0x8d 0x8d 0x8d 0x89 ,       0x9e 0x9b 0x91 0x94 0x8a 0x83 0x87 0x8d 0x8f ,0x8a 0x85 0x82 0x7b 0x89 0x8d 0x88 0x8f 0x85 , range:0x37 0x31 0x34 0x35 0x2a 0x31 0x33 0x31 0x2e ,0x37 0x34 0x30 0x31 0x34 0x32 0x31 0x31 0x33 ,       0x39 0x34 0x31 0x34 0x33 0x2f 0x31 0x31 0x32 ,0x34 0x31 0x32 0x2e 0x32 0x35 0x32 0x34 0x33 , CA Training result: cs:0 min  :0x58 0x5f 0x4d 0x48 0x4e 0x48 0x54 ,0x53 0x50 0x4b 0x4b 0x4b 0x45 0x53 , cs:0 mid  :0x96 0x9b 0x89 0x85 0x89 0x84 0x82 ,0x90 0x8d 0x88 0x87 0x86 0x82 0x80 , cs:0 max  :0xd5 0xd7 0xc6 0xc2 0xc5 0xc1 0xb1 ,0xcd 0xcb 0xc6 0xc3 0xc1 0xbf 0xad , cs:0 range:0x7d 0x78 0x79 0x7a 0x77 0x79 0x5d ,0x7a 0x7b 0x7b 0x78 0x76 0x7a 0x5a , cs:1 min  :0x56 0x65 0x4a 0x4d 0x4b 0x4e 0x53 ,0x52 0x57 0x4b 0x51 0x4b 0x47 0x51 , cs:1 mid  :0x97 0x9e 0x8a 0x87 0x8a 0x85 0x83 ,0x93 0x91 0x8a 0x88 0x88 0x82 0x81 , cs:1 max  :0xd9 0xd7 0xcb 0xc1 0xca 0xbd 0xb3 ,0xd4 0xcb 0xc9 0xbf 0xc6 0xbd 0xb1 , cs:1 range:0x83 0x72 0x81 0x74 0x7f 0x6f 0x60 ,0x82 0x74 0x7e 0x6e 0x7b 0x76 0x60 , out rockchip_sdram_size fdc20208 10000a02 rank=2 cs0_col=10 cs1_col=10 bk=3 cs0_row=17 cs1_row=17 bg=0 bw=2 row_3_4=0 SDRAM base=0, size=200000000 U-Boot SPL 2022.01-rc4-armbian (Jan 23 2022 - 11:40:31 +0300) rockchip_sdhci_probe clk set rate fail! Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error Trying to boot from MMC2 INFO:    Preloader serial: 2 NOTICE:  BL31: v2.3():v2.3-152-g4e725b15f:cl NOTICE:  BL31: Built : 10:51:13, Jul 15 2021 INFO:    GICv3 without legacy support detected. INFO:    ARM GICv3 driver initialized in EL3 INFO:    pmu v1 is valid INFO:    dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 0 INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:  Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0xa00000 INFO:    SPSR = 0x3c9 U-Boot 2022.01-rc4-armbian (Jan 23 2022 - 11:40:31 +0300) Model: Pine64 RK3566 Quartz64-A Board DRAM:  rockchip_sdram_size fdc20208 10000a02 rank=2 cs0_col=10 cs1_col=10 bk=3 cs0_row=17 cs1_row=17 bg=0 bw=2 row_3_4=0 SDRAM base=0, size=200000000 8 GiB MMC:  rockchip_sdhci_probe clk set rate fail! mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0 Loading Environment from nowhere... OK In:    serial@fe660000 Out:  serial@fe660000 Err:  serial@fe660000 Model: Pine64 RK3566 Quartz64-A Board Net:  No ethernet found. Hit any key to stop autoboot:  0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 1: Armbian Retrieving file: /boot/uInitrd Retrieving file: /boot/Image append: root=UUID=ad8c15d9-13f7-4b85-8337-ad918dae5fc7 console=ttyS02,1500000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian Retrieving file: /boot/dtb/rockchip/rk3566-quartz64-a.dtb Moving Image from 0x2080000 to 0x2200000, end=4420000 oacy Image at 0a200000 ...   Image Name:  uInitrd   Image Type:  AArch64 Linux RAMDisk Image (gzip compressed)   Data Size:    14042273 Bytes = 13.4 MiB   Load Address: 00000000   Entry Point:  00000000   Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000   Booting using the fdt blob at 0xa100000   Loading Ramdisk to ed19f000, end edf034a1 ... OK   Loading Device Tree to 00000000ed182000, end 00000000ed19ee63 ... OK Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux version 5.16.2-media (root@vbox) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #trunk SMP PREEMPT Sun Jan 23 11:49:47 MSK 2022 [    0.000000] Machine model: Pine64 RK3566 Quartz64-A Board [    0.000000] efi: UEFI not found. [    0.000000] NUMA: No NUMA configuration found [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] NUMA: NODE_DATA [mem 0x1fefefa40-0x1feff1fff] [    0.000000] Zone ranges: [    0.000000]  DMA      [mem 0x0000000000200000-0x00000000ffffffff] [    0.000000]  DMA32    empty [    0.000000]  Normal  [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Movable zone start for each node [    0.000000] Early memory node ranges [    0.000000]  node  0: [mem 0x0000000000200000-0x00000000efffffff] [    0.000000]  node  0: [mem 0x0000000100000000-0x00000001ffffffff] [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [    0.000000] cma: Reserved 384 MiB at 0x00000000d5000000 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.1 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: MIGRATE_INFO_TYPE not supported. [    0.000000] psci: SMC Calling Convention v1.2 [    0.000000] percpu: Embedded 30 pages/cpu s82200 r8192 d32488 u122880 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: detected: GIC system register CPU interface [    0.000000] CPU features: detected: Virtualization Host Extensions [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [    0.000000] alternatives: patching kernel code [    0.000000] Fallback order for Node 0: 0 [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1999368 [    0.000000] Policy zone: Normal [    0.000000] Kernel command line: root=UUID=ad8c15d9-13f7-4b85-8337-ad918dae5fc7 console=ttyS02,1500000 console=tty0 rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [    0.000000] software IO TLB: mapped [mem 0x00000000d1000000-0x00000000d5000000] (64MB) [    0.000000] Memory: 7459932K/8124416K available (17984K kernel code, 3310K rwdata, 7828K rodata, 4864K init, 771K bss, 271268K reserved, 393216K cma-reserved) [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x180 with crng_init=0 [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] trace event string verifier disabled [    0.000000] rcu: Preemptible hierarchical RCU implementation. [    0.000000] rcu: RCU event tracing is enabled. [    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [    0.000000] Trampoline variant of Tasks RCU enabled. [    0.000000] Rude variant of Tasks RCU enabled. [    0.000000] Tracing variant of Tasks RCU enabled. [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode [    0.000000] GICv3: 320 SPIs implemented [    0.000000] GICv3: 0 Extended SPIs implemented [    0.000000] GICv3: Distributor has no Range Selector support [    0.000000] GICv3: MBI range [296:319] [    0.000000] GICv3: Using MBI frame 0x00000000fd410000 [    0.000000] Root IRQ handler: gic_handle_irq [    0.000000] GICv3: 16 PPIs implemented [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    0.000000] ITS: No ITS available, not enabling LPIs [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.002080] Console: colour dummy device 80x25 [    0.002834] printk: console [tty0] enabled [    0.002988] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [    0.003033] pid_max: default: 32768 minimum: 301 [    0.003218] LSM: Security Framework initializing [    0.003277] Yama: becoming mindful. [    0.003429] AppArmor: AppArmor initialized [    0.003626] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [    0.003704] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [Hierarchical SRCU implementation. [    0.013850] EFI services will not be available. [    0.014535] smp: Bringing up secondary CPUs ... [    0.015648] Detected VIPT I-cache on CPU1 [    0.015698] GICv3: CPU1: found redis8fd480000 [    0.015773] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    0.017080] Detected VIPT I-cache on CPU2 [    0.017128] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    0.017188] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    0.018411] Detected VIPT I-cache on CPU3 [    0.018459] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [    0.018516] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [    0.018709] smp: Brought up 1 node, 4 CPUs [    0.018850] SMP: Total of 4 processors activated. [    0.018872] CPU features: detected: 32-bit EL0 Support [    0.018889] CPU features: detected: 32-bit EL1 Support [    0.018907] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [    0.018931] CPU features: detected: Common not Private translations [    0.018948] CPU features: detected: CRC32 instructions [    0.018966] CPU features: detected: RCpc load-acquire (LDAPR) [    0.018983] CPU features: detected: LSE atomic instructions [    0.018999] CPU features: detected: Privileged Access Never [    0.019016] CPU features: detected: RAS Extension Support [    0.019034] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [    0.062355] CPU: All CPU(s) started at EL2 [    0.066838] devtmpfs: initialized [    0.095226] Registered cp15_barrier emulation handler [    0.095286] Registered setend emulation handler [    0.095316] KASLR disabled due to lack of seed [    0.095653] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [    0.095724] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [    0.107820] pinctrl core: initialized pinctrl subsystem [    0.108974] DMI not present or invalid. [    0.109839] NET: Registered PF_NETLINK/PF_ROUTE protocol family [    0.113951] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [    0.115124] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocalocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [    0.117675] audit: initializing netlink subsys (disabled) [    0.118065] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1 [    0.120782] thermal_sys: Registered thermal governor 'fair_share' [    0.120801] thermal_sys: Registered thermal governor 'bang_bang' [    0.120835] thermal_sys: Registered thermal governor 'step_wise' [    0.120855] thermal_sys: Registered thermal governor 'user_space' [    0.120874] thermal_sys: Registered thermal governor 'power_allocator' [    0.121802] cpuidle: using governor ladder [    0.121883] cpuidle: using governor menu [    0.122462] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.122697] ASID allocator initialised with 65536 entries [    0.124833] Serial: AMBA PL011 UART driver [    0.145309] platform fe0a0000.hdmi: Fixing up cyclic dependency with fe040000.vop [    0.188872] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [    0.189975] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [    0.191151] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [    0.192172] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [    0.193238] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [    0.196074] platform hdmi-con: Fixing up cyclic dependency with fe0a0000.hdmi [    0.224986] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [    0.225037] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [    0.225062] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [    0.225083] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [    0.226258] cryptd: max_cpu_qlen set to 1000 [    0.293606] raid6: neonx8  gen()  1372 MB/s [    0.361761] raid6: neonx8  xor()  1080 MB/s [    0.429914] raid6: neonx4  gen()  1421 MB/s [    0.498050] raid6: neonx4  xor()  1086 MB/s [    0.566204] raid6: neonx2  gen()  1273 MB/s [    0.634346] raid6: neonx2  xor()  997 MB/s [    0.702501] raid6: neonx1  gen()  1046 MB/s [    0.770639] raid6: neonx1  xor()  838 MB/s [    0.838826] raid6: int64x8  gen()  1013 MB/s [    0.906952] raid6: int64x8  xor()  527 MB/s [    0.975086] raid6: int64x4  gen()  1077 MB/s [    1.043242] raid6: int64x4  xor()  570 MB/s [    1.111394] raid6: int64x2  gen()  962 MB/s [    1.179531] raid6: int64x2  xor()  514 MB/s [    1.247671] raid6: int64x1  gen()  677 MB/s [    1.315828] raid6: int64x1  xor()  383 MB/s [    1.315854] raid6: using algorithm neonx4 gen() 1421 MB/s [    1.315873] raid6: .... xor() 1086 MB/s, rmw enabled [    1.315891] raid6: using neon recovery algorithm [    1.317236] ACPI: Interpreter disabled. [    1.321836] iommu: Default domain type: Translated [    1.321877] iommu: DMA domain TLB invalidation policy: strict mode [    1.323676] vgaarb: loaded [    1.324521] SCSI subsystem initialized [    1.325297] usbcore: registered new interface driver usbfs [    1.325395] usbcore: registered new interface driver hub [    1.325482] usbcore: registered new device driver usb [    1.326342] pps_core: LinuxPPS API ver. 1 registered [    1.326368] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    1.326416] PTP clock support registered [    1.326766] EDAC MC: Ver: 3.0.0 [    1.328444] FPGA manager framework [    1.328641] Advanced Linux Sound Architecture Driver Initialized. [    1.329743] NetLabel: Initializing [    1.329768] NetLabel:  domain hash size = 128 [    1.329787] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO [    1.329916] NetLabel:  unlabeled traffic allowed by default [    1.331166] clocksource: Switched to clocksource arch_sys_counter [    1.407332] VFS: Disk quotas dquot_6.6.0 [    1.407478] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    1.408675] AppArmor: AppArmor Filesystem Enabled [    1.408810] pnp: PnP ACPI: disabled [    1.423711] NET: Registered PF_INET protocol family [    1.424266] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [    1.428842] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [    1.429238] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [    1.430115] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [    1.431055] TCP: Hash tables configured (established 65536 bind 65536) [    1.431431] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [    1.431674] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [    1.432152] NET: Registered PF_UNIX/PF_LOCAL protocol family [    1.432218] NET: Registered PF_XDP protocol family [    1.432252] PCI: CLS 0 bytes, default 64 [    1.432722] Trying to unpack rootfs image as initramfs... [    1.440558] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [    1.441371] kvm [1]: IPA Size Limit: 40 bits [    1.441421] kvm [1]: GICv3: no GICV resource entry [    1.441442] kvm [1]: disabling GICv2 emulation [    1.441481] kvm [1]: GIC system register CPU interface enabled [    1.441712] kvm [1]: vgic interrupt IRQ9 [    1.442029] kvm [1]: VHE mode initialized successfully [    1.445212] Initialise system trusted keyrings [    1.445305] Key type blacklist registered [    1.445735] workingset: timestamp_bits=42 max_order=21 bucket_order=0 [    1.455911] zbud: loaded [    1.458928] squashfs: version 4.0 (2009/01/31) Phillip Lougher [    1.463943] integrity: Platform Keyring initialized [    1.516745] xor: measuring software checksum speed [    1.523097]    8regs          :  1569 MB/sec [    1.528139]    32regs          :  1985 MB/sec [    1.534857]    arm64_neon      :  1480 MB/sec [    1.534891] xor: using function: 32regs (1985 MB/sec) [    1.534922] Key type asymmetric registered [    1.534941] Asymmetric key parser 'x509' registered [    1.535315] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [    1.535702] io scheduler mq-deadline registered [    1.535731] io scheduler kyber registered [    1.536088] io scheduler bfq registered [    1.558596] EINJ: ACPI disabled. [    1.568242] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [    1.568296] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    1.571982] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [    1.572034] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [    1.585926] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [    1.590321] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 23, base_baud = 1500000) is a 16550A [    1.592424] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 43, base_baud = 1500000) is a 16550A [    1.592728] serial serial0: tty port ttyS1 registered [    1.594272] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 44, base_baud = 1500000) is a 16550A [    1.706442] printk: console [ttyS2] enabled [    1.708840] Serial: AMBA driver [    1.713624] rockchip-vop2 fe040000.vop: Adding to iommu group 1 [    1.721672] cacheinfo: Unable to detect cache hierarchy for CPU 0 [    1.738041] brd: module loaded [    1.750528] loop: module loaded [    1.753399] Loading iSCSI transport class v2.0-870. [    1.755008] iscsi: registered transport (tcp) [    1.755468] megasas: 07.719.03.00-rc1 [    1.765056] libphy: Fixed MDIO Bus: probed [    1.768724] thunder_xcv, ver 1.0 [    1.769125] thunder_bgx, ver 1.0 [    1.769506] nicpf, ver 1.0 [    1.771225] hclge is initializing [    1.771571] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [    1.772226] hns3: Copyright (c) 2017 Huawei Corporation. [    1.772865] igb: Intel(R) Gigabit Ethernet Network Driver [    1.773360] igb: Copyright (c) 2007-2014 Intel Corporation. [    1.773960] igbvf: Intel(R) Gigabit Virtual Function Network Driver [    1.774530] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [    1.775629] sky2: driver version 1.30 [    1.778336] VFIO - User Level meta-driver version: 0.3 [    1.782546] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    1.783248] ehci-pci: EHCI PCI platform driver [    1.783754] ehci-platform: EHCI generic platform driver [    1.786848] ehci-platform fd800000.usb: EHCI Host Controller [    1.787463] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [    1.788380] ehci-platform fd800000.usb: irq 18, io mem 0xfd800000 [    1.803250] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [    1.804244] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [    1.805009] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.805668] usb usb1: Product: EHCI Host Controller [    1.806115] usb usb1: Manufacturer: Linux 5.16.2-media ehci_hcd [    1.806650] usb usb1: SerialNumber: fd800000.usb [    1.808058] hub 1-0:1.0: USB hub found [    1.808507] hub 1-0:1.0: 1 port detected [    1.811969] ehci-platform fd880000.usb: EHCI Host Controller [    1.812543] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [    1.813465] ehci-platform fd880000.usb: irq 20, io mem 0xfd880000 [    1.827304] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [    1.828325] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16 [    1.829088] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.829744] usb usb2: Product: EHCI Host Controller [    1.830189] usb usb2: Manufacturer: Linux 5.16.2-media ehci_hcd [    1.830723] usb usb2: SerialNumber: fd880000.usb [    1.832129] hub 2-0:1.0: USB hub found [    1.832555] hub 2-0:1.0: 1 port detected [    1.833925] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    1.834521] ohci-pci: OHCI PCI platform driver [    1.835045] ohci-platform: OHCI generic platform driver [    1.836138] ohci-platform fd840000.usb: Generic Platform OHCI controller [    1.836782] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [    1.837721] ohci-platform fd840000.usb: irq 19, io mem 0xfd840000 [    1.899606] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [    1.900382] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.901038] usb usb3: Product: Generic Platform OHCI controller [    1.901575] usb usb3: Manufacturer: Linux 5.16.2-media ohci_hcd [    1.902109] usb usb3: SerialNumber: fd840000.usb [    1.903446] hub 3-0:1.0: USB hub found [    1.903872] hub 3-0:1.0: 1 port detected [    1.905294] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [    1.905935] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [    1.906836] ohci-platform fd8c0000.usb: irq 21, io mem 0xfd8c0000 [    1.971592] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.16 [    1.972371] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.973026] usb usb4: Product: Generic Platform OHCI controller [    1.973562] usb usb4: Manufacturer: Linux 5.16.2-media ohci_hcd [    1.974096] usb usb4: SerialNumber: fd8c0000.usb [    1.975432] hub 4-0:1.0: USB hub found [    1.975857] hub 4-0:1.0: 1 port detected [    1.979241] usbcore: registered new interface driver usb-storage [    1.985099] mousedev: PS/2 mouse device common for all mice [    1.985423] Freeing initrd memory: 13712K [    1.988139] i2c_dev: i2c /dev entries driver [    1.991236] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [    2.001823] rk808 0-0020: chip id: 0x8170 [    2.037496] random: fast init done [    2.048327] rk808-regulator rk808-regulator: there is no dvs0 gpio [    2.048932] rk808-regulator rk808-regulator: there is no dvs1 gpio [    2.049499] rk808-regulator rk808-regulator: max buck steps per change: 8 [    2.065379] vcc_ddr: Bringing 500000uV into 1100000-1100000uV [    2.095973] vccio_acodec: Bringing 1800000uV into 3300000-3300000uV [    2.124742] vcc2v8_dvp: Bringing 1800000uV into 2800000-2800000uV [    2.132342] boost: Bringing 4700000uV into 5000000-5000000uV [    2.148011] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0 [    2.161684] rk808-rtc rk808-rtc: registered as rtc0 [    2.164886] rk808-rtc rk808-rtc: setting system clock to 2022-01-23T16:50:37 UTC (1642956637) [    2.180101] sdhci: Secure Digital Host Controller Interface driver [    2.180686] sdhci: Copyright(c) Pierre Ossman [    2.181945] Synopsys Designware Multimedia Card Interface Driver [    2.184545] sdhci-pltfm: SDHCI platform and OF driver helper [    2.188532] ledtrig-cpu: registered to indicate activity on CPUs [    2.190248] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd [    2.191460] hid: raw HID events driver (C) Jiri Kosina [    2.192392] usbcore: registered new interface driver usbhid [    2.192905] usbhid: USB HID core driver [    2.205435] NET: Registered PF_INET6 protocol family [    2.259737] Segment Routing with IPv6 [    2.260180] In-situ OAM (IOAM) with IPv6 [    2.260652] NET: Registered PF_PACKET protocol family [    2.261335] 8021q: 802.1Q VLAN Support v1.8 [    2.261791] Key type dns_resolver registered [    2.263826] registered taskstats version 1 [    2.264226] Loading compiled-in X.509 certificates [    2.269336] Loaded X.509 cert 'Build time autogenerated kernel key: bcfb3c304f2603c517987cb4d69b34b8b7156cba' [    2.274780] zswap: loaded using pool zstd/z3fold [    2.276840] Key type ._fscrypt registered [    2.277224] Key type .fscrypt registered [    2.277583] Key type fscrypt-provisioning registered [    2.281414] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [    2.282548] Key type encrypted registered [    2.282948] AppArmor: AppArmor sha1 policy hashing enabled [    2.283549] ima: No TPM chip found, activating TPM-bypass! [    2.284098] ima: Allocated hash algorithm: sha1 [    2.284560] ima: No architecture policies found [    2.285084] evm: Initialising EVM extended attributes: [    2.285555] evm: security.selinux [    2.285861] evm: security.SMACK64 [    2.286164] evm: security.SMACK64EXEC [    2.286498] evm: security.SMACK64TRANSMUTE [    2.286870] evm: security.SMACK64MMAP [    2.287234] evm: security.apparmor [    2.287550] evm: security.ima [    2.287823] evm: security.capability [    2.288150] evm: HMAC attrs: 0x1 [    2.377506] vop2_create_crtc: No remote for vp1 [    2.377983] vop2_create_crtc: No remote for vp2 [    2.378593] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops) [    2.381264] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [    2.383140] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [    2.386197] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops) [    2.387285] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [    2.388669] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [    2.391876] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [    2.393534] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [    2.394184] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30). [    2.394703] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10). [    2.395271] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [    2.395935] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [    2.401509] rk_gmac-dwmac fe010000.ethernet: init for RGMII [    2.402407] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [    2.403067] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [    2.403576] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [    2.404257] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [    2.404931] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [    2.405564] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [    2.406235] rk_gmac-dwmac fe010000.ethernet: TSO supported [    2.406737] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [    2.407499] rk_gmac-dwmac fe010000.ethernet: device MAC address a6:18:ed:86:5b:8d [    2.408187] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=8) [    2.408827] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [    2.409373] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width [    2.543202] libphy: stmmac: probed [    2.562893] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [    2.563648] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [    2.564271] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [    2.564373] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 33,32 bit host data width,256 deep fifo [    2.564812] printk: console [netcon0] enabled [    2.566045] netconsole: network logging started [    2.567028] psci_checker: PSCI checker started using 4 CPUs [    2.567119] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [    2.567589] psci_checker: Starting hotplug tests [    2.568473] psci_checker: Trying to turn off and on again all CPUs [    2.569868] psci: CPU0 killed (polled 0 ms) [    2.574607] psci: CPU1 killed (polled 0 ms) [    2.578270] psci: CPU2 killed (polled 0 ms) [    2.580023] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [    2.583870] Detected VIPT I-cache on CPU0 [    2.584299] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    2.585001] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [    2.588060] Detected VIPT I-cache on CPU1 [    2.588490] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    2.589206] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    2.592797] Detected VIPT I-cache on CPU2 [    2.593230] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    2.593950] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    2.596754] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3) [    2.597980] psci: CPU0 killed (polled 0 ms) [    2.601427] psci: CPU1 killed (polled 0 ms) [    2.604725] psci: CPU2 killed (polled 0 ms) [    2.608178] Detected VIPT I-cache on CPU0 [    2.608609] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [    2.609311] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [    2.612365] Detected VIPT I-cache on CPU1 [    2.612798] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [    2.613516] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [    2.617092] Detected VIPT I-cache on CPU2 [    2.617524] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [    2.618244] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [    2.6211ecker: Hotplug tests passed OK [    2.621639] psci_checker: Starting suspend tests (10 cycles per state) [    2.622346] psci_checker: cpuidle not available on CPU 0, ignoring [    2.622977] psci_checker: cpuidle not available on CPU 1, ignoring [    2.623648] psci_checker: cpuidle not available on CPU 2, ignoring [    2.624277] psci_checker: cpuidle not available on CPU 3, ignoring [    2.624894] psci_checker: Could not start suspend tests on any CPU [    2.625508] psci_checker: PSCI checker completed [    2.625985] of_cfs_init [    2.626269] of_cfs_init: OK [    2.629872] ALSA device list: [    2.630176]  No soundcards found. [    2.633131] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [    2.634158] mmc0: new high speed SDHC card at address 0001 [    2.635337] Freeing unused kernel memory: 4864K [    2.636591] mmcblk0: mmc0:0001 SD32G 29.1 GiB [    2.647113]  mmcblk0: p1 [    2.651350] Run /init as init process [    3.395370] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [    3.735260] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [    4.599299] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: data=writeback. Quota mode: none. [    5.551029] sysLmd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified) [    5.555731] systemd[1]: Detected architecture arm64. [    5.566954] systemd[1]: Set hostname to <station-m2>. [    5.747885] dw-apb-uart fe660000.serial: forbid DMA for kernel console [    6.605303] systemd[1]: Queued start job for default target Graphical Interface. [    6.608018] random: systemd: uninitialized urandom read (16 bytes read) [    6.614256] systemd[1]: Created slice system-getty.slice. [    6.615701] random: systemd: uninitialized urandom read (16 bytes read) [    6.618756] systemd[1]: Created slice system-modprobe.slice. [    6.619851] random: systemd: uninitialized urandom read (16 bytes read) [    6.623382] systemd[1]: Created slice system-serial\x2dgetty.slice. [    6.626603] systemd[1]: Created slice User and Session Slice. [    6.627746] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [    6.629553] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [    6.632273] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [    6.633806] systemd[1]: Reached target Local Encrypted Volumes. [    6.635025] systemd[1]: Reached target Paths. [    6.636029] systemd[1]: Reached target Slices. [    6.636895] systemd[1]: Reached target Swap. [    6.637729] systemd[1]: Reached target System Time Set. [    6.663299] systemd[1]: Listening on RPCbind Server Activation Socket. [    6.665549] systemd[1]: Listening on Syslog Socket. [    6.667433] systemd[1]: Listening on fsck to fsckd communication Socket. [    6.669004] systemd[1]: Listening on initctl Compatibility Named Pipe. [    6.671400] systemd[1]: Listening on Journal Audit Socket. [    6.673274] systemd[1]: Listening on Journal Socket (/dev/log). [    6.675436] systemd[1]: Listening on Journal Socket. [    6.677773] systemd[1]: Listening on udev Control Socket. [    6.679691] systemd[1]: Listening on udev Kernel Socket. [    6.687270] systemd[1]: Mounting Huge Pages File System... [    6.695446] systemd[1]: Mounting POSIX Message Queue File System... [    6.703799] systemd[1]: Mounting RPC Pipe File System... [    6.713003] systemd[1]: Mounting Kernel Debug File System... [    6.721588] systemd[1]: Mounting Kernel Trace File System... [    6.723714] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped. [    6.734123] systemd[1]: Starting Restore / save the current clock... [    6.742844] systemd[1]: Starting Set the console keyboard layout... [    6.751827] systemd[1]: Starting Create list of static device nodes for the current kernel... [    6.761087] systemd[1]: Starting Load Kernel Module configfs... [    6.770740] systemd[1]: Starting Load Kernel Module drm... [    6.785289] systemd[1]: Starting Load Kernel Module fuse... [    6.796277] systemd[1]: Started Nameserver information manager. [    6.800303] systemd[1]: Reached target Network (Pre). [    6.807097] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [    6.811870] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [    6.825496] systemd[1]: Starting Load Kernel Modules... [    6.834119] systemd[1]: Starting Remount Root and Kernel File Systems... [    6.860576] systemd[1]: Starting Coldplug All udev Devices... [    6.860612] fuse: init (API version 7.35) [    6.887528] systemd[1]: Mounted Huge Pages File System. [    6.889362] systemd[1]: Mounted POSIX Message Queue File System. [    6.891484] systemd[1]: Mounted Kernel Debug File System. [    6.893487] systemd[1]: Mounted Kernel Trace File System. [    6.897533] systemd[1]: Finished Restore / save the current clock. [    6.906226] systemd[1]: Finished Create list of static device nodes for the current kernel. [    6.911773] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [    6.913928] systemd[1]: modprobe@configfs.service: Succeeded. [    6.917328] systemd[1]: Finished Load Kernel Module configfs. [    6.919046] RPC: Registered named UNIX socket transport module. [    6.919782] RPC: Registered udp transport module. [    6.920221] RPC: Registered tcp transport module. [    6.921081] RPC: Registered tcp NFSv4.1 backchannel transport module. [    6.925977] systemd[1]: modprobe@drm.service: Succeeded. [    6.929596] systemd[1]: Finished Load Kernel Module drm. [    6.937293] systemd[1]: Mounted RPC Pipe File System. [    6.940302] systemd[1]: modprobe@fuse.service: Succeeded. [    6.943802] systemd[1]: Finished Load Kernel Module fuse. [    6.950978] systemd[1]: Finished Load Kernel Modules. [    6.956122] systemd[1]: Finished Remount Root and Kernel File Systems. [    6.966020] systemd[1]: Mounting FUSE Control File System... [    6.974171] systemd[1]: Mounting Kernel Configuration File System... [    6.981315] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [    6.982541] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [    6.990919] systemd[1]: Starting Load/Save Random Seed... [    7.000165] systemd[1]: Starting Apply Kernel Variables... [    7.009060] systemd[1]: Starting Create System Users... [    7.020280] systemd[1]: Mounted FUSE Control File System. [    7.022050] systemd[1]: Mounted Kernel Configuration File System. Armbian 22.02.0-trunk Bullseye ttyS2 station-m2 login:
  USB on Quartz64 Zero litbulb 2 3,055 11-09-2026, 01:33 PM
Last Post: elizabethtaylor
  DietPi OS for Quartz64 MichaIng 48 65,194 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,136 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,731 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 194,557 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 95,009 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,233 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,019 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,981 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,786 10-29-2022, 06:55 AM
