Quartz64 max PCIE power?
I would eventually (I realize the software stack isnt really there yet) like to replace my intel atom board in my home server with a Quartz64, however, I'm wondering power wise if it will be able to run my SAS adapter? How many W can I draw from the PCIe slot on the board, assuming I have "Unlimited" power on the input (will be running it all off a ATX PSU)
The 12V on the PCIe connector comes from the DC in socket, so however much your DC power supply is able to provide, minus whatever the rest of the system uses through the PMIC's DC-to-DC converters.
The 3.3V on the PCIe connector is DC-to-DC converted from the 12V input by an SY8113B, which can deliver 3A of current according to its data sheet.
So in short, 3A*3.3V = 9.9W on the 3.3V rail, and north of 50W on the 12V rail depending on how beefy your DC power supply is.
If your card only draws wattage from the 3.3V rail, you might get in trouble, but if it has its own DC-to-DC circuitry to convert the 12V input, you're all good.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 5 23,888 05-05-2026, 07:57 AM
Last Post: kapqa
  How to reengage PCIe when reapplying power? rotdrop 1 2,381 10-10-2024, 06:49 AM
Last Post: rotdrop
  No boot...power light shows green 98cwitr 2 6,348 01-19-2024, 07:31 PM
Last Post: Darin755
  Quartz64 seeming died Darin755 0 2,369 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 5,284 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 4,210 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 4,506 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 20,476 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 24,757 04-28-2023, 01:58 AM
Last Post: NCLI
  Booting Quartz64 Model B Jojo120120 14 22,428 01-23-2023, 03:31 AM
Last Post: balbes150
