Acrylic enclosure
Would anyone that has received their Acrylic case be so kind and provide some measurements for it?
I´m most interested in hole layout as I´m going to mount it using the original holes from the enclosure.
It would be nice to get some work done before my shipment arrives Smile
Backer #20,167 - KS funded 07 Jan 2016 - Backerkit funded 10 Mar 2016
STATUS -  Received 6 Jul 2016 - Shipped 24 Jun 2016
Which holes? The posts between top and bottom or the holes for mounting the Pine64?
Posts are 151.5mm and 102mm between centres. Actually, I measured the current position of the posts, not the holes, as it's assembled, but I don't think there's much wiggle room, all equivalent sides match.
(05-24-2016, 09:05 AM)benpope81 Wrote: Which holes? The posts between top and bottom or the holes for mounting the Pine64?
I think they mean the length, width and depth of the actual acrylic case, not the distance between holes/posts.
I think he means the length, width and depth of the actual acrylic case, not the distance between holes/posts.
Acrylic dimensions: 167x118mm
Acrylic case height (external face to external face): 48mm
Height including posts: 57mm
Sorry about being unclear, I meant between the posts, as I will mount the entire case on to a bigger sheet of acrylic, and it would be easiest to use existing holes for that
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 16,176 09-17-2020, 06:41 AM
Last Post: dabou
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 33,202 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 52,268 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,732 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 13,157 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 10,112 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,475 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,546 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 32,096 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,967 11-01-2016, 06:23 PM
