any way to turn off authentication on pinephone?
I'm using it purely as a phone and reader, and there's nothing on the pinephone of any interest to anyone. The authentication step is a bother but would be okay if it only happened on reboot. But it's every single time after the screen blanks, which is a *giant* bother. (More so for me than some people because I have very dry skin, and everything on a touchscreen takes multiple tries for me.)
Oh, I do have the screen set to never blank while I'm using it, but I doubt that's a good idea when it's knocking around in my pocket.
Is there any way to bypass authentication entirely? I'm happy to edit files in /etc or wherever, but will need step-by-step instructions. Bad things happen when I try to improvise as root Dodgy .
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
Not yet AFAIK. There's an outstanding phosh bug/feature request asking for an option to disable password authentication on the lock screen, but nobody has implemented it yet. I think that would still need a touchscreen action like a swipe, but a lot less involved than a full unlock.
as a partial solution, why change password to one digit, like "9". obvious disadvantage, do not use ssh or change ssh to allow different user.
get the user name.
$ whoami
get the root console, system does not allow ordinary users to change bad and easy passwords.
$ sudo su -l
change user password, (do not change root user's password).
# passwd >username< # passwd manjaro
in one command
$ sudo passwd >username<
I stand on :
loginctl show-seat $(loginctl list-seats --no-pager --no-legend) -p ActiveSession --value|xargs -iX loginctl unlock-session X
or faster :
loginctl unlock-sessions
when connected in ssh.
From what i understood, systemd-logind take the hand when the power on button is pressed, then it communicates directly with PAM. I found no way to add a second handler on the press button or redirect the existing one.
udevadm trigger -v -n -g power-switch
returns
/sys/devices/platform/gpio-keys/input/input0/event0
Then
udevadm info /sys/devices/platform/gpio-keys/input/input0/event0
seems to correspond to the power button (but not sure - if somebody could confirm)
So we have the command to run and (perhaps) the button, and now ?
Thanks for the ideas!
The one to change pwd to one digit could well be a workaround. I didn't realize there was enough interest for a bug/feature request to be filed. I'll have to go look that up.
I'll have to study yours, Frexit. Not sure I understand it yet Big Grin
I followed the
cat /sys/devices/platform/gpio-keys/input/input0/event0/uevent
then
fuser /dev/input/event0
and it is seems finally that systemd doesn't handle the power button at all because of the file :
/etc/systemd/logind.conf.d/ignore-power-key.conf [Login] HandlePowerKey=ignore
According to "udevadm monitor", the power button is not handled by udev too.
The previous fuser shows 3 processes : init, systemd-logind and phoc/phosh/gnome-session.
So it seems that the power button is definitely handled by the last one :
/usr/bin/phoc -C /usr/share/phosh/phoc.ini -E bash -lc 'gnome-session --disable-acceleration-check --session=phosh --builtin'
So seems like we will have to wait that phosh team implements the option...
  Mobian image for the PinePhone Korfou 2 2,116 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,843 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,348 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,613 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,571 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,388 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,660 01-02-2025, 12:47 PM
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 10,213 01-08-2024, 02:50 PM
Last Post: ERPlegend
  PinePhone won't boot after software update jb2000 2 5,157 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 7,146 03-01-2023, 04:45 PM
