Mounting / unmounting drives from the Index app (Plasma)
I opened an encrypted SD card using a USB card reader connected to the phone. It appeared in the Index app, which showed the "mount" button and then I could enter the passphrase. But now I don't know how to unmount & lock it. The Index app doesn't have the usual unmounting icon like Dolphin has. I had to unmount via the terminal.
Is there a direct way to unmount & lock a card via the Index app? Or in Settings, or somewhere else?
(10-01-2021, 10:36 AM)theResonant Wrote: Is there a direct way to unmount & lock a card via the Index app?
In Index "long touch" on the SD card and select "Remove".
At least it worked that way here with combo usbA/usbC "memory stick". Nonencrypted media used though...
Selecting "Remove" makes the entry disappear from the sidebar, but if I close Index and re-open it, the card appears again in the sidebar. Also, my card reader has an LED that shows "disconnected" when ejected from the computer, but this doesn't happen when selecting "Remove".
The only way I can trigger a real unmounting is via the terminal. So the "Remove" option is there, but doesn't seem to do much else apart from visually removing the entry. Maybe you're right, it does work for unencrypted media. Will try.
(10-06-2021, 01:29 AM)theResonant Wrote: Selecting "Remove" makes the entry disappear from the sidebar, but if I close Index and re-open it, the card appears again in the sidebar.
Just rechecked and yes, you seems to be right. The USB "stick" after "Remove" and at Index next start is still there and seems to be mounted. At least it does not ask permission to mount it as it happens after the first connection...
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 21,700 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,938 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,136 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,128 03-02-2023, 07:25 PM
  Manjaro plasma-mobile Beta 13 Uturn 13 16,675 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,698 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 16,195 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 3,320 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 53,788 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 2,644 07-04-2022, 11:42 AM
Last Post: tuxmain
