zram swap support for the PBP; aka: "how to download more RAM"
(02-01-2020, 01:06 PM)wasgurd Wrote:
(01-21-2020, 11:39 PM)Arglebarg Wrote:
root@pinebookpro:~/work/zram-swap# cat /proc/swaps
Filename                                Type            Size    Used    Priority
/dev/zram0                              partition       6291452 0       5
I'm pretty sure the default swapfile has a priority of 1, 0 or -1; I can't remember which. The zram-swap script sets priority 5 which should be higher.
You can safely disable the default swapfile and remove it.
What size of zram do you recommend?
I personally use 2xRAM, 1.5xRAM is what Chromebooks use as well as what my team uses at work for our production fleet. It kinda depends on what compression algorithm you use as well as what gets stuffed into your RAM. If you use lz4 for extra-fast compression/decompression you should expect compression ratio around 2x on average, with default lzo or lzo-rle you should expect compression ratio around 3x. Considering you still need some base memory that cannot be swapped out/compressed, I'd say you should be OK with the above mentioned sizes for zram - you are more likely to see the system slow down very noticeably as it fills up zram beyond ~180-200% total RAM use ((zram content + RAM use - zram compressed size)/total RAM) than see OOMs with those sizes in my experience.
  Official Debian support moonwalkers 64 120,262 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Armbian is [edit: no longer] dropping support for Pinebook Pro TRS-80 4 8,231 12-23-2022, 12:01 AM
Last Post: TRS-80
  Armbian VPU decoding support coming soon LivingLinux 0 3,139 11-13-2022, 02:32 PM
Last Post: LivingLinux
  Kernel 5.17 will improve VP9 support? jiyong 1 5,872 01-16-2022, 08:26 PM
Last Post: xmixahlx
  Debian GPU Support Atton 5 11,400 12-02-2021, 05:37 PM
Last Post: cobratbq
  PostmarketOS - Why swap file not on at boot? stozi 3 8,798 06-24-2021, 12:27 AM
Last Post: craftyguy
  [LibreOffice & Gimp] ARM support: no hardware acceleration on [Manjaro] Pinebook Pro regivanx 0 4,677 06-15-2021, 04:04 AM
Last Post: regivanx
  [Panfrost] now support stable OpenGL ES 3.1 rimaille 0 4,799 06-10-2021, 11:23 PM
Last Post: rimaille
  Better rkvdec support in 5.11? ShootTheMoon2 2 7,644 02-28-2021, 07:10 PM
Last Post: ShootTheMoon2
  Question about graphics support mcc 11 27,702 10-10-2020, 06:43 AM
Last Post: sigmaris
