Clusterboard Armbian
Thanks for the update and the pointer on the mainline efforts. Appreciate it. Makes more sense now.
Also - thanks for the work on upstreaming your Armbian fixes.
(04-16-2018, 12:53 PM)PigLover Wrote: Thanks for the update and the pointer on the mainline efforts.  Appreciate it.  Makes more sense now.
Do you know if this is available in the current images here?
https://www.armbian.com/pine64/
I have some SOPINE's en-route so I'm figuring out if I can start using the "official" Armbian images yet Smile
Thanks!
No, but a build off master of armbian should work. My one line change is merged.
Finally got around to fully populating my Clusterboard and now I'm starting to dig-in to making it fast Smile
I noticed that with this image I can't find the clock speed and cpu temps where I expect them. I believe that this is because the "mainline" kernel is being used. If that's the case I believe that this also means the clock speed is "locked" (no scaling) and could be locked as low as ~400Mhz.
Do you know if that is the case?
If so I'm wondering what the best way to address that is. I really like Armbian but I also need to get these guys running at top speed. Maybe all I need is to swap the mainline kernel out for a "legacy" one, or maybe I need to bite the bullet and do a custom build?
I've built Linux kernels before but I haven't done it on ARM so I'm not sure if/how it's different?
(06-02-2018, 04:07 AM)aww Wrote: No, but a build off master of armbian should work. My one line change is merged.
No matter what I try I get No-Carrier for eth0 on all my SOPINE modules. I assume this is a kernel issues or am I doing something wrong? I have tried "link up" but to no effect...
Thanks.
Steve
(02-19-2018, 02:09 PM)aww Wrote: This is a build of "minimal" Armbian with the change I had to make to get networking working. Do not update the the dtb file or it will break again. I am waiting on some feadback so I can upstream the fix if it works on other versions.
https://storage.googleapis.com/pine64-im....20.img.xz
Oh Joy!! Finally I have my modules booting. I am so happy. And I am so appreciative of your effort to get this information to us. I have been struggling with this and it has been keeping me from enjoying my ClusterBoard for several weeks. I am in your debt. :-)
My sincere thanks to @aww  for the image which finally worked in my cluster.
All seven modules up and happy, yea!! See the attached image.
.png   cluster-up.png (Size: 436.33 KB / Downloads: 946)
@ichibon-brosan  is SSH enabled out of the box?  im getting a connection refused.  but super glad I found an image that actually boots Smile
  Creating a current armbian-Image with network-fix clusterDude 15 53,262 05-29-2024, 03:50 PM
Last Post: poVoq
  Managed Ethernet switch on the Clusterboard dsimic 6 17,545 01-16-2024, 02:05 AM
Last Post: hazcam
Sad Version/Date of last armbian build that came with network patches? Bazmundi 0 2,786 12-07-2023, 03:23 PM
Last Post: Bazmundi
  Selling Clusterboard + 4 sopine xblack86 7 15,023 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,779 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 29,263 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 12,714 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,846 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 36,299 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 7,245 03-31-2021, 01:38 PM
Last Post: Pine
