Experimental Mobian kernel patch for extended battery life
So far I am not noticing any difference in battery life.
I am trying to leave my PPp unplugged more but without doing anything special I don't see a major change.
(09-04-2025, 01:21 AM)biketool Wrote: So far I am not noticing any difference in battery life.
I am wondering if the issue I am fixing only affects some PPP and not others. One quick way to check is to run the following WebGL Aquarium demo for 10 minutes (disable sleep/suspend):
http://webglsamples.org/aquarium/aquarium.html
Thereafter run the aforementioned command and post your output here:
sudo dmesg|grep "rk818-bat: changed"
If dsoc is significantly lower than rsoc, then that matches what I have found in all the OS's I have tried (Mobian, postmarketOS, danctnix). Note that this patch only affects usage under load (active use), not standby times or suspend times.
Any luck getting suspend to work? This makes a huge difference when the phone is under load, but without suspend...I can't see myself daily driving this. Even with my keyboard case, it drains fairly quickly.
Keep up the good work though!
(09-23-2025, 06:18 AM)benpocalypse Wrote: Any luck getting suspend to work? This makes a huge difference when the phone is under load, but without suspend...I can't see myself daily driving this. Even with my keyboard case, it drains fairly quickly.
Yes suspend works now. I guess I should update the original post.
what causes the suspend to work, not work, and hang in a coma it cant get out of?(edit) I opend the PPpro and unplugged-replugged all of the ribbon cables, suspend-coma issue is still a problem......(/edit)
BTW pretty cool the flatpak camera app, I can take pix with my PPp!!
WIll this kernel work with (testing past trixie=stable)forky as well?
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 16,639 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 2,517 04-06-2025, 02:15 AM
Last Post: henrythemouse
  Battery Management on PinePhonePro: d50zesl0g@mozmail.com 4 3,257 03-02-2025, 11:52 AM
Last Post: d50zesl0g@mozmail.com
  Battery life thread: discussion, support and tips apink 12 11,729 03-01-2025, 10:39 AM
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 6,751 02-25-2025, 08:27 AM
  Reseting the Battery Fuel Gauge franzthiemann 8 5,300 01-24-2025, 08:19 AM
Last Post: teekay
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 1,590 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 4,022 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 1,680 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,138 11-18-2023, 08:21 AM
Last Post: crocspot
