Boot Order in Pinebook Pro
(03-21-2025, 03:27 AM)rosaryspirit Wrote: That makes sense—keeping a solid U-Boot on eMMC gives flexibility without messing with SPI flash. I’ll check out the NetBSD one. Does it support booting from USB and NVMe smoothly?
At some point they upgraded the U-Boot that comes with NetBSD; so the modern one works even better. But I'm not sure about USB and NVMe support. I expect it works but I haven't tried either.
:wq
(11-23-2023, 07:37 AM)KC9UDX Wrote: I would avoid the SPI flash.
Nowadays (2025), there's the solution of flashing RK2AW on the SPI alongside U-boot
Megi made pre-bootloader/menu that will check if there are bootloaders on the SD card or on the eMMC and those will take precedence, other wise it has 2 backup copies of U-Boot next to it.
So you can flash that on the SPI, and if something goes wrong in the U-Boot you flashed, or if you merely need a different U-Boot for a different OS, you can simply pop a SD card with it and it will boot.
See here for a package containing rk2aw, opensource U-boot, and U-boot with Rockchip's binary memory initialisation:
https://xff.cz/kernels/bootloaders/ (new item: https://xnux.eu/log/091.html )
(11-23-2023, 07:37 AM)KC9UDX Wrote: I would avoid the SPI flash.  Having a good U-Boot on the eMMC works.  It won't let you boot multiple operating systems on the same media, but it will let you boot from any device.  You easily flash a good U-Boot over the Manjaru one without affecting Manjaru itself.
The one that I use which comes with NetBSD (and can probably be sourced other ways) doesn't have a "menu" but it does have a command interpreter that you can invoke by pressing a key when prompted.
See this: https://youtube.com/shorts/jVab9bcjM_I
Thanks for sharing. I saw this video. its very helpful for me.
  Window Maker Live for Pinebook Pro vajak 9 6,030 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,021 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,337 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,595 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,193 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,167 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,127 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,298 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 161,187 12-08-2023, 11:25 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 17,192 08-31-2023, 04:20 PM
Last Post: TRS-80
