Manjaro ARM 20.04
#27
(06-19-2020, 09:05 AM)theplaidtieninja Wrote: Is there a way to set the default screen brightness for with the machine powers on?
I'm running stock Manjaro Arm 20.04 with all current updates. I love the PBP, but my only real papercut issue is that the screen is really low brightness every time I turn it on. Obviously I can just change it with the keyboard, but it'd be nice if the brightness just defaulted brighter. Is there a way I can change this default value?
Yes you can.
Open Energy Saver application from start menu.
There you will see Brightness Level increase as per your convenient and press apply. from next boot it will follow this setting.
Good Luck
Manjaro ARM Team.
Manjaro ARM 20.04 - by spikerguy - 05-21-2020, 04:55 PM
RE: Manjaro ARM 20.04 - by TDC_PBP - 05-27-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by xmixahlx - 05-27-2020, 07:52 PM
RE: Manjaro ARM 20.04 - by mstrstvns - 05-28-2020, 11:24 AM
RE: Manjaro ARM 20.04 - by spikerguy - 05-28-2020, 02:17 PM
RE: Manjaro ARM 20.04 - by Der Geist der Maschine - 05-29-2020, 12:04 AM
RE: Manjaro ARM 20.04 - by pfeerick - 06-01-2020, 05:48 AM
RE: Manjaro ARM 20.04 - by cefre00 - 06-04-2020, 08:59 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 11:06 AM
RE: Manjaro ARM 20.04 - by tiagoespinha - 06-06-2020, 02:09 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-07-2020, 07:48 AM
RE: Manjaro ARM 20.04 - by zaius - 06-07-2020, 03:53 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-09-2020, 06:14 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-10-2020, 11:01 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-11-2020, 06:00 AM
RE: Manjaro ARM 20.04 - by User 18041 - 06-11-2020, 01:50 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-12-2020, 02:07 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-13-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-10-2020, 03:37 PM
RE: Manjaro ARM 20.04 - by linuxfreund - 06-12-2020, 03:41 PM
RE: Manjaro ARM 20.04 - by q4osteam - 06-16-2020, 09:02 AM
RE: Manjaro ARM 20.04 - by jiyong - 06-16-2020, 01:32 PM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-16-2020, 08:31 PM
RE: Manjaro ARM 20.04 - by spikerguy - 06-17-2020, 03:43 AM
RE: Manjaro ARM 20.04 - by ovv - 06-17-2020, 03:58 AM
RE: Manjaro ARM 20.04 - by PRStoetzer - 06-18-2020, 01:59 PM
Screen Brightness - by theplaidtieninja - 06-19-2020, 09:05 AM
RE: Screen Brightness - by spikerguy - 06-19-2020, 03:55 PM
RE: Screen Brightness - by theplaidtieninja - 06-19-2020, 06:59 PM
RE: Screen Brightness - by greysuite - 06-23-2020, 08:59 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-19-2020, 05:56 PM
RE: Manjaro ARM 20.04 - by anoctis - 06-20-2020, 03:50 PM
RE: Manjaro ARM 20.04 - by User 6582 - 06-23-2020, 09:12 AM
RE: Manjaro ARM 20.04 - by jiapei100 - 06-28-2020, 12:53 AM
RE: Manjaro ARM 20.04 - by S265 - 06-28-2020, 04:53 AM
RE: Manjaro ARM 20.04 - by spikerguy - 06-29-2020, 02:44 AM
RE: Manjaro ARM 20.04 - by S265 - 06-29-2020, 03:48 PM
RE: Manjaro ARM 20.04 - by wdt - 07-22-2020, 03:54 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 07-25-2020, 04:36 PM
RE: Manjaro ARM 20.04 - by wdt - 07-25-2020, 07:48 PM
RE: Manjaro ARM 20.04 - by thepeckhambassplayer - 08-01-2020, 11:04 AM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 08:42 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 01:35 PM
RE: Manjaro ARM 20.04 - by Redbeard - 08-12-2020, 04:10 PM
RE: Manjaro ARM 20.04 - by carlosqueso - 08-12-2020, 06:47 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-19-2020, 09:08 PM
RE: Manjaro ARM 20.04 - by spikerguy - 08-20-2020, 03:17 PM
RE: Manjaro ARM 20.04 - by 8jef - 08-20-2020, 04:56 PM
RE: Manjaro ARM 20.04 - by cefre00 - 08-25-2020, 05:37 AM
RE: Manjaro ARM 20.04 - by nightranger73 - 09-17-2020, 08:37 AM
RE: Manjaro ARM 20.04 - by carlosqueso - 09-24-2020, 07:28 PM
RE: Manjaro ARM 20.04 - by poVoq - 09-23-2020, 04:59 PM
RE: Manjaro ARM 20.04 - by pine76 - 09-29-2020, 04:09 PM
RE: Manjaro ARM 20.04 - by wdt - 09-29-2020, 05:51 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 12:00 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 04:12 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-04-2020, 10:59 PM
RE: Manjaro ARM 20.04 - by wdt - 10-04-2020, 11:15 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-05-2020, 07:45 AM
RE: Manjaro ARM 20.04 - by wdt - 10-05-2020, 12:57 PM
RE: Manjaro ARM 20.04 - by pine76 - 10-06-2020, 09:23 PM
RE: Manjaro ARM 20.04 - by rempfer - 10-16-2020, 01:30 AM
RE: Manjaro ARM 20.04 - by markifi - 02-23-2021, 03:22 PM
RE: Manjaro ARM 20.04 - by vandys - 12-27-2022, 08:11 PM
RE: Manjaro ARM 20.04 - by Yochanan - 12-28-2022, 02:53 PM
RE: Manjaro ARM 20.04 - by vandys - 01-08-2023, 07:22 PM
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 337 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,160 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,985 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 776 08-18-2023, 02:06 AM
Last Post: juliamenendez
