Mobile Carriers in the United States
#82
(07-28-2020, 05:23 PM)FOSSagent0 Wrote:
(07-28-2020, 04:06 PM)Lt. Dillinger Wrote:
(07-28-2020, 02:33 PM)rocket2nfinity Wrote:
(07-28-2020, 01:44 PM)Lt. Dillinger Wrote:
(07-28-2020, 01:09 PM)rocket2nfinity Wrote: You don't need to reset. Since it sees your sim, can you make a phone call? If so, you don't have data enabled, 2g/3g/4g set, or the apn info correctly input. What are your apn settings supposed to be according to mint mobile CS? If you can't make a phone call, did you ensure you did all system updates? An earlier build could not make phone calls well.
I can't make any calls because it's not finding their cell towers (no connection at all)  Yes, it sees the SIM card, and when I click on it, there is a check mark, but then that's it.  I have the data enabled, but it will not let me put in all of the APN info that the tech at Mint Mobile gave me.  Basically, it won't save anything except for the WiFi info.  I've disabled WiFi and Bluetooth when I tried to set up the SIM card and still no luck.  I'll keep trying different things as I have 7 days to get a refund back from Mint if I can't get it working.  Immure as more updates come out things will get sorted out.  I'm not upset as I knew these types of things were going to happen going into this.  I still have very high hopes for this phone.
When you say "not finding their cell towers at all" do you mean you have no bars? If you have no bars, then obviously you won't be able to connect. Maybe you should pop another OS onto a sim card and boot from it just to make sure your hardware is ok. There is for instance the factory test image in the postmarket demo builds. It only tests hardware. July 20 something is the date on it.
No bars because it won't connect to any cell towers.  My wife works fine, bluetooth too, but it's hit and miss on finding the SIM card too.  Sometimes I reboot and it finds the SOM card, other times not.  I've got a buddy close to me who's a cell phone guru and I'm gonna let him have a look.  We've been talking about this phone, so he's a bit interested in it too.
The issue could be the OS, I have tried the factory image of the Postmarket os image and it shows the modem is working but when using UBports it does not work with my T-mobile sim. Another thing is I've heard about the firmware for the modem being corrupted in some cases. Have you tried another os such as Mobian to see if it will work with your SIM card?
No I haven't as I really want to stick with Ubuntu Touch OS.  I'm hoping that with updates many of these issues will be worked out.  What I find interesting is the tech at Mint Mobile said she was able to help some users get their phones working.  So I guess it is a hit and miss, phone by phone situation which I find intriguing.  It's kind of like the squeak you hear in your car, it's there daily but the day you take it to the dealership, it's gone.  Smile
Mobile Carriers in the United States - by aren - 02-13-2020, 04:11 PM
RE: Mobile Carriers in the United States - by Lt. Dillinger - 07-28-2020, 08:34 PM
RE: Mobile Carriers in the United States - by RTP - 07-28-2020, 07:54 PM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 964 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,348 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,435 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,460 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 732 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,389 05-04-2023, 05:18 AM
Last Post: Gon
  MMS-Monitor: Help for carriers with dual APNs? treebeard 2 1,404 02-10-2023, 02:45 PM
Last Post: treebeard
  Phone carriers and the Speakout carrier bedtime 3 2,146 08-16-2022, 11:11 PM
Last Post: Oblivion2528
  compatible carriers the7thpoint 2 1,755 06-17-2022, 08:24 AM
Last Post: mikehenson
Lightbulb pinephone mobile dock jasmin763 2 1,757 06-06-2022, 09:06 AM
Last Post: 98cwitr
