Mobile Carriers in the United States
#36
(04-12-2020, 06:05 PM)rocket2nfinity Wrote:
(04-12-2020, 05:45 PM)laserbeamh Wrote:
(04-12-2020, 03:57 PM)rocket2nfinity Wrote:
(04-12-2020, 03:32 PM)laserbeamh Wrote:
(04-12-2020, 03:06 PM)dukla2000 Wrote: Yeah that is same for me, it it temperamental! if you exit WiFi settings, go back exit, check Bluetooth etc eventually you should find it selectable  Confused
So you're right on both counts. It was grayed out, but switching into other menus eventually made it clickable. When I enabled it, it behaved exactly as you anticipated; showed up just long enough to try to connect before cutting out and searching for known networks.
@rocket2nfinity I tried a couple calls just now on 4G only and they work both in and out (with audio). Under Modem Details it reads:
Modem Status
    Carrier                   Verizon
    Network Type       lte
    Signal Strength
    Network Status    Registered
So it seems promising! If there's anything else I can test, let me know!
Yes. Please type the following in terminal and tell me the output of the section under org.ofono.radiosettings and org.ofono.connection manager. I'm specifically looking for connection bearer info cs-preferred or ps-preferred and what bearer says under radio settings.
I want to caution you to scrub the IMEI, phone number, serial number and personal identifying info if you post the whole output here. Here is the command:
/usr/share/ofono/scripts/list-modems
I'm running debian+phosh and I think they actually removed ofono and are relying on ModemManager instead, so I've pulled out the results of mmcli -m 0 instead. The part I think is most relevant is the "carrier config" under Hardware that says "carrier config: hVoLTE-Verizon"
The full log is here. I've taken out everything I know to be personal information, but if you see anything else, please let me know!
Well I finally have my answer. The Pinephone can do VoLTE out of the box, and is already whitelisted with Verizon. Wow and congratulations.  Can you do me a favor - I'm not using Debian-phosh. Does it have any settings in network configuration to turn VoLTE on or off? Something like HD Voice, Enhanced LTE or just VoLTE? How about for WiFi calling?
VoLTE is not supported by any of the distros. It's only the modem that supports the feature. Same for Wifi calling. It's unlikely we'll be seeing support for that for a long time, as it's pretty complex as i hear, and it's also not a priority compared to other stuff.
Mobile Carriers in the United States - by aren - 02-13-2020, 04:11 PM
RE: Mobile Carriers in the United States - by 33YN2 - 04-13-2020, 10:21 PM
RE: Mobile Carriers in the United States - by RTP - 07-28-2020, 07:54 PM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 869 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,306 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,313 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,394 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 714 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,349 05-04-2023, 05:18 AM
Last Post: Gon
  MMS-Monitor: Help for carriers with dual APNs? treebeard 2 1,369 02-10-2023, 02:45 PM
Last Post: treebeard
  Phone carriers and the Speakout carrier bedtime 3 2,104 08-16-2022, 11:11 PM
Last Post: Oblivion2528
  compatible carriers the7thpoint 2 1,734 06-17-2022, 08:24 AM
Last Post: mikehenson
Lightbulb pinephone mobile dock jasmin763 2 1,733 06-06-2022, 09:06 AM
Last Post: 98cwitr
