Flash dhivael's SPI uboot (risky)
#37
(02-09-2020, 01:55 PM)as400 Wrote:
(02-09-2020, 01:48 AM)Wizzard Wrote: Thank you very much guys for the help. It just seems that it only supports Manjaro. Neither Armbian not Ubuntu boots. Armbian has the boot.scr generated, but Ubuntu does not. Can I create it manually?
Yes you can but it might be that Ubuntu uses extlinux.conf instead of boot.scr. Which is perfectly ok. Maybe even better since you can do whatever changes you want to the extlinux.conf and you don't have to generate anything,
In case you want to create boot.scr you have to create a text file (eg. boot.txt) with all the stuff you want. And then:
mkimage -A arm -O linux -T script -C none -n "U-Boot boot script" -d boot.txt boot.scr
Armbian should have both a boot.cmd file and also an armbianEnv.txt file.   The Armbian boot.scr is generated from the boot.cmd,  but many changes can be made by editing the armbianEnv.txt file.  See the armbian Documentation for more info.  You might just want to try writing the armbian build to an sd card, seeing if you can boot that way, and if so, using armbian-config to enable boot from SPI the NVME.
Flash dhivael's SPI uboot (risky) - by clover - 02-06-2020, 10:42 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 12:40 AM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 12:52 AM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 01:18 AM
RE: Flash dhivael's SPI uboot - by amiraeva - 02-07-2020, 09:42 AM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:04 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 02:42 PM
RE: Flash dhivael's SPI uboot - by User 15997 - 02-07-2020, 02:34 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:40 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 02:53 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:05 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 03:39 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:57 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 04:11 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 04:12 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 04:23 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-08-2020, 06:36 AM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 05:08 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 05:42 PM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 06:27 PM
RE: Flash dhivael's SPI uboot - by clover - 02-08-2020, 01:37 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 12:36 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:25 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 01:46 PM
Flash dhivael's SPI uboot (risky) - by Wizzard - 02-08-2020, 02:02 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 02:13 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 02:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 03:35 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 01:55 PM
RE: Flash dhivael's SPI uboot (risky) - by belfastraven - 02-09-2020, 02:16 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:27 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:46 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-12-2020, 11:16 AM
RE: Flash dhivael's SPI uboot (risky) - by vrabac - 03-13-2020, 12:12 AM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-14-2020, 08:04 AM
  How to rewrite uboot to emmc pineitup 5 8,880 12-27-2020, 10:35 AM
Last Post: nightranger73
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,735 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,457 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 18,342 09-13-2020, 01:20 PM
Last Post: hmuller
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 53,913 07-28-2020, 03:18 PM
Last Post: SamWilts
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,977 06-07-2020, 02:37 AM
Last Post: as400
  (almost) upstream uboot/atf User 15997 27 31,205 02-08-2020, 10:18 PM
Last Post: Natrox
  Widevine-flash on Chromium-SD Card mamboman777 3 6,470 01-20-2020, 04:00 PM
