full disk encryption with luks on manjaro xfce
#46
(07-04-2020, 02:31 PM)Proant Wrote: Well, almost got there using the manjaro-arm-installer with the prebuilt encryption option, yet not quite there yet..
Posted an issue there.
Let's see where that leads.
I'm also curiously following your issue, as the procedure you've posted would have been how I'd have imagined it roughly, too.
So you did indeed run the script directly on the PineBook, no more x86-machine needed? Or did you use a VM?
Would be happy if you could post exactly what you did in case you get it working... Good luck! Smile
RE: full disk encryption with luks on manjaro xfce - by JtR - 07-05-2020, 12:42 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,165 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,578 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,250 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,144 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,440 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,911 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,762 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 58,554 07-11-2020, 09:01 PM
Last Post: xmixahlx
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,959 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,926 06-07-2020, 02:37 AM
Last Post: as400
