full disk encryption with luks on manjaro xfce
(02-17-2020, 02:15 PM)JaceAlvejetti Wrote:
(02-17-2020, 01:59 PM)limxr Wrote:
(02-17-2020, 10:43 AM)JaceAlvejetti Wrote: Followed the directions, in the end I reboot to a screen that does ask for my password but when I type its entered into the line below it in plain text, hitting enter doesn't do anything but move to the next line.
after some time modules will start to time out not being able to find firmware so I don't think my text is being entered in the right space.
Any thoughts?
It sounds like the boot process did not wait for the password prompt but just continued.  Do you have rootwait set as a bootarg?  I've attached my boot.txt to see as example.
I do at that and agree that is what it sounds like, heres mine:
setenv macaddr da 19 c8 7a 6d f4
part uuid ${devtype} ${devnum}:${bootpart} uuid
setenv bootargs console=tty1 root=/dev/mapper/cryptroot cryptdevice=UUID=bc3791fa-01e0-471d-9ace-a7cae5035c15:cryptroot:allow-discards rw rootwait quiet append video=eDP-1:1920x1080@60
setenv fdtfile rockchip/rk3399-pinebook-pro.dtb
if load ${devtype} ${devnum}:${bootpart} ${kernel_addr_r} Image; then
  if load ${devtype} ${devnum}:${bootpart} ${fdt_addr_r} dtbs/${fdtfile}; then
    fdt addr ${fdt_addr_r}
    fdt resize
    fdt set /ethernet@fe300000 local-mac-address "[${macaddr}]"
    if load ${devtype} ${devnum}:${bootpart} ${ramdisk_addr_r} initramfs-linux.img; then
      # This upstream Uboot doesn't support compresses cpio initrd, use kernel option to
      # load initramfs
      setenv bootargs ${bootargs} initrd=${ramdisk_addr_r},20M ramdisk_size=10M
    fi;
    booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r};
  fi;
fi
That boot.txt looks fine.  I wonder if the initram was generated correctly with mkinitcpio -P when booted to manjaro sd before you encrypted the root partition?  From a linux os you could use cryptsetup to open the root partition on the sdcard, mount it, and check the etc/mkinitcpio.conf to make sure all the modules and hooks are loaded in order and the compression set to "cat".
If you need to generate initram again you can probably do so from an arch/manjaro os just make sure the mkinitcpio -P command is using options to point to the sdcard and not the booted os.
Another way you could do this is to decrypt the root partion on sdcard (cryptsetup-reencrypt /dev/mmcblk1p2 --decrypt) then change boot.txt back to non-luks configuration so you can boot into sdcard again.
RE: full disk encryption with luks on manjaro xfce - by limxr - 02-17-2020, 04:22 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,167 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,591 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,251 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,147 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,441 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,914 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,778 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 58,573 07-11-2020, 09:01 PM
Last Post: xmixahlx
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,967 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,961 06-07-2020, 02:37 AM
Last Post: as400
