Void Linux is probably possible.
Just an update on this, there is now a (fairly) trivial process known for building bootable Void Linux images for Pinebook Pro.
I have tested this and booted from SD card successfully. Here's where you can find the info: https://github.com/void-linux/void-mklive/issues/105
This is still very much a WIP as nothing is merged into the main Void repository yet, but some community members have done great work adding support for Pinebook Pro!
Void Linux is probably possible. - by aaspectre - 01-20-2020, 10:54 AM
RE: Void Linux is probably possible. - by branon - 01-21-2020, 08:41 PM
RE: Void Linux is probably possible. - by notpod - 01-30-2020, 05:56 PM
RE: Void Linux is probably possible. - by matosys - 02-04-2020, 08:49 AM
RE: Void Linux is probably possible. - by branon - 02-11-2020, 06:47 PM
RE: Void Linux is probably possible. - by branon - 02-18-2020, 07:42 PM
RE: Void Linux is probably possible. - by branon - 08-28-2020, 03:42 PM
RE: Void Linux is probably possible. - by wdt - 08-30-2020, 10:22 PM
RE: Void Linux is probably possible. - by branon - 09-03-2020, 06:54 PM
RE: Void Linux is probably possible. - by wdt - 09-03-2020, 08:59 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 397 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,577 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 691 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 161,814 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,237 11-28-2022, 05:03 PM
  Arch Linux ARM root filesystem SKiljan 24 21,199 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,171 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,436 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,131 03-22-2022, 06:37 PM
Last Post: pentamassiv
Sad 1080p60 video on PBP Linux chewie 2 3,083 08-03-2021, 09:43 AM
Last Post: chewie
