Armbian for the Pinebook Pro [WIP]
#58
(04-18-2021, 05:47 AM)lanefu Wrote: Sleep is delegated to systemd.  See /etc/systemd/sleep.conf
If you find a better configuration please share.
https://www.freedesktop.org/software/sys....conf.html
At the time of implementation hardware sleep of any kind was unreliable so this mode we're using is just kernel-based sleep.
Thanks for the quick reply! Note that in `/etc/systemd/sleep.conf` I had this at the end:
SuspandState=freeze
I corrected the typo (Susp*a*nd), and will test a bit more. The man page doesn't give me a lot of detail on the power saving differences between the different options, but it seems that `mem` means it will look at /sys/power/mem_sleep so I'll have to dig around and do some more testing of the various options.
Note that I FULLY support reliability :-) so can understand it may not be reasonably possible to find a better powersaving in sleep, since there are complaints about it disabling sound, possibly wifi, not waking at all, etc. Armbian really is great for the PBP, btw. I am currently on 5.10.21, and use Cinnamon (4.8 via PPA that we maintain) which is really quite performant (older Cinnamon up through 4.6 was sluggish).
Armbian for the Pinebook Pro [WIP] - by Luke - 01-19-2020, 01:51 PM
RE: Armbian for the Pinebook Pro [WIP] - by igorp - 02-02-2020, 01:43 PM
RE: Armbian for the Pinebook Pro [WIP] - by Luke - 02-02-2020, 02:10 PM
RE: Armbian for the Pinebook Pro [WIP] - by AliC - 02-05-2020, 08:53 PM
Armbian for the Pinebook Pro [WIP] - by Wizzard - 02-15-2020, 02:27 PM
RE: Armbian for the Pinebook Pro [WIP] - by _kiwi - 08-10-2020, 05:14 AM
RE: Armbian for the Pinebook Pro [WIP] - by tllim - 12-23-2020, 10:23 PM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 12-24-2020, 01:13 AM
RE: Armbian for the Pinebook Pro [WIP] - by Idaho - 01-06-2021, 06:14 PM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 03-10-2021, 12:12 PM
RE: suspend power consumption? (RE: Armbian) - by rik-shaw - 04-18-2021, 08:52 AM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 04-18-2021, 12:30 PM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 04-23-2021, 05:19 PM
RE: Armbian for the Pinebook Pro [WIP] - by sjk - 05-04-2021, 09:47 AM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 05-04-2021, 11:08 AM
RE: Armbian for the Pinebook Pro [WIP] - by Luke - 05-05-2021, 11:23 AM
RE: Armbian for the Pinebook Pro [WIP] - by wdt - 05-05-2021, 01:23 PM
  Boot Order in Pinebook Pro food 11 5,662 03-28-2025, 10:08 AM
Last Post: DrYak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 0 621 11-10-2024, 02:50 PM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 2,423 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 893 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 4,837 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 7,397 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,495 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 5,161 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 121,661 12-08-2023, 11:25 PM
  USB 3 port not working with Armbian zaius 3 2,705 11-13-2023, 01:54 PM
Last Post: zaius
