An unofficial Debian Installer for Pinebook Pro
(02-12-2020, 05:14 AM)Solra Bizna Wrote: After running the installer, mount the root partition, chroot into it, do whatever apt commands you want, exit from the chroot, and unmount the root partition.
Something like this:
mount /dev/mmcblk1p6 /mnt
chroot /mnt /bin/bash
apt install wpasupplicant network-manager
# (run any other commands you like here)
exit
umount /mnt
(make sure a given command succeeds before moving on to the next one)
There is also use the following to get a chroot shell: ./install-debian do_shell
Above approach is perfectly ok and often it won't make a difference which method you use. However do_shell will mount additional filesystems which allows you to run a wider set of commands to set things up and will also handle encrypted rootfs fairly smoothly.
RE: An unofficial Debian Installer for Pinebook Pro - by danielt - 02-12-2020, 05:58 AM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Debian on Pinebook Pro u974615 7 1,311 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,824 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,242 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,334 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,887 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,344 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,149 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,630 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,478 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,548 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
