An unofficial Debian Installer for Pinebook Pro
#75
(01-16-2020, 04:47 AM)danielt Wrote: Currently I do the following to configure:
make pinebook_pro_defconfig
scripts/config --set-str LOCALVERSION -1-pinebookpro-arm64
scripts/config --enable COMPAT
scripts/config --disable MODULE_COMPRESS
scripts/config --enable PREEMPT
scripts/config --disable HARDEN_EL2_VECTORS
scripts/config --enable RTC_DRV_RK808
make olddefconfig
Thanks, that was exactly what I was looking for! I'm cross compiling the kernel right now!
Quote:PS I'm happy to point you at my exact kernel sources if you have problems getting something working but, to be honest, putting focus on my kernel is just splitting the development community. Using the Manjaro kernel for your work is, IMHO, better for everyone for now... and you can switch to "real" mainline as soon as Thomas' lands the remaining patches.
Yeah, I agree- and maybe we can then also use the arm64 kernel package directly from Debian Wink
RE: An unofficial Debian Installer for Pinebook Pro - by bisco - 01-16-2020, 12:31 PM
First boot - by JaredT66 - 05-19-2020, 09:49 AM
RE: First boot - by carletes - 05-19-2020, 01:35 PM
  Boot Order in Pinebook Pro food 11 5,146 03-28-2025, 10:08 AM
Last Post: DrYak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 0 537 11-10-2024, 02:50 PM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 2,218 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 75,499 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 797 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 4,490 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 6,639 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,189 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 4,788 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 118,555 12-08-2023, 11:25 PM
