U-Boot with direct NVMe boot support for eMMC/SPI Flash
#83
(07-07-2020, 09:54 AM)tophneal Wrote:
(07-07-2020, 09:52 AM)mamboman777 Wrote: Well, I got lots of errors on the build.sh.  I think I may be missing dependencies?
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
make: *** No rule to make target 'realclean'.  Stop.
make: *** No rule to make target 'bl31'.  Stop.
cp: cannot stat 'build/rk3399/release/bl31/bl31.elf': No such file or directory
make: *** No rule to make target 'mrproper'.  Stop.
cp: cannot stat '../build/bl31.elf': No such file or directory
make: *** No rule to make target 'pinebook-pro-rk3399_defconfig'.  Stop.
make: *** No targets specified and no makefile found.  Stop.
/home/joshua/Desktop/u-boot-build-scripts-master/build.sh: line 37: tools/mkimage: No such file or directory
dd: failed to open 'idbloader-spi.img': No such file or directory
cat: u-boot.itb: No such file or directory
cp: cannot stat 'idbloader-spi.img': No such file or directory
cp: cannot stat 'idbloader.img': No such file or directory
cp: cannot stat 'u-boot.itb': No such file or directory
Did you install aarch64-linux-gnu-gcc and use git clone --recursive?
Well, I appear to be soft bricked.  I downloaded, extracted, ran the build file and moved to a usb.  I plugged the usb into my PBP, copied the files over, then navigated to the folder with spiflash.bin in it and ran "sudo dd if=spiflash.bin of=/dev/mtd0" which appeared to run successfully.  I then clicked reboot.  The machine will not respond now.  I'm not getting any sort of light when I press the power button.  The charge light on the side is the only light I'm getting.  What can I do next to troubleshoot this?  I've tried pressing the reset button.
RE: U-Boot with direct NVMe boot support for eMMC/SPI Flash - by mamboman777 - 07-07-2020, 02:12 PM
  uboot wont boot to SD card after upgrade jbradley419 7 909 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,291 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 722 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 610 11-22-2023, 11:47 AM
Last Post: fxc
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,719 11-20-2023, 06:22 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 772 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,228 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,936 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 817 07-13-2023, 01:50 PM
Last Post: PaulQ
