Enable KVM on default OS (Debian 9)
(11-30-2019, 05:50 PM)astr0baby Wrote:
(11-23-2019, 03:52 PM)Mrfixit2001 Wrote: Updated kernel in v1.5 update just released. A new release on GitHub was also pushed. I added virtualization and kvm to the kernel, as requested.
I can confirm that this does not work on the stock Debian-Desktop distribution with Kernel 4.4.202
Qemu just bails out that that "kvm" accelerator not found
The Manjaro-ARM   ( Kernel 5.4.0-1) works fine after setting
echo 0 > /sys/devices/system/cpu/cpu0/online
echo 0 > /sys/devices/system/cpu/cpu1/online
echo 0 > /sys/devices/system/cpu/cpu2/online
echo 0 > /sys/devices/system/cpu/cpu3/online
Then the 2 cores work with -enable-kvm  ( tested with qemu-system-aarch64  4.1.93)
It looks like maybe you're trying to use the 64-bit kvm? The default userspace is 32-bit while the kernel is 64-bit. So it supports 64-bit but you'll need to configure multiarch first. Otherwise I expect qemu-system-arm will work.
RE: Enable KVM on default OS (Debian 9) - by Mrfixit2001 - 12-02-2019, 11:45 AM
  Debian on Pinebook Pro u974615 7 1,164 03-31-2024, 10:11 AM
Last Post: u974615
  Nethunter default password failed lamlarryyyy 0 361 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,119 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,540 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,108 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,292 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,361 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,064 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,923 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,021 08-23-2022, 06:13 AM
Last Post: db579
