Power supply questions
(05-02-2016, 09:31 AM)montero65 Wrote: I did try plugging in my hard drive over the weekend, and while its light came on, it was making a clicking sound every few seconds, which I assume was from not enough power being available when it was trying to spin.  It didn't crash the board at least, so that was nice.
Expected behaviour. Maximum amperage when USB ports are fed through the PMU (power management unit) are 650mA. Most 2.5" disks need slightly more when they try to spin up. On the 2GB board you can use a jumper to power USB peripherals directly from DC-IN and not the PMU instead (only drawback: when you want to use a battery in such cases PMU + step-up converter won't provide power to the USB ports when running on battery) so on the 2GB board you won't have the problem if  you power Pine64+ through Euler pins (since Micro USB is simply crap to provide power to such a setup)
BTW: http://forum.pine64.org/showthread.php?t...45#pid7945
Power supply questions - by montero65 - 04-28-2016, 02:44 PM
RE: Power supply questions - by rahlquist - 04-28-2016, 02:52 PM
RE: Power supply questions - by longsleep - 04-28-2016, 02:55 PM
RE: Power supply questions - by ssvb - 04-28-2016, 03:41 PM
RE: Power supply questions - by montero65 - 04-29-2016, 08:35 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 08:47 AM
RE: Power supply questions - by montero65 - 04-29-2016, 09:11 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 09:26 AM
RE: Power supply questions - by rahlquist - 04-29-2016, 09:34 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 10:27 AM
RE: Power supply questions - by clarkss12 - 04-29-2016, 10:50 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 11:08 AM
RE: Power supply questions - by rahlquist - 04-29-2016, 01:26 PM
RE: Power supply questions - by montero65 - 04-29-2016, 01:49 PM
RE: Power supply questions - by Ghost - 04-29-2016, 01:58 PM
RE: Power supply questions - by tkaiser - 04-30-2016, 01:58 AM
RE: Power supply questions - by montero65 - 05-02-2016, 09:31 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 09:39 AM
RE: Power supply questions - by kflorek46 - 06-03-2016, 03:12 PM
RE: Power supply questions - by clamum - 05-02-2016, 09:46 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 09:54 AM
RE: Power supply questions - by rahlquist - 05-02-2016, 10:20 AM
RE: Power supply questions - by montero65 - 05-02-2016, 09:49 AM
RE: Power supply questions - by clamum - 05-02-2016, 11:35 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 11:38 AM
RE: Power supply questions - by rahlquist - 05-02-2016, 11:47 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 12:18 PM
RE: Power supply questions - by clamum - 05-03-2016, 02:04 PM
RE: Power supply questions - by peterz - 05-04-2016, 02:10 PM
RE: Power supply questions - by clamum - 05-04-2016, 02:35 PM
RE: Power supply questions - by SkimMilk - 05-06-2016, 01:24 AM
RE: Power supply questions - by tkaiser - 05-06-2016, 01:28 AM
RE: Power supply questions - by SkimMilk - 05-06-2016, 01:32 AM
RE: Power supply questions - by rahlquist - 05-06-2016, 05:45 AM
RE: Power supply questions - by mesaxi - 08-11-2017, 08:06 PM
RE: Power supply questions - by tllim - 08-15-2017, 03:51 AM
RE: Power supply questions - by mesaxi - 08-14-2017, 05:15 PM
  Pine64+ power button PaddyChan 0 2,815 09-14-2020, 09:55 AM
Last Post: PaddyChan
  UK power supply (Pinebook Pro 64) skobi 0 2,331 11-17-2019, 04:55 AM
Last Post: skobi
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 6,427 02-22-2019, 03:25 AM
Last Post: GaryFunk
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,771 05-24-2018, 01:58 AM
Last Post: crapped
  short boot time after power-up bongo 7 10,294 10-31-2017, 08:02 AM
Last Post: bongo
  PINE64/ROCK64 infra receiver power on cserem 1 3,650 10-06-2017, 07:25 AM
Last Post: MarkHaysHarris777
  Sufficient supply for product integration? SlowBro 4 6,500 02-19-2017, 10:40 AM
Last Post: dkryder
  Power-on pine by remote kleintvra 1 2,889 08-11-2016, 02:48 PM
  Chgled Power Reset rduerst 4 6,812 07-22-2016, 09:22 PM
Last Post: pfeerick
  Pine A64 not powering up / Power button missing vaevictis 10 14,207 07-06-2016, 01:28 PM
Last Post: xalius
