Power supply questions
(04-29-2016, 09:34 AM)rahlquist Wrote: they expect you will know how to find the stuff you need.
Or they simply didn't get the idea that powering might be a problem (typical 'hardware guy' behaviour: Using a bench PSU and AWG 20 rated short cables thinking 'what could go wrong?!'). And isn't it funny: They use a bench PSU adjusted to 5.1V but recommend 5.0V PSUs (instead of clearly saying 'get any 5.2V PSU made for Raspberry Pi since we made the same mistake as them and rely on Micro USB'): http://wiki.pine64.org/index.php/Main_Page#Power_Usage
And the problem with (Micro) USB is that focusing on the PSU isn't enough since the cable matters. When I started with this SBC stuff I also had no idea but since I started with A20 boards that already received superiour support by the linux-sunxi community back then I was able to read out the actual voltage: http://forum.lemaker.org/forum.php?mod=v...a=page%3D1
Two times the same PSU but in one case using a 'typical' Micro USB cable voltage drops below 4.6V occured with only slight loads (600 mA consumption). A64 is able to exceed 800mA easily, a few USB peripherals need another 300mA and then every 'typical' AWG28 rated USB cable will let the voltage drop below sane tresholds.
Power supply questions - by montero65 - 04-28-2016, 02:44 PM
RE: Power supply questions - by rahlquist - 04-28-2016, 02:52 PM
RE: Power supply questions - by longsleep - 04-28-2016, 02:55 PM
RE: Power supply questions - by ssvb - 04-28-2016, 03:41 PM
RE: Power supply questions - by montero65 - 04-29-2016, 08:35 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 08:47 AM
RE: Power supply questions - by montero65 - 04-29-2016, 09:11 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 09:26 AM
RE: Power supply questions - by rahlquist - 04-29-2016, 09:34 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 10:27 AM
RE: Power supply questions - by clarkss12 - 04-29-2016, 10:50 AM
RE: Power supply questions - by tkaiser - 04-29-2016, 11:08 AM
RE: Power supply questions - by rahlquist - 04-29-2016, 01:26 PM
RE: Power supply questions - by montero65 - 04-29-2016, 01:49 PM
RE: Power supply questions - by Ghost - 04-29-2016, 01:58 PM
RE: Power supply questions - by tkaiser - 04-30-2016, 01:58 AM
RE: Power supply questions - by montero65 - 05-02-2016, 09:31 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 09:39 AM
RE: Power supply questions - by kflorek46 - 06-03-2016, 03:12 PM
RE: Power supply questions - by clamum - 05-02-2016, 09:46 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 09:54 AM
RE: Power supply questions - by rahlquist - 05-02-2016, 10:20 AM
RE: Power supply questions - by montero65 - 05-02-2016, 09:49 AM
RE: Power supply questions - by clamum - 05-02-2016, 11:35 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 11:38 AM
RE: Power supply questions - by rahlquist - 05-02-2016, 11:47 AM
RE: Power supply questions - by tkaiser - 05-02-2016, 12:18 PM
RE: Power supply questions - by clamum - 05-03-2016, 02:04 PM
RE: Power supply questions - by peterz - 05-04-2016, 02:10 PM
RE: Power supply questions - by clamum - 05-04-2016, 02:35 PM
RE: Power supply questions - by SkimMilk - 05-06-2016, 01:24 AM
RE: Power supply questions - by tkaiser - 05-06-2016, 01:28 AM
RE: Power supply questions - by SkimMilk - 05-06-2016, 01:32 AM
RE: Power supply questions - by rahlquist - 05-06-2016, 05:45 AM
RE: Power supply questions - by mesaxi - 08-11-2017, 08:06 PM
RE: Power supply questions - by tllim - 08-15-2017, 03:51 AM
RE: Power supply questions - by mesaxi - 08-14-2017, 05:15 PM
  Pine64+ power button PaddyChan 0 2,795 09-14-2020, 09:55 AM
Last Post: PaddyChan
  UK power supply (Pinebook Pro 64) skobi 0 2,316 11-17-2019, 04:55 AM
Last Post: skobi
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 6,379 02-22-2019, 03:25 AM
Last Post: GaryFunk
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,720 05-24-2018, 01:58 AM
Last Post: crapped
  short boot time after power-up bongo 7 10,173 10-31-2017, 08:02 AM
Last Post: bongo
  PINE64/ROCK64 infra receiver power on cserem 1 3,620 10-06-2017, 07:25 AM
Last Post: MarkHaysHarris777
  Sufficient supply for product integration? SlowBro 4 6,436 02-19-2017, 10:40 AM
Last Post: dkryder
  Power-on pine by remote kleintvra 1 2,867 08-11-2016, 02:48 PM
  Chgled Power Reset rduerst 4 6,757 07-22-2016, 09:22 PM
Last Post: pfeerick
  Pine A64 not powering up / Power button missing vaevictis 10 14,053 07-06-2016, 01:28 PM
Last Post: xalius
