Booting with default debian image
(11-07-2019, 04:10 AM)danielt Wrote:
(11-07-2019, 02:51 AM)mfritsche Wrote: Next stupid question:
I see that extlinux.conf defines a boot menu. Is the menu only available via serial console?
Yes.
Hopefully this can change as the platform matures (u-boot can draw to framebuffers and listen to USB keyboards but it requires drivers and these don't exist just yet) but at present you need a serial port to interact with the boot menu.
A simple approach is to put your boot partition on an SD card since if you need to change kernel you can eject the card, boot from a eMMC and edit extlinux.conf .
So, my understanding is:
1. SoC looks for u-boot, loads u-boot
2. u-boot looks for boot loader (extlinux used for standard image), loads extlinux
3. extlinux looks for extlinux.conf, loads and starts kernel
So actually, it's extlinux that doesn't have a framebuffer/ keyboard to display the menu/ get user input right now?
Booting with default debian image - by mfritsche - 11-06-2019, 04:36 AM
RE: Booting with default debian image - by zaius - 11-06-2019, 02:02 PM
RE: Booting with default debian image - by mfritsche - 11-08-2019, 02:01 AM
Booting with default debian image - by tophneal - 11-07-2019, 09:36 AM
Booting with default debian image - by tophneal - 11-07-2019, 11:31 AM
  Debian on Pinebook Pro u974615 7 1,185 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,682 02-22-2024, 04:02 PM
  Nethunter default password failed lamlarryyyy 0 361 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,129 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,565 09-07-2023, 09:38 PM
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 989 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,117 07-15-2023, 02:58 PM
Last Post: u974615
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,930 04-01-2023, 02:58 PM
Last Post: TRS-80
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,363 12-09-2022, 05:04 AM
Last Post: ndp
