Booting with default debian image
(11-06-2019, 04:36 AM)mfritsche Wrote: Is there a guide/ explanation of the boot sequence for dummies?
I can see "Image" and "Image.bak" in /boot/. I want to build a custom kernel based on mrfixit2001's code (with changed configuration), but I haven't found out yet to recover as painless as possible when things go south.
Is there a boot menu in u-boot or something?
The answer is slightly complicated because you have the system on chip with one setting and the uboot on emmc has another.
In the SoC, the order is emmc, sdcard
However the code on the emmc will switch to sdcard if it is bootable.
Booting with default debian image - by mfritsche - 11-06-2019, 04:36 AM
RE: Booting with default debian image - by evilbunny - 11-06-2019, 05:17 AM
RE: Booting with default debian image - by zaius - 11-06-2019, 02:02 PM
Booting with default debian image - by tophneal - 11-07-2019, 09:36 AM
Booting with default debian image - by tophneal - 11-07-2019, 11:31 AM
  Debian on Pinebook Pro u974615 7 1,181 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,681 02-22-2024, 04:02 PM
  Nethunter default password failed lamlarryyyy 0 361 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  install debian on pbp jsch 7 4,127 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,559 09-07-2023, 09:38 PM
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 989 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,117 07-15-2023, 02:58 PM
Last Post: u974615
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,930 04-01-2023, 02:58 PM
Last Post: TRS-80
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,362 12-09-2022, 05:04 AM
Last Post: ndp
