RockPro64 Fan Pins
(10-24-2019, 10:47 AM)tblindba Wrote: I'm in the same boat. I've found that the 12V PWM fan header doesn't work for the fan I have, and any pwm setting in the hwmon other than >240 causes a rattling noise that won't work. I'm thinking about getting a Noctua 5V fan to run off the GPIO headers, but I have to work out how to set up the connectors. With a NAS with 2 3.5" HDDs, I need some cooling, but not a whole lot.
Does anyone know who sells a pin adapter for the 12V header?
Can anyone share their fan setups other than the Pine64 store fan?
Probably not what you are looking for but maybe a possibility. I have pine64 nas case with 2 3.5 inch wd red drives and had similar problem at the start. First i thought to use fan header on the board but to control it using cpu temperatures wouldn't be ideal nor did i know how to set it up, it is probably best to control it using hard drive temps.
I had spare zalman fanmate fan controllers laying around http://www.zalman.com/contents/products/...tml?no=504, they take 5 or 12 volt feed and output it to 5-11v 6W, so i removed shielding from sata power cable pair closer to the board (before there is something that converts 12volt to 5 volt for hard drives) not sure if it is important but i used the same pair as it goes to single hard drive. I routed fan controller outside the case and glued it at the back of the case. Attached image doesn't show the fan controller but gives you a brief.
.jpg   pine64Nas.jpg (Size: 492.59 KB / Downloads: 573)
RockPro64 Fan Pins - by TheUnknownMuncher - 10-08-2019, 10:37 AM
RE: RockPro64 Fan Pins - by TheUnknownMuncher - 10-08-2019, 12:44 PM
RE: RockPro64 Fan Pins - by tblindba - 10-24-2019, 10:47 AM
RE: RockPro64 Fan Pins - by vecnar - 11-03-2019, 05:05 PM
RE: RockPro64 Fan Pins - by tblindba - 11-06-2019, 05:12 PM
RE: RockPro64 Fan Pins - by vecnar - 11-09-2019, 09:56 PM
RE: RockPro64 Fan Pins - by tblindba - 11-13-2019, 08:22 AM
RE: RockPro64 Fan Pins - by vecnar - 11-14-2019, 04:06 AM
  Installing Wifi drive for the RockPro64 John45595 0 330 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 783 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 696 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,309 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 911 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,350 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,857 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,708 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,031 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,822 10-21-2022, 07:44 AM
Last Post: rapier1
