RockPro64 Fan Pins
I've done some searching through the forum and found that the fan connector is a 2mm PH type 2pin connector. I'm not seeing any pre-made adapters but I will probably be able to make my own. It appears that I will not have fan speed control, however, unless I build my own PWM controller, because 4-pin PWM will need 12V full supply at all times, and will just run at full speed. Is this correct? This sounds fine for me, because I generally am running at full speed anyway.
RockPro64 Fan Pins - by TheUnknownMuncher - 10-08-2019, 10:37 AM
RE: RockPro64 Fan Pins - by TheUnknownMuncher - 10-08-2019, 12:44 PM
RE: RockPro64 Fan Pins - by tblindba - 10-24-2019, 10:47 AM
RE: RockPro64 Fan Pins - by vecnar - 11-03-2019, 05:05 PM
RE: RockPro64 Fan Pins - by tblindba - 11-06-2019, 05:12 PM
RE: RockPro64 Fan Pins - by vecnar - 11-09-2019, 09:56 PM
RE: RockPro64 Fan Pins - by tblindba - 11-13-2019, 08:22 AM
RE: RockPro64 Fan Pins - by vecnar - 11-14-2019, 04:06 AM
  Installing Wifi drive for the RockPro64 John45595 0 313 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 762 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 684 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,262 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,329 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,828 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,657 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,800 10-21-2022, 07:44 AM
Last Post: rapier1
