Stream torrents with Kodi on Android
Hi everyone,
I just wanted to give some info about torrent streaming with Kodi. I tested several android devices and all of them support torrent stream with Kodi, so I believe that the pine64 will to (I can't tell for sure because my pine is coming in May so I haven't tested it yet).
I'd suggest to install Kodi via play store, ore some other store and download these plugins:
Kmediatorrent - Github link (after installing the kmediatorrent you'll have to go only on kickass torrents provider as other providers don't work)
Installation - after you download the zip file put it on a USB drive. Then insert the USB drive into your pine and start Kodi. Go to System - Settings - Add-ons - install from zip file. Find your USB and select the kmediatorrent zip file. after it installs it go back to the home screen and go to videos - add-ons and you will find the kmediatorrent. You'll need to configure it - do it as you wish than, although I would recommend only to setup the subtitles if you need them and everything else will work fine.
Quasar plugin - just go to this link and follow the instructions. When you go to the download page for the quasar plugin I would recommend to use the android_arm as the pine uses the arm processor. [url=https://seo-michael.co.uk/how-to-install-pulsar-repo-setup-pulsar-for-xbmc/][/url]
If someone tries this please inform if everything went ok, if not I will post everything after testing it on my pine when I receive it.
Stream torrents with Kodi on Android - by Treville - 04-17-2016, 07:53 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,811 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,832 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,886 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,007 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,083 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,356 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,691 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,632 02-10-2019, 07:44 PM
Last Post: mmmarcus
