WiFi/BT, How to make a connection?
How to make a WiFi/BT connection via shell command?
Tried WiFi first but doesn't succeed yet.
The following is some log.
Environment
Board : RockPro64
OS : bionic-minimal-rockpro64-0.6.59-273-arm64.img
WiFi/BT Module : ROCKPro64 2×2 MIMO Dual Band WIFI 802.11AC/BLUETOOTH 4.2 MODULE[url=https://www.pine64.org/?product=rockpro64-2x2-mimo-dual-band-wifi-802-11acbluetooth-4-1-module][/url]
Log
Quote:rock64@rockpro64:~$ uname -a
Linux rockpro64 4.4.132-rockchip-ayufan-273 #1 SMP Tue Jul 3 21:35:20 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
rock64@rockpro64:~$ sudo ip link set wlan0 up
RTNETLINK answers: Operation not permitted
rock64@rockpro64:~$ sudo ifconfig wlan0 up
SIOCSIFFLAGS: Operation not permitted
rock64@rockpro64:~$ networkctl | awk '/wlan/ {print $2}'
wlan0
rock64@rockpro64:~$ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet6 fe80::ec26:f5ff:fe58:fd1f  prefixlen 64  scopeid 0x20<link>
        ether ee:26:f5:58:fd:1f  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5  bytes 681 (681.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 24
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        TX packets 0  bytes 0 (0.0 B)
rock64@rockpro64:~$ sudo lshw -c network
  *-network:0 DISABLED
       description: Wireless interface
       physical id: 7
       logical name: wlan0
       serial: ac:83:f3:e6:25:16
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=wl driverversion=0 multicast=yes wireless=IEEE 802.11
  *-network:1
       description: Ethernet interface
       physical id: 8
       logical name: eth0
       serial: ee:26:f5:58:fd:1f
       capacity: 1Gbit/s
       capabilities: ethernet physical tp aui bnc mii fibre 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=March_2013 duplex=half link=no multicast=yes port=MII speed=10Mbit/s
rock64@rockpro64:~$ rfkill list all
0: bt_default: Bluetooth
        Soft blocked: no
        Hard blocked: no
1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
2: brcmfmac-wifi: Wireless LAN
        Soft blocked: no
        Hard blocked: no
rock64@rockpro64:~$ lsmod
Module                  Size  Used by
zram                   32768  6
lz4_decompress         16384  1 zram
lz4_compress           16384  1 zram
bcmdhd               1183744  0
rockchip_saradc        16384  0
snd_soc_rockchip_spdif    16384  2
snd_soc_rockchip_i2s    16384  4
snd_soc_rockchip_hdmi_dp    16384  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
autofs4                40960  0
dw_hdmi_i2s_audio      16384  0
rock64@rockpro64:~$ nmcli c
NAME  UUID  TYPE  DEVICE
rock64@rockpro64:~$ modinfo -p bcmdhd
dhd_doflow: (uint)
dhd_dpcpoll: (uint)
clockoverride:SDIO card clock override (int)
sd_msglevel: (uint)
sd_power: (uint)
sd_clock: (uint)
sd_divisor: (uint)
sd_sdmode: (uint)
sd_hiok: (uint)
sd_f2_blocksize: (int)
sd_f1_blocksize: (int)
g_assert_type: (int)
dhd_oob_gpio_numBig GrinHD oob gpio number (int)
clm_path: (string)
info_string: (string)
op_mode: (int)
dhd_msg_level: (int)
iw_msg_level: (int)
wl_dbg_level: (int)
android_msg_level: (int)
config_msg_level: (int)
dhd_arp_enable: (uint)
dhd_arp_mode: (uint)
disable_proptx: (int)
firmware_path: (string)
nvram_path: (string)
config_path: (string)
dhd_watchdog_ms: (uint)
dhd_console_ms: (uint)
dhd_slpauto: (uint)
dhd_pkt_filter_enable: (uint)
dhd_pkt_filter_init: (uint)
dhd_master_mode: (uint)
dhd_watchdog_prio: (int)
dhd_dpc_prio: (int)
dhd_rxf_prio: (int)
dhd_dongle_ramsize: (int)
passive_channel_skip: (int)
instance_base: (int)
iface_name: (string)
dhd_idletime: (int)
dhd_poll: (uint)
dhd_intr: (uint)
dhd_sdiod_drive_strength: (uint)
dhd_txbound: (uint)
dhd_rxbound: (uint)
dhd_deferred_tx: (uint)
dhd_pktgen: (uint)
dhd_pktgen_len: (uint)
allow_delay_fwdl: (int)
WiFi/BT, How to make a connection? - by Aesop - 09-27-2018, 11:07 PM
  AW-CM256SM wifi card mtek 4 2,411 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 12,859 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 2,800 07-20-2022, 03:31 AM
Last Post: imianz
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,587 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,318 03-10-2021, 12:23 AM
Last Post: Wizzard
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 2,038 11-17-2020, 04:25 AM
Last Post: pi64
  new WIFI/BT module not working with android 8.1 Firesped 0 2,036 05-12-2020, 10:33 PM
Last Post: Firesped
  Questions about the ROCKPro64 1x1 Dual Band WIFI module thelabratrules 0 2,019 04-04-2020, 03:29 PM
Last Post: thelabratrules
  Best location for adhesive wifi antennas with NAS case callegar 1 3,079 02-17-2020, 12:40 PM
  No WiFi f4exb 3 5,043 11-11-2019, 05:54 AM
Last Post: winstar
