Questions about the ROCKPro64 1x1 Dual Band WIFI module
Hi!
I'm planning to buy this module, though I have some questions about it.
First, does it have compatiblity issues? I've read that in the past there were problems with the WiFi module - though I'm not sure it was the same model.
Second, what speed can it achieve on 5Ghz? I haven a 1000/1000 Mbps connection, so a minimum 200Mbps down and up would be reasonable for me.
Third, do I need to get an antenna for it?
Fourth, is it easy to unplug the chip? I have two RockPro64 (2GB/4GB version), I plan to use it for one, but there could be occasions where I'd like to plug it in the other one.
  Powering two disks from RockPro64 some_pinephone_user 3 6,934 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 4,043 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,431 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 11,423 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 4,747 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,985 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 4,194 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,978 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 17,729 11-08-2022, 03:40 AM
Last Post: ajtravis
  U.FL plug on the Wifi/BT module? domih 8 21,523 10-17-2022, 04:43 AM
Last Post: callegar
