Considering buying and question on the PCIe slot
(08-10-2018, 11:56 AM)MobileJAD Wrote: Any luck?
I just purchased a Rockpro64 kit, I'm very curious what PCIe cards will work using drivers included with the Linux kernel and what devices will work but only after some extra work.
Right now the big problem seems to be getting the rockpro64 pcie driver working for most cards. There's really no way to test anything other than a handful of cards that work for unknown reasons right now.
The only cards I've seen mentioned that function (are seen with lspci, pcie bus starts successfully) are some sata and nvme boards and an Intel I350-T* nic. I've tested with 3 separate Mellanox 10Gb cards and none of those function at the moment. I have a couple more HP 4x1Gb nics that I can test sometime this week, one is a rebadged Intel I340 so I suspect it'll work and the other is a Marvell chip.
RE: Considering buying and question on the PCIe slot - by Arglebargle - 08-10-2018, 02:10 PM
Question Another Fan Question backwoodstech2 1 368 02-03-2024, 04:09 PM
Last Post: backwoodstech2
Information Question regarding odd startup behaviour Mff 0 1,184 12-03-2022, 03:18 PM
Last Post: Mff
  PCIE interface power on too late Slark Xiao 0 1,018 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  PCIe gen1 timeout - how to debug tosi 3 4,582 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 1,742 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,772 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 2,681 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,713 10-20-2020, 10:52 AM
Last Post: GreyLinux
  PCIe x4 mode - Lane 3 failure acdkyn 1 2,785 04-24-2020, 01:32 PM
Last Post: kuleszdl
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,139 04-16-2020, 12:30 AM
Last Post: mjembd
