boot logs shows chinese ip trying to login ssh
I would recommend not running sshd on a public IP address unless there is some reason you need to log in remotely. The most secure way is to put the machine behind a firewall.
or if you have multiple network interfaces, you can tell sshd only to listen on the internal one. You can also tell sshd not to allow root to log in over ssh. You can also tell sshd to listen on a different port than 22, this will cut down on login attempts but not eliminate them. All of these things can be done by editing /etc/ssh/sshd_config.
Another thing you can do is configure sshd to authenticate using RSA encryption keys instead of passwords (you have to generate the keys first and distribute them to any machine(s) you want to connect from).
Here's an article with some good tips on securing your SSH: https://www.cyberciti.biz/tips/linux-uni...tices.html
RE: boot logs shows chinese ip trying to login ssh - by psychedup - 05-31-2018, 01:28 PM
  Rock64 won't boot luminosity7 10 4,192 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 346 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,549 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,122 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,070 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 2,671 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,590 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,559 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,691 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 15,424 08-27-2020, 01:44 PM
Last Post: globaltree
