your monitor is listed as dvi-d so you should be using a dvi-d to hdmi adapter? one issue with dvi-d to hdmi is the hdmi copy protection signal is messed up/not understood by the dvi-d monitor since at the time they were made that protection had not be in place. but another thing is there may be a config file that needs to be changed. you might want to join the chat and see if the devs can help you.
Monitor Display Resolution
Messages In This Thread |
Monitor Display Resolution - by Riverman - 03-19-2018, 04:10 PM
RE: Monitor Display Resolution - by dkryder - 03-20-2018, 01:31 AM
RE: Monitor Display Resolution - by Riverman - 03-20-2018, 10:14 AM
How do i change the default resolution? | BowerR64 | 0 | 2,325 |
09-05-2020, 02:20 PM Last Post: BowerR64 |
Android9 blinking screen and can't change resolution for home screen | AlexS | 0 | 2,031 |
07-24-2019, 08:06 AM Last Post: AlexS |
Android GUI resolution | Vasant | 1 | 3,175 |
02-28-2018, 10:50 AM Last Post: Luke |
Cannot select resolution past FullHD | Lexstar | 0 | 3,693 |
08-25-2017, 04:34 PM Last Post: Lexstar |
