How do i change the default resolution?
So i got 3 of those Rock64 boards off Amazon, i only got one emmc card for one so far.
I went threw all of the Android files (Android is all i really know how to use as of now)
Anyway i installed one that is Android 9 tv emmc boot and one that is SD boot. My issue is the SD boot one has a defualt of 1920 x 1080, the emmc install deufalts at 1280 x 720 and it wont change in the settings, ive reinstalled the operating system more then once and its like stuck in the firmware or somethin
Can some one guide me on how to fix this so its like the SDboot version?
I tried to install the SDboot version onto the emmc but for some reason when using this version on the emmc it no longer reconizes the SD reader (im guessing because the os should be on here instead?)
Its been a fun little board so far, i dig all of the different OS files, havnt tried em all yet but its cool they are available
  Android9 blinking screen and can't change resolution for home screen AlexS 0 3,348 07-24-2019, 08:06 AM
Last Post: AlexS
  Monitor Display Resolution Riverman 2 5,519 03-20-2018, 10:14 AM
Last Post: Riverman
  Android GUI resolution Vasant 1 5,134 02-28-2018, 10:50 AM
Last Post: Luke
  Cannot select resolution past FullHD Lexstar 0 5,110 08-25-2017, 04:34 PM
Last Post: Lexstar
