RockPro64 and Pine H64 Discussion Thread
All below is related to the RockPro64 dev board.
Great specs.
But BT 4.1 is a disappointment though. BT 4.2 would have been better (for me) because of more speed (to my BT 4.2 laptop) and I want to experiment with the IP connectivity (internet) for smart devices/sensors.
1) So can you confirm that it is possible to successfully use a BT 4.2 dongle in one of the USB 2.0 ports ?
2) Will it be possible to fully disable/blacklist only the BT controller of the WiFi/BT module, and leave the WiFi fully working ?
3) Will you be making available downloads of, or links to, the onboard chips datasheets and example source code ?
For example a link like this one : http://www.ti.com/product/WL1837MOD and also links to, or downloadable sample code of, a working skeleton with hints and comments.
Yes, make it easy for devs. In MS style.
I realise that the kernel and userspace source code for Mali drivers is probably blob format only, and therefore off-limit.
4) Do you release Linux kernel and Android kernel as full source, or source code with blobs ?
5) What else will be released as blob only?
6) For how many years will you actively support the RockPro64 with image updates, and source code updates ?
"..... there are mounting holes for a heatsink and a header for a fan on the PCB. .....".
7) Will a heatsink+quiet_fan combo be available upon launch, or is this up to 3rd parties ?
"..... Both boards have the same dimensions as the original Pine A64 (133mm x 80mm x 19mm). ....."
8) But the i/o ports will be layed out differently and there will be a heatsink+fan combo. Will a case (taking into account heatsink+fan combo) be available upon launch, or is this up to 3rd parties ?
9) Will there be power supplies/adapters available ?
10) If not, what power supply/adapter without PCI-e card, and what power supply/adapter with a lot of power sucking PCI-e card ?
(Volt, amp, plug).
RE: RockPro64 and Pine H64 Discussion Thread - by Tigger - 01-31-2018, 02:56 PM
  Shipping Update and Stock Availability Thread Luke 92 118,064 11-25-2024, 12:48 AM
Last Post: P. Siera
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 203,053 06-04-2021, 09:43 AM
Last Post: Luke
  PinePhone Mobian CE shipping update thread Luke 59 98,015 04-25-2021, 12:57 PM
Last Post: Luke
  PinePhone KDE Community Edition shipping update thread. Luke 135 212,993 04-11-2021, 01:47 PM
Last Post: Luke
  Manjaro Community Edition Shipping thread Luke 122 180,351 01-28-2021, 07:30 PM
Last Post: Muad
  December Community News Discussion Luke 2 8,358 01-19-2021, 04:48 PM
Last Post: zer0sig
Information August/ September Pinebook Pro, PineTab and PinePhone shipping thread Luke 256 441,111 10-27-2020, 11:14 AM
Last Post: Luke
  New Pine Store is up! Luke 17 35,740 10-12-2020, 04:28 PM
Last Post: zer0sig
  Pine Tab Markdanni123 3 7,312 10-04-2020, 11:26 PM
Last Post: zer0sig
  September Pine phone sales ? bcnaz 5 10,762 09-26-2020, 01:36 AM
Last Post: bcnaz
