The 6 most common reasons why Pine64 won't boot
#30
(04-17-2016, 11:16 AM)yourhighpriestess Wrote:
(03-31-2016, 10:03 AM)Andrew2 Wrote: Data written to SD card got corrupted either because you unfortunately bought a counterfeit SD card or the card is faulty. Another common problem are SD card readers that start to overheat when used with a fast card and corrupt data 'on the fly'. Checking for both problems is simple: Never use any flash based media without verifying it before.
how do I get around the timeouts I get with Phoenix?
You should read the posts you're answering to. Check the card you want to use first since it's easy and a prerequisit for burning Android images (Phoenix Card will fail pretty early when used with a counterfeit card, will stop right after the "[Boot]Burn success" message since writing the system partition beyond the card's real capacity is obviously not possible)
RE: The 6 most common reasons why Pine64 won't boot - by tkaiser - 04-18-2016, 02:09 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 188 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,255 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,692 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,599 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,724 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,774 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,502 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,165 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,279 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,175 10-18-2020, 01:41 PM
Last Post: toiny
