The 6 most common reasons why Pine64 won't boot
#93
(10-19-2016, 12:34 AM)ChrisG Wrote: It's still not booting regularly. More then half of the time I get the white stripe screen. I spend way too much money on this board for it not to function. Appreciate if one of the moderators or experts (MarkHaysHarris777?) of Pine64 can give some definitive tips and suggestions to rule out other issues. When it runs it performs better on the Samsung Evo card. However when playing around with it, e.g. connecting to WiFi, browsing, testing the occasional app. It freezes for a while or indefinitely and then the white-striped screen comes. Rebooting does not resolve the issue at all then. Appreciate the help here.
This sounds like the board is malfunctioning. Please confirm, are the white stripes on the LCD 7" display, or are the white stripes on the hdmi display ?
Are the stripes in the 'same' position horizontally?  (or do they move around from boot to boot)
Can you try another pine board with the same display?  Do the stripes follow the board, or are they persistent on the display board ?
Vertical stripes are usually indicative of a bad display board, interface connector, or bad ribbon. More often the not the stripes are the result of having a defect in the display itself; not on the computer board producing the image !
I of course cannot reproduce your difficulties; although, I am sorry.  You might like to open a support ticket and perhaps your board can be replaced; however, it would be nice if you can narrow down whether the striping is the display proper, or the pine board-- some further diagnostics will be helpful.
RE: The 6 most common reasons why Pine64 won't boot - by MarkHaysHarris777 - 10-19-2016, 08:04 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 148 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,213 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,651 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,593 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,720 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,770 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,486 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,138 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,269 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,172 10-18-2020, 01:41 PM
Last Post: toiny
