power supply
(02-17-2016, 07:03 AM)MichaelMeissner Wrote:
(02-17-2016, 05:18 AM)Phlebas Wrote: I have a 5v 3.0amp micro usb unit will this be ok for P64+ 2Gb board ?
If the power supply always delivers 3.0 amps, no matter what you connect to it, then it would work.  However, there are some micro USB power supplies that try to be 'smart' and will only deliver higher amps if they are connected to a phone that they recognize.  If they connect to an unknown device, they might throttle the power down to 0.5 amps (500mA).
The other issue is whether the power supply is designed to deliver 3 amps all of the time without overheating, or it is meant to deliver 3 amps as a peak amount.  It really depends on how well it is made.
Haha, yes. That is the longer answer Smile
power supply - by Phlebas - 02-17-2016, 05:18 AM
RE: power supply - by Ghost - 02-17-2016, 05:29 AM
RE: power supply - by Phlebas - 02-17-2016, 05:38 AM
RE: power supply - by MichaelMeissner - 02-17-2016, 07:03 AM
RE: power supply - by Ghost - 02-17-2016, 07:05 AM
RE: power supply - by Phlebas - 02-17-2016, 08:49 AM
RE: power supply - by tllim - 02-17-2016, 09:49 PM
RE: power supply - by By-Jokese - 02-21-2016, 06:15 AM
RE: power supply - by tllim - 02-21-2016, 09:13 PM
  New RockPro64 Power Up Problem enorbet2 7 5,113 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,868 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,947 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,435 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,496 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 5,118 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,796 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,134 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,559 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,144 10-23-2016, 12:16 PM
Last Post: dkryder
